Forum » Programiranje » Pomoč pri programiranju pacmana v visual studiu.
Jiffle ::
public partial class Form1 : Form
public Form1()
InitializeComponent();
char smerP = 'R';
int speedP = 3;
char smerG = 'R';
int speedG = 3;
int tocke = 0;
R - right
L - left
U - up
D - down
private void timer1_Tick(object sender, EventArgs e)
switch (smerP)
case 'R': pbPacman.Left += speedP; break;
case 'L': pbPacman.Left -= speedP; break;
case 'U': pbPacman.Top -= speedP; break;
case 'D': pbPacman.Top += speedP; break;
private void pbPacman_Tick(object sender, EventArgs e)
if (pbPacman.Bounds.IntersectsWith(cesnja.Bounds))
tocke += 100;
tocke2.Text=(tocke.ToString());
if (pbPacman.Bounds.IntersectsWith(limona.Bounds))
tocke += 100;
tocke2.Text = (tocke.ToString());
private void Form1_KeyDown(object sender, KeyEventArgs e)
switch (e.KeyValue)
case 37: smerP = 'L'; break;
case 38: smerP = 'U'; break;
case 39: smerP = 'R'; break;
case 40: smerP = 'D'; break;
private void tGhost_Tick(object sender, EventArgs e)
Ghost-a bi bilo dobro omejiti, da bi se
premikal le znotraj okna, sicer hitro uide
izven vidnega polja.
switch (smerG)
case 'R': pbGhost.Left += speedG; break;
case 'L': pbGhost.Left -= speedG; break;
case 'U': pbGhost.Top -= speedG; break;
case 'D': pbGhost.Top += speedG; break;
// Spodnji del kode zazna, ali sta se pacman in gost 'zaletela'
if (pbGhost.Bounds.IntersectsWith(pbPacman.Bounds))
tGhost.Enabled = false;
tPacman.Enabled = false;
MessageBox.Show("Konec igre");
private void tSpremeniSmerG_Tick(object sender, EventArgs e)
/* Trapasta logika premikanja ghost-a. Vsake toliko časa
izbere naključno smer.
Primerna izboljšava bi bila tudi, če bi se ghost
premikal tako, da bi sledil pacmanu.
Random r = new Random();
switch (r.Next(4))
case 0: smerG = 'U'; break;
case 1: smerG = 'R'; break;
case 2: smerG = 'D'; break;
case 3: smerG = 'L'; break;
}Zanima kaj tocno imam narobe pri "private void pbPacman_Tick(object sender, EventArgs e)" ker hočem da mi vsakič ko se pacman dotakne sadja mu zviša tocke, toda mi ne uspeva. Zanima me tudi kako bi najlazji nacin naredil "zide" ( to da pacman niti ghost ne more iti čez , ali je treba uporabiti Intersect.Bounds kodo?
- spremenil: bluefish ()
| » | [c#] Slika iz URLOddelek: Programiranje | 3376 (2963) | MrBrdo |
| » | C# PomočOddelek: Programiranje | 1816 (1641) | jizzer |
| » | uporaba C++ unmanaged kode v C#.NET projektuOddelek: Programiranje | 2324 (2047) | krho |
| » | [c#] enostavna Igrca -> poraba procesorja 95%Oddelek: Programiranje | 2518 (1882) | elKaktus |
| » | [Visual C#] posodabljanje poljaOddelek: Programiranje | 1996 (1816) | iggy1 |
