Zelo slab DL, UL je vredu?
AnotherMe ::
Na (samo) enem računalniku imam nikakršen DL pod 1Mbps! Na vseh ostalih brez problema čez 5Mbps. Zanimivo je, da upload pa je recimo vredu.
Računalnik je nek starejši AiO HP, povezan preko (vgrajenega) wifi. Naloženi so sveži W10. Enako je tudi, če povežem preko usb wifi dongla. Na istem mestu laptop ali telefon deluje brez problema.
Ideje?
Iatromantis ::
https://lmgtfy.com/?q=poor+wifi+speed+w...
The solution for me was to go to Activity Center (Windows Key + A) and turn off "Location". My Wi-Fi speed is now consistent at the highest speed I am paying for and returns the same result on speed test as my wired connection.
or
STEP 1: Open Run and type devmgmt.msc to open device manager.
STEP 2: Locate the wifi adapter and double click to open properties window.
STEP 3: Go to "Advanced" tab.
STEP 4: Click on "802.11n Bandwidth" [You may have b,g or n after 802.11[b/g/n] Bandwidth].
If not found & then you may have default windows driver installed.Then you can found an option of "HT Mode".
STEP 5: Change the value in dropdown to "20MHz/40MHz Auto" if already not selected.
Note: If you have default windows driver installed then you may have options in the dropdown like "HT Mode 20|40". If you found then select it.
STEP 6: Click "Ok". It will restart your adapter automatically and may solve your problem.
konspirator ::
Preko kabla testiraj.
mojster_joni ::
AnotherMe je izjavil:
Ideje?
sem ti označil težavo
AnotherMe ::
preko kabla je cca 180/20
preko laptopa 25/10
tudi z usb wifi donglom, mi pokaže praktično enako hitrost kot na vrajenem wifi (če dongle štekam v laptop pokaže podobno kot vgrajen laptopov wifi)
tudi na laptopu ima w10...
"STEP 4: Click on "802.11n Bandwidth" [You may have b,g or n after 802.11[b/g/n] Bandwidth].
-> nič od tega nimam...
AnotherMe ::
Zdej je tako... Glede na to, da prek kabla dela vredu, moznosti, da bi kabl napeljal pa nimam, me zanima, ali lahko en wifi router postavim kot "sprejemnik" in na mrezni port priklopim racunalnik?
next3steps ::
Lahko.
AnotherMe ::
Kul. Bom pogledal, kaj imam kaj viska... Kaksna splosna navodila? Oz. Kaj sploh iskati?
Nekako takole?
http://www.makeuseof.com/tag/how-to-tur...
Router za običajnega uporabnika na optiki (strani: 1 2 )
Oddelek: Omrežja in internet
5314064 (12300) XS!D3
Kako usposobiti wifi na starem laptopu?
81281 (1017) Pentium
moč wifija
172561 (2151) Ribič
Čuden problem z nihanjem WIFIja - TL-WR1043ND
478276 (7107) krop
Win XP SP2 in Blutooth
82450 (2295) jast
