Koliko gb rabi video kamera 2.0 mp s kompresijo H.264
alese ::
Vprašanje je, recimo s kamero 2.0mp to je 1080P(1920×1080, frame rate 15 fps, kompresija H.264/G.711, snemaš eno uro, koliko je to gb.Da vidim stručnjake :)
b3D_950 ::
alese ::
Kaj je to bitrate, gre za snemalnik tale https://digitklik.si/izdelek_HD-CVI-SNE... in kamero tole https://digitklik.si/izdelek_VIDEO%20NA... hvala
Kodek ti nič ne pove o velikosti file. Potrebuješ informacijo o nastavitvi kompresije, ponavadi je ta podatek imenovan bitrate(ki pove koliko prpstpra zasede ena sekunda)
alese ::
Lonsarg je izjavil:
semnašel, piše 1Kbps ~ 6144Kbps Per Channel, koliko sedaj zavzame prostora.hvala
  • spremenil: alese ()
Mavrik ::
Zdeliš z 8 pa vidiš. Pri 6144Kbps to pomeni 768 KB/s posnetka za vsak kanal.
  • spremenil: Mavrik ()
alese ::
Mavrik je izjavil:
Od česa pa je odvisno ali ima bitrate 1 kbps ali 6144 kbps
Baja ::
od tega kako nastaviš ;)
alese ::
Baja je izjavil:
a ni odvisno od tega kakšno kamero imaš koliko resolucije
BivšiUser2 ::
File size is calculated simply using duration x bitrate. Other things like frame rate, dimensions and bpc will have little effect.
It ain't necessarily so.
While that is true if you are exporting to a format and codec that has variable bit rates, if you are using an uncompressed format or a lossless codec (like Lagarith, for example), those other elements--frame rate, dimensions, and bit depth--are primary factors in file size.
For example, I just did a quick test using 6 seconds of a simple red solid matte in a 24p sequence, exported using Microsoft AVI/None in three different frame sizes. Here's the results:
100x100: 4,407 KB
512x512: 115,212 KB
1920x1080: 911,262 KB
Huge differences, due to just one of those other factors. However, when using something like MPEG-2 or H.264, you can control the bitrate, and each of those three encodes would be pretty similar in file size.
Jim--I know you know all this, but I just thought it prudent to point out that there are those other factors to consider when dealing with certain encoding scenarios.
SloTech - če nisi z nami, si persona non grata.
Mavrik ::
alese je izjavil:
Baja je izjavil:
Ne. Odvisno je od tega koliko je na kameri nastavljeno, resolucija je drugačna stvar.
alese ::
Mavrik je izjavil:
alese je izjavil:
Baja je izjavil:
KAJ, kaj nastaviš na kameri, na kameri se ne da nič nastavit ne razumem odgovora
Mavrik ::
Glej, kamera mora imeti nastavljeno NEKAJ. Zdaj če nima opcij, ima pač vnaprej nastavljen bitrate od proizvajalca. In mi ti NE MOREMO povedati na kaj je nastavljena ker kamere ali navodil za njo nimamo. In zato ti tudi NE MOREMO povedati kako veliki bodo posnetki.
Če pa pogruntaš na koliko je nastavljen bitrate na kameri, pa boš lahko tudi zračunal velikost posnetkov.
b3D_950 ::
Na snemalniku boš lahko nastavljal bitrate od 1~6144Kb/s
Zelo verjetno nastavitve ne bodo v taki preprosti številki, pač pa se bo ta bitrate sam določil glede na resolucijo im morda kako (low, medium, high) nastavitev. Skratka če boš vse izbral največ bo 6144Kbps, zna biti da take nastavitve sploh ne bo, v takem primeru bo bitrate pri 1080p resoluciji najbrž kar 6144Kbps.
Nastavitev kamere v tem primeru nima veze, ker bo snemalnik tisti, ki bo kompresiral video.
Wifi router s POE porti (strani: 1 2 )
Oddelek: Omrežja in internet
8113623 (10601) rdecaluc
Bitna hitrost zvoka
416303 (5007) XLapse
Android snemanje/kompresija videa
Oddelek: Mobilne tehnologije
243376 (3070) iloveboobz
PS 3
Oddelek: Konzole
202971 (2516) scuba123
V XivD
Oddelek: Zvok in slika
92291 (1996) gumby
