Forum » Strojna oprema » AMD Navi - GPU
AMD Navi - GPU
ASRock's EEC Listing Suggests 12 GB VRAM For Radeon RX 6600 XT & 6 GB VRAM For Radeon RX 6700 'RDNA 2' Graphics Cards
https://wccftech.com/amd-radeon-rx-6700...
Horas ::
ka je s ttmu amdju? 6700 samo 6gb????
8700k+z390, 32gb 3600mhz, 1080ti, 700w gold, 512gb+2x250gb m.2 nvme + 2tb hdd
8500+b360, 32gb 2666mhz, rx 6600, 600w bronze, 512gb+250gb ssd m.2 + 2tb hdd
FlyingBee ::
Za esport fhd drkadžije.
New Sphincter Kvartet:
DamijanD ::
Horas ::
groza ja, sem mislil da bo kaj fajnega v amd taboru da zamenjam rx580 pa zgleda da še oni začenjajo nategvat ker pač lahko, če to dela ena konkurenca bojo še oni.
me res zanima koliko hitrejša bo 6600xt od rx580 še posebej pa od 1080ti
- spremenil: Horas ()
FlyingBee ::
Edina konkurenca. Če bo 6600xt hitrejša od 1080ti bo dober deal, ker so radeonke precej slabše v miningu, zna amd tokrat zadovoljiti gamerje.
AMD RX 6700 listed with 6GB, half the VRAM of RX 6700 XT cards
By Dave James an hour ago
The new mainstream card will also come with less memory than the old AMD RX 5700 from 2019.
https://www.pcgamer.com/amd-rx-6700-6gb...
FlyingBee ::
Edino prav, za vse ostale pa bo 12gb 6700xt.
FlyingBee ::
The RX 6700 should still be able to use the Infinity Cache feature, which allows it to multiply the effective memory bandwidth at its disposal. Though that's not necessarily something that matters a whole lot at the lower resolutions the RX 6700 series of cards is targeting.
Ufffff. Zna biti 6700 kljub 6gb kar beštija.
IC jo bo reševal.
IC jo bo reševal.
- spremenil: D3m ()
FlyingBee ::
Verjetno manj zanimiva za minerje in ravno prav za fhd gamerje.
Horas ::
kaj pa bo potem 6600xt 12gb?
nekje medium-high 1440p?
FlyingBee ::
Ta bo predvsem za mešat štrene 3060 12gb. Marketing department je verjetno tako zahteval.
AMD Radeon RX 6700 XT 12 GB & Radeon RX 6700 6 GB Custom Graphics Cards From PowerColor Spotted
Master_Yoda ::
to pomeni, da se bo samo 6700XT kupoval...
Ja tista 2 komada ki bosta prvo leto na zalogi :D.
Dovie'andi se tovya sagain.
Rumor | AMD RDNA 3 Navi 31 160 CU MCM internal performance target to be 2.5x RDNA 2 Radeon RX 6900 XT, Navi 33 will still be monolithic; NVIDIA Lovelace has RDNA 3 and Intel Xe firmly in sight
https://www.notebookcheck.net/AMD-RDNA-...
Tale NAVI bodo pa kar še nekaj časa vlekli ?
FlyingBee ::
Podobno kot zen že 4 leta, izkazala se je za dobro potezo, GCN je bil zaviralec.
Tudi Lovelace bo podvojeno CU, noro. V bistvu lahko Ampere in rdna2 gladko preskočimo.
- spremenil: FlyingBee ()
FlyingBee ::
2x 80cu žival, prvi mcm v high end, to bo še zanimivo
Malce sprememb v zasnovi CU-ja jim ne bi škodilo, recimo več računskih enot, kar bi šlo kar vredu v tandemu z infinity cachem.
Moj problem je predvsem ta, da me načeloma kartice s porabo nad 200W in ceno nad 500€ ne zanimajo preveč.
Vem, da za mnoge to ni težava, ampak se načeloma dokazuje, da je še prostora za arhitekturne izboljšave.
Vuli ::
pismu, a zdej bodo še 6800xx začele zginjat.
RDNA3 bo preboj MCM čip design.
Enkrat 2022 najbrž.
To z Advanced Node zna bit problem, ker bi znala biti gneča.
GenZNPC ::
Itak ne boste dobili teh p/w kartic, dokler bo BTC nad 30k$
Sanja svinja kukuruz. Bodo midrange graficne gladko cez 1000eur se 1-2 leti.
skibidi
Škoda, da nisem kupil nov GPU pred meseci. Jebiga, zgodovina se ponavlja. Po drugi strani pa itak nimam časa za igrice:).
FlyingBee ::
18. marca bo verjetno izid 6700xt.
https://www.techpowerup.com/278664/amd-...
Sapphire Radeon RX 6900 XT Toxic Limited Edition 'Big Navi' Custom Graphics Card Unveiled - Hybrid Cooled Monster, 2.66 GHz Boost Clocks
https://wccftech.com/sapphire-radeon-rx...
Horas ::
ko se sam spomnim kk so bli glasni tule gor avgusta-novembra, počakajte!!! počakajte!!!!
FlyingBee ::
No, no, bilo je novembra ok.
FlyingBee ::
3.3., torej v sredo bo uradno glede 6700xt in 6700, slednja bo verjetno vsaj 5700xt perf, boljša od 3060, 6700xt pa 2080s oziroma boljša od 3060ti. Cene? Kdo ve.
Horas ::
vemo cene, ne se sprenevedat, amd ni dobrodelna ustanova
Čisto možno je, sodeč po slabi dobavljivosti 5600xt do 5700xt, da so že pred časom nehali s proizvodnjo procesorjev za te kartice in je bilo preusmerjeno v RDNA 2.0 čipe.
https://geizhals.de/sapphire-radeon-rx-... - za ilustracijo o ceni povprečne RDNA 1.0 kartice.
temp1337 ::
Nevem zakaj žališ cigane in v istem stavku se jim opravičuješ. Prav tako ne razumem zakaj bi nekdo kupoval komponente v računalniku zaradi izgleda.
Ne sekiraj se preveč, če ne razumeš vsega, za vse je čas, tudi za odgovore.
Ajde, glede drugega se nekoliko strinjam s teboj. Vizualna komponenta komponent je totalno stran vržen gnar, zato se še posebej čudim vsem firmam, ki te hladilnike ozaljšujejo z nekimi vzorci in barvami, nalepkami in podobnim. Zato mi je tale Lenovota karta všeč, saj gre skoraj kontra logiki RGB neumnosti. Ampak to še ni vse, dandanes lahko kupiš grafično kartico, ki ti na namenskem lcd-zaslonu prikazuje, kaj trenutno igraš na WinAmp playerju! Prečudovito! Nekaj pa je res, tudi tale Lenovo vso reč zajebe s tistim RGB sranjem. Mar ne morejo teh zadev delati podobno kot M16? Uporabnost pred obliko, šparanje resursov na nekih glupih dizajnih in podobno. Zdi se namreč, da je industrijski dizajn grafičnih kartic večinoma usmerjen v polinteligentne posameznike, ki tripajo samo na fragmentirane in našpičene dizajne, in barvno kričečnost, kot da smo neki zadeti rejverji s sredine devetdesetih.
Vsaj dve besedi sem izumil v tem odstavku, dobro mi gre.
DamijanD ::
18 marca bo release, zmanjkalo pa jih bo 5 secund pozneje
Drugače pa 6700XT tam okrog 3070 glede na grafe.
