Forum » Sedem umetnosti » The Mandalorian [Star Wars - Tv serija]
ripmork ::
Sem z mal zamude pogledal pa opažam, da nisem edini razočaran nad tretjo sezono.
Tretji del je bil sicer neobičajen (drugi karakter v ospredju dogajanja) a še kar dober, nasplošno pa je vse skupaj zelo predvidljivo in prisiljeno postalo. Res izrazit občutek, da štancajo vsebino, ki je sama sebi namen (ker je serija pač dobila following). Sploh po četrti epizodi me je kar minilo, da bi še kak del pogledal.
- spremenil: ripmork ()
globoko grlo ::
Nej mi en razloži kako lahko en sam samcat Mando razfuka pač vse kar obstaja, ena vojska "mandotov" pa kumi ene pirate razhajka?
globoko grlo je izjavil:
Teme se reče main character.
Nikec3 ::
OK epizoda. Serija postaja ujetnik svojega glavnega junaka. Zadnje epizode so nakazale, da zna bit tale "Andorijski" politični del serije bolj zanimiv od glavnega plota vezanega na Mandota in Grogu-ta.
@WarpedOne o Elonu Musku:
Ena skupina Mandalorijancev je sektašev, druga so pa zgleda naciji
Nikec3 ::
Heh, zelo "campy" epizoda, ampak je nekako pasalo skupaj. Lizzo in Jack Black sta bila perfekten cast za svojo vlogo.
Phantomeye ::
Nekaj govoric
Jon Favreau butting heads with Kathleen Kennedy
Jon Favreau had a falling out with Kathleen Kennedy after Season 2 of The Mandalorian because she tried to get so involved with the show to the point where Jon Favreau almost left the show.
Kathleen Kennedy forced Jon Favreau to do Boba Fett and forced Favreau to make Grogu and Mando reunite, which Jon Favreau did not want to do (explains Season 3?) and says that Favreau was very bummed by the reaction to that.
Pedro Pascal problems with The Mandalorian
Pedro Pascal also had a big blow-up with Disney during Season 2 and that Pedro Pascal is barely on the set for Season 3 which is why the character has been sidelined in favor of Bo-Katan
It's also questioned if Pedro Pascal will be back for The Mandalorian Season 4 or if his character walks away in the Season 3 finale or dies.
https://cosmicbook.news/star-warsrumors...
Ja najboljš, da ubijejo kar glavni lik in bomo potem gledali še nekaj sezon tega lika, brez tega lika
Phantomeye ::
Ajde to bi še šlo nekako skozi
Dave Filoni bo režiral film direktno povezan s TV serijo Mandalorian. Lahko, da bo film celo kot finale TV serije Mandalorian.
ripmork ::
Ugh,... me kar pogreje, ko tole berem. Ker zaenkrat je tretja sezona kar - meh.
BT52 ::
Prva sezona je bila najboljša. (Še zdaleč od objektivno odlične, vendar prikupne lahke zgodbice, kot nek video kolaž) Imeli so potencial, ker je bil povsem samostojen projekt Favroja. Zdaj pa so se prilepile SJW pijavke zraven pa imajo to kar imajo. PROPAD in prodajo Lucasa pred vrati....
- spremenilo: BT52 ()
Mogoče je bila prva sezona najboljša samo je bila pa finalna epizoda druge sezone daleč najboljša epizoda v celotni seriji.
Tretja sezona mi nekako kar ne gre še vedno nisem pogledal 5 in 6 epizode
Executive producer in director Rick Famuyiwa pravi - "I think now with Bo possessing the Darksaber, I know that there was a lot of expectations that might have shifted both in terms of what it meant for Din Djarin, but also for Bo and what does it mean? Who is the Mandalorian at this point? And so I think it could be anyone. And I think that's what they're trying to define in many ways, is what does that mean to be Mandalorian?"
Glede na izjave producenta lahko, da Din Djarin sploh ni več glavni lik TV serije ampak BO Katan.
Sem pogledal 5 in 6 epizodo. Peta piratska epizoda je bil kar dobra. Šesta pa vizualno lepa to je pa tudi vse.
MVP v kakšnem smislu?
Ampak kaj pa naj bi ta vohun kaj takšnega izdal? Ker vse kar so Mandalorijanci naredili, je bilo dokaj odmevno in je moralo domevati širše v galaksiji - premagali pirate, zgodovinski premiki oz. združenje klanov - večino INFO pa ima očitno tista vohunka imperija. Kar še ni bilo razloženo je oz. morda zdaj je, kdo je pomagal rešiti Moffa? Ker najprej zaradi beskarja so najprej vsi pomislili na Mandalorijance, zdaj pa vidimo, da ima tudi Moff enote opremljete v oklepe iz beskarja; torej so ga najbrž oni rešili (ne pa nek Mandalorijanec).
- spremenil: Gregor P ()
Ja večino informacij ima tista vohunka katera je pri New Republic in izdaja za Imperij. Ampak verjetrno mora eden izmed Mandolorjev izdajati vse skupaj.
Dva najbolj očitna naj bi bila Armorer in Axe Woves.
Phantomeye ::
Well.
1. Zakaj je conveniently glih ona poškodovane odpeljala nazaj na ladjo. Glede na to, da je hotla bit v landing party (in ona NIKOLI ne gre na misije). Lahko bi poslali kergakol NPC-ja.
2. Ona je predlagala, da bo-katan zbere vse mandaloriane. Če jih imaš na kupu, jih lahko potolčeš v šusu (če imaš dovolj sredstev).
3. Moffko je dobil sredstva ravno zaradi tega, ker so mandoti se zbrali skupaj. To pomeni, da mu je to sodelovanje med klani v interesu.
4. Sklepam, da za kovanje baskarja rabiš know-how. In ta bejba ima ta know-how, k ga je lahko posredovala Moffu.
5. Namignjeno je bilo, da je od Armorke klan bil del Death Watcha.
Proti argument, ki spodbija moje argumente -> Moff je bil presenečen, ko je izvedel, da sta obe frakciji združili moči.
- spremenilo: Phantomeye ()
Phantomeye ::
Lahko je pa armorer red hearing in so the spies ti mandaloriani ti, ki so ostali na planetu, ker so jih oni peljali direkt do Moffa (in kasneje niso bli prisotni) - to sm prebral na internetu.
V zadnji epizodi so omenjali Grand Admiral Thrawn-a. Mogoče ga pa vidimo v finalni epizodi tretje sezone? Da ga predstavijo preden bo nastopil v TV seriji Ashoka.
8 Biggest Clues In Mandalorian Season 1-3 That The Armorer Is An Imperial Spy
The Armorer's Sect Was Spared In The Mandalorian Purge
The Armorer's Sect Lived On Nevarro - The Same Planet As Moff Gideon
The Armorer Didn't Stop Din Djarin From Working For The Empire
The Armorer Survived The Covert's Destruction - Despite Staying Behind
The Armorer Tested Bo-Katan's Commitment To The Creed - And She Failed
The Armorer Changed Her Mind A Little Too Quickly
The Armorer Led The Mandalorians Into A Trap
The Armorer's Helmet Design Is The Same As Moff Gideon's
https://screenrant.com/the-mandalorian-...
Potolkel je največ sovražnikov in umrl herojske smrti ČEPRAV bi lahko tudi on pobegnilškoda ga je.
Cela scena je bila kr nekaj. Tocno tko, lastorocno je pokosil vecino nasprotnikov. Vsi skupaj pa ne bi mogli se tistih par spucati. Konec koncev niso bili kekci, temvec Mandalorians.
Glup konec...
Preveč predvidljiv in primitivno narejen.
Phantomeye ::
eh, ocitno ne bomo zvedli kdo so bli "spies". Pa Moff je bil očitno nazaja samo zato, da je bil v dveh epizodah...
Han ::
Finale je tak kot cela tretja sezona - povprečen. Moffa lahko po potrebi oživijo, tako kot so Palpatina za deveto epizodo v zadnji trilogiji...
Je pa srečen konec in bolj kot ne zaključen konec. Tako da sploh ni potrebe po 4. sezoni.
Badwolff ::
Men je blo kar ok.
čist so pozabli, da naj bi bil spy.
Mof je overpowered.
pocukran konec, ampak ok.
Res 4. sezone niti ni treba, je tko zaključeno vse.
Mof je overpowered.
Men je samo bedno da so že lani premagali Gideona, kao. In potem to sezono jovo na novo, spet isti bad guy. Pa še rabiš gledati Book of Bobba Fett, ker so zadnji trije deli dejansko samo Mandalorian.
Ja sam klon naj bi že imel silo, ta je pa imel samo motoriziran oklep.
Badwolff ::
Ko si izmisliš dobrega negativca, ga ne ubiješ kar tako, ga je lažje reciklirat, kot naredit novga
Poglej stripe, isti nasprotniki že 80 let, pa nič ne kaže, da ne bodoše naslednjih 80 let.
Raja hoče Jokerja in comp.
Furbo ::
Zanimivo, kako dobi stanovanjce za nagrado model. Točno tako, kot v kaki igri.. hmm..
Kayzon ::
Dokler bojo Disney vodile moderne woke feministke,star wars pac enostavno ne bo za gledat. Se spomnim koliko so vsi pljuvali po drugi trilogiji,sam glede na nove filme in serije ki jih producirajo,je tista trilogija top notch.
ps. - jarjar
ps. - jarjar
- spremenilo: Kayzon ()
Finale tretje sezone mi je bil kar vredu sploh, ker je bila tretja sezona bolj dolgočasna.
Upam, da v 4 sezoni ne bodo spet privlekli Moff Gideona.
Zanimivo, da so kar uničili Dark saber.
Temuera Morrison igralec Boba Fett-a pravi, da je bil izrezan iz finala tretje sezone in, da mu je Din Djarin (Mandalorian) vzel dokaj pomembno vlogo v The Book of Boba Fett.
| » | Star wars - Obi-Wan Kenobi - Serija (strani: 1 2 3 4 5 )Oddelek: Sedem umetnosti | 58262 (9498) | SmeskoSnezak |
| » | Star Wars: Cassian Andor (2021) - TV serija (strani: 1 2 3 4 )Oddelek: Sedem umetnosti | 34346 (7889) | oo7 |
| » | Star Wars Acolyte - TV serija (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Sedem umetnosti | 58174 (36036) | Mato989 |
| » | Star Wars : Boba Fett (2020) (strani: 1 2 )Oddelek: Sedem umetnosti | 16482 (8885) | oo7 |
