Forum » Strojna oprema » HDD napake - uveljavitev garancije?
bijoloh ::
Pozdravljeni,
potrebujem mnenje glede HDD-ja.
Imam HDD, ki je še pol leta v garanciji, zadnje čase pa sta se pri pregledu s smartmontools pojavili 2 napaki - prva pred približno mesecem in pol, druga včeraj. Sicer overall-health status napiše PASSED, ampak me zanima vaše mnenje ali bi lahko za to že uveljavil garancijo? Predvsem bi nebi rad, da bo disk kar "čez noč" mrknil in bom ostal brez diska...
Spodaj je izpis preizkusa z napakami:
Hvala za vaša mnenja!
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.10.0-327.28.2.el7.x86_64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 3.5" HDD DT01ACA...
Device Model: TOSHIBA DT01ACA100
Serial Number: xxxxxxxxxxx
LU WWN Device Id: xxxxxxxxxxx
Firmware Version: MS2OA750
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Aug 7 17:01:48 2016 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x85) Offline data collection activity
was aborted by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 7022) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 117) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 141 141 054 Pre-fail Offline - 72
3 Spin_Up_Time 0x0007 100 100 024 Pre-fail Always - 188
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 6
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 115 115 020 Pre-fail Offline - 34
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 12829
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 6
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 17
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 17
194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 18/37)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2 occurred at disk power-on lifetime: 12815 hours (533 days + 23 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 38 48 1f b9 0c Error: UNC at LBA = 0x0cb91f48 = 213458760
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 80 50 00 2e b9 40 08 01:50:58.626 READ FPDMA QUEUED
60 80 48 80 2d b9 40 08 01:50:58.626 READ FPDMA QUEUED
60 80 40 00 2d b9 40 08 01:50:58.626 READ FPDMA QUEUED
60 80 38 80 2c b9 40 08 01:50:58.625 READ FPDMA QUEUED
60 80 30 00 2c b9 40 08 01:50:58.625 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 11303 hours (470 days + 23 hours)
60 00 b8 80 23 b9 40 08 2d+18:08:51.819 READ FPDMA QUEUED
60 00 b0 80 1f b9 40 08 2d+18:08:51.816 READ FPDMA QUEUED
60 00 a8 80 1b b9 40 08 2d+18:08:51.813 READ FPDMA QUEUED
60 80 a0 00 18 b9 40 08 2d+18:08:51.787 READ FPDMA QUEUED
60 00 98 00 14 b9 40 08 2d+18:08:51.786 READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 12826 -
# 2 Short offline Completed without error 00% 12823 -
# 3 Extended offline Completed without error 00% 11320 -
# 4 Short offline Completed without error 00% 11317 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Han ::
Dokler disk prestane teste, uveljavljanje garancije nima smisla, ker ne boš nič dosegel. Preglej ga še s kakšnim drugim programom, npr. Toshibinim in Seagatovim (Seatools).
bijoloh ::
Sem poskušal poiskati na Toshibini spletni strani kak program za testiranje diskov in pod FAQ piše:
Podpora na višku
Bom poskušal še s Seatools in WD Data Lifeguard Diagnostic programom, če bo prepoznalo disk.
Toshiba does not provide any diagnosis tool for HDD for personal users.
Podpora na višku
bijoloh ::
solatko ::
Na strani proizvajalca pogledaš do kdaj je garancija in z njihovim orodjem preveriš disk. Če je test negativen, dobiš kodo in navodila za reklamacijo.
To odneseš tja, kjer si kupil ali pa sam pošlješ v zamenjavo.
Delo krepa človeka
bijoloh ::
Sliši se preprosto, ampak ko se stvari lotiš se lahko precej zaplete
Grem na Toshiba.si, prijadram do strani za podporo in registracijo naprave. Vnesem serijsko, datum nakupa in državo nakupa in napiše, da serijska št. ni veljavna. Poskusim še enkrat, isto - serijska ni veljavna. Potem poskušam kombinacijo, da vnašam črke kot male tiskane, kot velike tiskane, zmeraj ista napaka - serijska ni veljavna. Ker imam še en disk od Toshibe (isti model) poskusim še s serijsko št. tega drugega diska in spet ista napaka. Potem poskusim še preko domene toshiba.eu in spet ista zadeva
Potem pišem kar na email slovenske firme, ki je navedena za garancijo (kjer jim razložim situacijo). Pohvalno sem takoj dobil odgovor, da naj jim prinesem disk, da ga bodo oni testirali, da bodo videli za kaj se gre.
Vmes sem zagnal Hirens boot CD in zagnal WD Data LifeGuard Diagnostic, ki je prepoznal v sistemu tako Seagatove, kot Toshibine diske. Na problematičnem Toshibinem disku zaženem najprej quick test, ki prestane preizkus (PASSED), potem pa še extended, ki pa napiše, da je našel bad sektorje, ter mi ponudi možnost popravila. Ker nisem siguren, ali je pametno s programom od WD "popravljati" bad sektorje od Toshibinega diska, sem zaenkrat pustil pri miru. Še poročilo od testiranja:
Test Option: QUICK TEST Model Number: TOSHIBA DT01ACA100 Unit Serial Number: xxxxxxxx Firmware Number: MS2OA750 Capacity: 1000.20 GB SMART Status: PASS Test Result: PASS Test Time: 12:37:35, August 09, 2016 Test Option: EXTENDED TEST Model Number: TOSHIBA DT01ACA100 Unit Serial Number: xxxxxxxx Firmware Number: MS2OA750 Capacity: 1000.20 GB SMART Status: PASS Test Result: FAIL Test Error Code: 08- Test Time: 14:25:58, August 09, 2016
Potem znova zaženem sistem (Linux) in še enkrat pregledam disk s smartmoontools, kjer mi javlja, da je sedaj že 11 odkritih napak...
Zdaj sem v dvomu kaj narediti - ali z WD Data LifeGuard Diagnostic "popraviti" bad sektorje ali poslati slovenski firmi v garancijo? Predvsem drugo se mi zdi, da bodo oni naredili enako kot bi lahko jaz - s programsko opremo "popravili" bad sektorje in mi vrnili disk "popravljen" nazaj.
Ima kdo kakšne konkretne izkušnje, kakšna je praksa, če se ti pojavijo bad sektorji na disku v garanciji - ti zamenjajo disk z novim ali ti ga "popravijo"?
Han ::
Dokler ga lahko, ga popravljajo, potem ga menjajo z novim ali obnovljenim (refurbished). Slabi sektorji se pri 'popravilu' dejansko izločijo iz uporabe. Nadomestijo jih dobri iz rezerve. Ko rezerve zmanjka, dobiš drug disk...
Seatools tudi vidi slabe sektorje?
Kaj pravi CrystalDiskInfo?
- spremenil: Han ()
IMHO ne, ker slabi sektorji so pri klasičnih diskih nekaj povsem vsakdanjega in jih vsebuje skoraj vsak disk. Vsak disk ima zato tudi nekaj rezervnih sektorjev, ki jih uporabi, kadar zazna slabe (jih premapira). Problem slabega sektorja je v tem, da so podatki, ki se iz njega preberejo, napačni. Zato disk sam od sebe ne more premapirati slabih sektorjev, saj ne ve, kaj storiti z napačnimi podatki. To lahko stori samo aplikacija, ki te podatke uporablja. Taki sektorji so v smart označeni s "pending". Druga pesem pa je, kadar v slab sektor nekaj zapišeš. V tem primeru pa disk pozna "zdravo" vsebino, zato lahko vsebino slabega sektorja zavrže (itak je prišel ukaz za njen prepis) in naredi premapiranje. Zdravilo za slabe sektorje je torej njihov prepis. Najenostavneje je shraniti vsebino in prepisati celoten disk, lahko pa izračunaš, kateri blok na particiji moraš prepisati.
solatko ::
kamikaze5 - Slab sektor na mestu, kjer sistem zapiše neprenosljivo datoteko, je razlog za menjavo diska. Na Sony-evem prenosniku je bil od 1TB pokvarjen samo en sektor, smart je šel normalno skozi, so takoj zamenjali disk, ker se sistem enostavno ni dalo zagnati, pa tudi factorydefault zaradi tega sektorja ni deloval.
Po drugi strani pa imaš diske, ki imajo v smartu 3 ali več rumene trikotnike, pa so še vedno b.p..
Delo krepa človeka
filip007 ::
Daj slikco od HD Tune pod "Health", da bomo videli za kakšno napako gre.
Zero games, zero talk.
bijoloh ::
Torej, da odgovorim lepo po vrsti.
CrystalDisk nisem pognal, ker na Hirens Boot CD se pritožuje, da rabi neke datoteke od Internet Explorer-ja, ki naj jih prekopiram in potem registriram - se mi ni ljubilo ukvarjat s tem
Začel sem s HD Tune, ki kaže naslednje:
Nato sem zagnal še en program - Victoria, ki kaže sledeče:
Ter še Seatools 2.23 za DOS. Short test je javil kot PASSED:
Nato sem šel še Long test, ki pa je pri 29% zmrznil - lučka na ohišju za indikacijo aktivnosti diska je bila ugasnjena, tudi slišati ni bilo, da bi katerikoli od diskov kaj "mlel". V zgornjem delu zaslona od programa Seatools so se pojavili čudni znaki zelene barve... poskušal sem z ukazom Alt-R za prekinitev testa in vse kar je naredilo je bilo to, da je začel sistemski zvočnik neprekinjeno piskati. Edina rešitev je bil gumb za hard reset sistema:
Potem zaženem znova Hirens Boot CD in sem si rekel, da bom zagnal še enkrat WD Data LifeGuard Diagnostics in poskušal zagnati "popravilo" bad sektorjev v tem programu - začuda oba testa prestane kot PASSED
Nato zaženem še HD Tune:
ter Victoria HD test:
In ker mi ni dalo miru kaj se dogaja, še enkrat zaženem Seatools 2.23 za DOS, kjer oba testa - short in long - gresta skozi brez problemov kot PASSED
Nazadnje zaženem sistem normalno (linux), in pogledam še s smartmontools, ki pa še vedno kaže PASSED ampak sedaj 18 napak:
Če na kratko povzamem - vsakič, potem ko sem zagnal WD toolse za testiranje diska, mi smartmontools poveča število napak za 7. Po tem, ko je Seatools zamrznil, mi tako WD DLG kot Seatools oba pokažeta long in short teste kot PASSED!
Razumem zmeraj manj
Local Time is: Thu Aug 11 08:09:43 2016 CEST
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
command.
power-saving mode.
2 Throughput_Performance 0x0005 142 142 054 Pre-fail Offline - 69
8 Seek_Time_Performance 0x0005 113 113 020 Pre-fail Offline - 35
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 12916
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 19
194 Temperature_Celsius 0x0002 222 222 000 Old_age Always - 27 (Min/Max 18/37)
ATA Error Count: 18 (device log contains only the most recent five errors)
Error 18 occurred at disk power-on lifetime: 12904 hours (537 days + 16 hours)
40 51 00 4e 1f b9 0c Error: UNC at LBA = 0x0cb91f4e = 213458766
42 d0 00 4e 1f b9 e0 00 3d+18:47:58.536 READ VERIFY SECTOR(S) EXT
42 d0 00 4d 1f b9 e0 00 3d+18:47:54.719 READ VERIFY SECTOR(S) EXT
42 d0 00 4c 1f b9 e0 00 3d+18:47:50.901 READ VERIFY SECTOR(S) EXT
42 d0 00 4b 1f b9 e0 00 3d+18:47:47.083 READ VERIFY SECTOR(S) EXT
42 d0 00 4a 1f b9 e0 00 3d+18:47:43.265 READ VERIFY SECTOR(S) EXT
Error 17 occurred at disk power-on lifetime: 12904 hours (537 days + 16 hours)
40 51 00 4d 1f b9 0c Error: UNC at LBA = 0x0cb91f4d = 213458765
42 d0 00 49 1f b9 e0 00 3d+18:47:39.447 READ VERIFY SECTOR(S) EXT
Error 16 occurred at disk power-on lifetime: 12904 hours (537 days + 16 hours)
40 51 00 4c 1f b9 0c Error: UNC at LBA = 0x0cb91f4c = 213458764
42 d0 00 00 18 b9 e0 00 3d+18:47:35.642 READ VERIFY SECTOR(S) EXT
Error 15 occurred at disk power-on lifetime: 12904 hours (537 days + 16 hours)
40 51 00 4b 1f b9 0c Error: UNC at LBA = 0x0cb91f4b = 213458763
42 d0 00 00 10 b9 e0 00 3d+18:47:35.632 READ VERIFY SECTOR(S) EXT
Error 14 occurred at disk power-on lifetime: 12904 hours (537 days + 16 hours)
40 51 00 4a 1f b9 0c Error: UNC at LBA = 0x0cb91f4a = 213458762
42 d0 00 00 08 b9 e0 00 3d+18:47:35.628 READ VERIFY SECTOR(S) EXT
# 1 Short offline Completed without error 00% 12909 -
# 2 Short offline Completed without error 00% 12907 -
# 3 Short offline Completed without error 00% 12907 -
# 4 Short offline Completed without error 00% 12905 -
# 5 Short offline Completed without error 00% 12904 -
# 6 Short offline Completed without error 00% 12874 -
# 7 Extended offline Completed without error 00% 12826 -
# 8 Short offline Completed without error 00% 12823 -
# 9 Extended offline Completed without error 00% 11320 -
#10 Short offline Completed without error 00% 11317 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Razumem zmeraj manj
- spremenil: bijoloh ()
bijoloh ::
Moram popraviti moj povzetek
- vsakič, potem ko sem zagnal WD toolse za testiranje diska, mi smartmontools prikaže povečano število napak - prvič za 9, drugič za 7. Po tem, ko je Seatools zamrznil, mi tako WD DLG kot Seatools oba pokažeta long in short teste kot PASSED!
filip007 ::
Boš popravil slikce, očitno si pozabil dati na "share".
bijoloh ::
Se opravičujem za slikce, jih nisem pozabil dati pod "share", ampak ima dropbox neko omejitev za dnevni ogled in se je očitno prekoračila
Tukaj so na drugi strani naložene slikce:
Potem zaženem znova Hirens Boot CD in sem si rekel, da bom zagnal še enkrat WD Data LifeGuard Diagnostics in poskušal zagnati "popravilo" bad sektorjev v tem programu - začuda oba testa prestane kot PASSED 8-O:
In ker mi ni dalo miru kaj se dogaja, še enkrat zaženem Seatools 2.23 za DOS, kjer oba testa - short in long - gresta skozi brez problemov kot PASSED 8-O:
Upam, da so sedaj slikce vidne!
filip007 ::
Jaz ne vidim nič čudnega, lahko pa probaš še z Linux Mint 18 s programom za formatiranje in tam izbereš Smart in lahko disk dodatno testiraš.
Spajky ::
Čisto možno, da z diskom ni nič narobe, je pa s kabli, verjetno tudi z napajalnim delom, ali pa je kak kondenzator na matični slab; možnost je tudi bugast driver za disk ...
bijoloh ::
Driver bi jaz kar izključil, ker sta v sistemu dva ista diska in za drugega ne kaže, da bi bilo kaj narobe.
Kabli - ne vem mogoče, čeprav za podatkovni kabel se mi zdi malo verjetno, ker ni bil taknjen odkar so bili diski vgrajeni. Mogoče od napajanja, da se je napajalnik kaj "skuril"?
Kondenzatorji na plošči - bom preveril za vsak slučaj.
Mene pri vsem tem še najbolj moti to, da ko sem prvič zagnam WD DLG je po extensive preverjanju javil, da je našel slabe sektorje (ki jih takrat nisem poskušal "popraviti" s ponujeno opcijo, ker sem želel še prej s Seatools preveriti), potem Seatools po prvikratnem long preverjanju zmrzne pri 29%, ampak do takrat tudi izpiše, da je našel 7 napak (glej slikico). Po tem ko je Seatools zamrznil in sem naredil hard reset pa oba programa kažeta vse OK, edino števec napak pri smartmontools se je povečal...
| » | linux + dm-crypt luks težave z odklepom particije ob bootuOddelek: Operacijski sistemi | 1380 (1139) | gendale2018 |
| » | a mi je crknu disk al neOddelek: Strojna oprema | 2032 (1473) | filip007 |
| » | Po 2 PB zapisanih podatkov tretjina SSD-jev še deluje (strani: 1 2 )Oddelek: Novice / Diski | 34943 (28817) | Laybach |
| » | Disk umiraOddelek: Strojna oprema | 2076 (1361) | Ramon dekers |
| » | [Linux - Grub] OS se mi noče naložitiOddelek: Operacijski sistemi | 1920 (1635) | kriko1 |
