Forum » Strojna oprema » Disk umira
Disk umira
WildChild ::
DELL inspiron 6400:
Kar mi je dalo misliti. Predvsem branje je zelo počasno. Zategadelj sem preveril še za napake v sektorjih z smartctl -l error /dev/sda ukazom:
Očitno so napake na določenih sektorjih. Sedaj pa imam še garancijo. Sem k sreči vzel dodatnih +3 kar nanese vsega skup 5let garancije. Samo me nekaj zanima glede garancije. A oni to vzamejo na podlagi parih vrstic izpisa, da se diskom izteka doba?
/dev/sda:
Timing cached reads: 2178 MB in 2.00 seconds = 1089.81 MB/sec
Timing buffered disk reads: 104 MB in 3.02 seconds = 34.48 MB/sec
smartctl 5.40 2010-10-16 r3189 [i686-pc-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
ATA Error Count: 352 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 352 occurred at disk power-on lifetime: 13152 hours (548 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 02 f3 fd df ed Error: UNC 2 sectors at LBA = 0x0ddffdf3 = 232783347
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 ed fd df ed 00 04:23:51.719 READ DMA
27 00 00 00 00 00 e0 00 04:23:51.718 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 04:23:51.711 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 04:23:51.705 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 04:23:51.705 READ NATIVE MAX ADDRESS EXT
Error 351 occurred at disk power-on lifetime: 13152 hours (548 days + 0 hours)
c8 00 08 ed fd df ed 00 04:23:44.975 READ DMA
27 00 00 00 00 00 e0 00 04:23:44.975 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 04:23:44.968 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 04:23:44.962 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 04:23:44.962 READ NATIVE MAX ADDRESS EXT
Error 350 occurred at disk power-on lifetime: 13152 hours (548 days + 0 hours)
c8 00 08 ed fd df ed 00 04:23:38.262 READ DMA
27 00 00 00 00 00 e0 00 04:23:38.262 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 04:23:38.255 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 04:23:38.249 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 04:23:38.248 READ NATIVE MAX ADDRESS EXT
Error 349 occurred at disk power-on lifetime: 13152 hours (548 days + 0 hours)
c8 00 08 ed fd df ed 00 04:23:31.529 READ DMA
27 00 00 00 00 00 e0 00 04:23:31.529 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 04:23:31.522 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 04:23:31.516 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 04:23:31.515 READ NATIVE MAX ADDRESS EXT
Error 348 occurred at disk power-on lifetime: 13152 hours (548 days + 0 hours)
c8 00 08 ed fd df ed 00 04:23:24.786 READ DMA
27 00 00 00 00 00 e0 00 04:23:24.785 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 04:23:24.778 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 04:23:24.772 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 04:23:24.772 READ NATIVE MAX ADDRESS EXT
in da mood
Pyr0Beast ::
Testiraj s proizvajalčevim programom.
WildChild ::
Garancijo imam 5let vsega skupaj. Mene zanima, če lahko dokažem z programjem, da mi disk umira? Ali mora dejansko bit mrtev?
in da mood
dejansan ::
kot ti je že Pyr0Beast omenil poglej kateri disk imaš in testiraj s proizvajalćevim programom nato pa report sprintaj, do sedaj mi še niso nikoli komplicirali
kar se tiče garancije, če si imel od proizvajalca 2 leti in si dokupil +3 to ne pomeni da imaš skupaj 5 let, temveč imaš 3 leta garancije
dejansan
WildChild ::
Garancija Plus 5+ (vrednost izdelka do 1000EUR)
101,00 EUR
Zgleda da sem dokupil na že 2leti garancijo 5+ tako, da je še v veljavi :) Sam najt jo morm...
101,00 EUR
in da mood
WildChild ::
Gre se za disk: MK1234GSX: 2.5" HDD 120GB* Na PROIZVAJALČEVI strani Sem prenesel ZIPfjdtwin.exe [464KB] Vendar je nekako samo za Visto (zadnja najbližja verzija windows 7). Sem z desno kliknil na .exe in dal properties in compatibility in označil tam najprej XP SP 3, nato Vista. In nato kliknil, ok in pognal program kot administrator, vendar ko se mi orodje odpre ne morem označiti diska :S In posledično ne morem opraviti testa. Zakaj Linux test o napakah nebi bil primeren, če proizvajalec ne posodablja svojih orodij?
Oz obstaja še kje kako orodje za toshibo trde diske in je kompatibilno z windows 7?
in da mood
filip007 ::
Daj slikco od HDTune Health, da se bo bolj videlo pri čem smo...
Zero games, zero talk.
WildChild ::
Error Scan se pa zele izvaja pa ga prlimam. Nekam nizke hitrosti :(
Aja pa opazil sem, da je zadnje 3 tedne temperatura CPU ja precej viska, tam okrog 50C. To v Linuxu, pa sedaj vidim, da je na Windowsih enako... Sm razdru laptop, pa spucal ventilatorje. sam ni nic pomagalo. Je mozno, da se je po 3 letih spustila termalna masa? Al pa kaka druga finta?
in da mood
WildChild ::
Error Scan ni nic pokazal, da bi blo kaj narobe. Vse zeleno, test je pa trajal 1:14min, Scanning speed 18.6MB/s
Kako zanesljivi so ti HDTune skenerji? Pod Linuxom nism naredil dolgega testa...
in da mood
filip007 ::
A si prepričan, da nimaš kakšen spyware gor, ker izgleda OK, pa še kakšen CCleaner sprobaj, mogoče je samo zafilan.
WildChild ::
Nimam nobene nesnage...
Disk pa tudi ni zafilan. Placa je še 1.5GB... (windows 7 Professional, 32bit)
in da mood
filip007 ::
Žal premalo prostega prostora ali pa naloži kakšen Jolicloud.
WildChild ::
sam to je pa res bedno.. zakaj mi pise 1.5gb frej ce pa dejansko ne morem koristit teh 1.5gb.. ah ja..
in da mood
filip007 ::
Polkna delajo super, če je vsaj 90GB+ frej pol letijo vse ostalo je mletje in mletje in ja polkna rabijo swap plac za RAM z diska dol.
Ramon dekers ::
da ne odpiram nove teme, bom pisal kar tukaj.
Rabim nujno pomoč, disk mi je že kar nekajkrat sam od sebe ugasnil, enostavno se je zaslišalo da se je ustavil in ni več mlel, takrat je računalnik zablokiral. Po resetu je delal ok, mogoče 3 -4 mesece in potem ponovil napako...
Sedaj pa je problem sledeč na disku imam nekaj uporabnih podatkov, in bi jih rad spravil iz njega, vendar me ne spusti v winse, niti v safe mode, ko hoče priti notri se mi resetira cela kišta. Glavne podatke sem načeloma shranjeval na drugi disk, ampak zadnje delo oz. nalogo ki je kar precej obsežna sem pozabil prenesti.
je sploh kakšna varianta da pridem še v winse in shranim kam zadeve??
Ramon dekers ::
HJA sedaj pa je problem kako to skopirati, notri sem, samo kaj ko linux ne pozna usb ključa (imam 08 verzijo) da pa bi kopiral na dvd pa ne gre ker je cd notri. Kakšna rešeitev je še možna?
Pyr0Beast ::
Nimaš druge. Plačati moraš 100€ za različico linuxa 10.10 ...
Potegni iz neta vraga no, saj je zastonj :)
Ramon dekers ::
heh že zrihtal z linuxom mi je zaznal drug usb ključek. Me pa zanima kako hudiča linux lahko požene zadevo pri winsih se pa sliši kako se plošče dobesedno ustavijo. MI lahko kdo obrazloži ta fenomen?!
Pyr0Beast ::
It is the miracle of linux ! :))
- spremenil: Pyr0Beast ()
Ramon dekers ::
lepo prosim za konkreten odgovor! Ce nalozim linux bi sigurno prislo do enakega efekta. Moje mnenje je da lin manj obremeni disk!
Pyr0Beast ::
Ej. Ne vem. Sprobaj :)
Windows lahko izvede 'varno' zaustavitev, če posumi da je nekaj narobe s sistemom.
amigo_no1 ::
Live linux se zažene s cd*ja, winsi z diska, ki je kot kaže na določenih delih poškodovan, zato se ne naložijo do konca.
Da si lahko skopiral kar si pač prej pozabil je zgolj krompir (da disk ni poškodovan na sektorjih) kjer se nahajo pozabljeni podatki.
Lahko bi uporabil tudi WinPE ali prestavil disk v drug pc kot dodaten disk in bi verjetno tudi skopiralo.
- spremenilo: amigo_no1 ()
Ramon dekers ::
ne bi ker diska ne zazna oz ce dam poskodovan disk kot slave mi zatrokira na drugem kompu pride na zacetek in to je to. Drugace pa najlepsa hvala za odgovore! Sem poskusil vse varianta ampak dela samo z linux.
Pyr0Beast ::
Windowsi so včasih zelo izbirčni pri zaznavi strojne opreme in napakah povezanih z njo. Potegni dol DBAN in anuliraj vse podatke na disku. Nato na novo postavi particije in probaj gor namestiti linux.
Daedalus ::
Zgolj dobronamerni nasvet - ko začne disk odpovedovat, prvo narediš dober backup, potem nabaviš drug disk in gor obnoviš sistem. Šele potem pa mučiš star disk, da dokončno odpove in ga lahko brez težave reklamiraš. Če mučiš že itak utrujen disk in nisi prej naredil prej opisanih korakov, pol res prosiš za težave in stokanje ob kr konkretni verjetnosti, da gre disk s podatki adijo.
[J.P.Sartre]
[J.P.Sartre]
Ramon dekers ::
vem, sem naredil, backup, samo ena naloga je ostalo tam. Disk je star 8 let, se pa slisi kako se ustavi, in zatrokera. Hvala za nasvet
| » | HDD napake - uveljavitev garancije?Oddelek: Strojna oprema | 4317 (3556) | bijoloh |
| » | počasno delovanje kompa Asus N76VZOddelek: Pomoč in nasveti | 1617 (1445) | WIngs |
| » | BSOD me spravlja v obupOddelek: Strojna oprema | 2326 (1798) | rsroki |
| » | BSOD problemOddelek: Pomoč in nasveti | 2229 (1887) | Oktan |
| » | [Linux - Grub] OS se mi noče naložitiOddelek: Operacijski sistemi | 1936 (1651) | kriko1 |
