Kloniranje tablice
Kloniranje tablice
Cervantes ::
Imam dve tablici GT P5110 in sem odločil, da bom naredil na drugi klon prve.
Po brskanju po raznih forumih sem uporabil TWRP za backup na prvi, in ga skopral na drugo.
TWRP na tadrugi ga sploh ne vidi.
Kaj delam narobe?
AC_DC ::
http://forum.xda-developers.com/showthr...
V teoriji:
prva tablica: TWRP backup na sdkartico, nato prestaviš kartico na drugo tablici in restore.
  • spremenilo: AC_DC ()
Cervantes ::
TWRP po defaultu spravi backup v /sdcard/TWRP/BACKUP in se mu ne da dopovedat, naj to spravi kam drugam.
To je notranja sd kartica in bi moral razdret tabilci, kar pa jaz nerad počnem, ker ponavadi vse polomim.8-O
AC_DC ::
Lokacije TWRP backupa se ne da spremeniti ?
Kako misliš potem prestavljati backup na drugo tablico brez sdkartice ?
Cervantes ::
Skopiram na PC s prve, nato s PCa na drugo v isti direktorij.
Mare2 ::
Kaj pa Easeus? :)
Cervantes ::
Easeus za Android?
Bom pogledal.
twrp gleda id naprave, tako da če skopiraš backup iz ene tablice na drugo, ga druga brez igračkanja nebo sprejela
Cervantes ::
Kakšen namig?
TWRP bases backups and restores on serial number in a couple places. I've only done this from same phone to other of the same phones I've gotten of the same model (e.g. S3 to S3, HTC One 32GB to HTC One 64GB). Not sure how it would work from different model to different model - spose it depends on what you are restoring., model, rom, etc.
TWRP backup directory is sdcard/TWRP/BACKUPS/[SerialNumberOfDevice]/[timeStampOfBackup]/
Change the directory name to the serial number of the new device you want to restore to. Then, go to /[timeStampOfBackup]/recovery.log and do a find/replace on all of the old serial number with the new serial number - I believe there are 8 or 9 instances.
If you change the directory name from w/in TWRP recovery console, reboot - then it'll show up as a recovery option... though, you'll need to update the log file another way -if it's on an sdcard (vs. an HTC One where there is no true sdcard) neither should be a problem.
cheers
Cervantes ::
Mare2 je izjavil:
Kaj pa Easeus? :)
Ne zajebavat, amigo. Seriously.
Cervantes ::
iloveboobz je izjavil:
cheers
Ja, so namigi.
Ampak nimam HTCone.
Cervantes ::
No, mislim da sem zadevo zdaj dokončno zayebal.
Dela mi samo še Restore in Download (Power + Volume Up).
Al obstaja še kakšna možna rešitev ali pač Shit Happens?
BTW, Odin tablico vidi.
A bi se dal s tem kaj pomagat?
bobby ::
Ce odin tablico visi, pol je ok.
Iz samfirmware.com potegni dol rom pa ga namesti preko Odin-a pa je.
Zjebal si recovery in system, emergency ti pa dela ok
Cervantes ::
Zanimiva zadeva.
Sem hotel DL for free, pa se ni zgodilo nič.
Potem sem se upgradal za 15€, pa se spet ni zgodilo nič, no download.
Razmišljam, da bi tudi sam odprl takšno spletno stran.
Goddamned motherfuckers??
http://www.sammobile.com/firmwares/down...
meni sledeči link dela BP, sam adblocker je treba izklopit.
Ja, so namigi.
Ampak nimam HTCone.
Nima veze.
Cervantes ::
No, skoraj bi uspelo...
Ampak zdaj imam pa tole:
"Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again."
Kies tablice sploh ne prepozna.Tablice sploh ne morem več ugasniti, vedno me zabriše nazaj na zgoraj omenjeni screen.
Brick?
BTW, tudi Odin je več ne vidi...
Cervantes ::
Zdaj mi je uspelo preko odina ponovno rutati tablico in lahko pridem v download in restore, ki pa nima kaj restorat.
PC tablice ne vidi (Explorer), tako da ne morem gor nič skopirat.
Tudi Kies ne vzpostavi komunikacije.
Ali lahko naredim restore iz microsd kartice?
Na xda ne najdem nič približno takega.
Urejeno.
Nič se trudit!:D
Flashanje Xiaomi naprav (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Mobilne tehnologije
496126520 (42936) _ssd_sata
Galaxy S6(G920F) No OS Installed!
92393 (2075) nooby
Custom ROM instalacija
102228 (2053) printer
cyanogen boot za S Note 1
Oddelek: Operacijski sistemi
61203 (1062) ezikielrage
Dual-boot Android
121399 (1168) bobby
