Težave z HP OfficeJet 8610
dajoker ::
Pri zamenjavi kartuše je tiskalnik potisnil glavo do konca v desno in na zaslonu javil "Cartridge problem - one or more cartridges appear to be damaged. Remove them and replace with new cartridges."
Fora je v tem, da se glava ne pripelje več na sredino, da bi jih menjal, ampak je vse skup obstalo, na zaslončku pa ponudi samo možnost animacije kako naj bi izgledala zamenjava.
Lahko kaj sam storim, ali je potrebno zadevo nesti na servis?
"Hacker" is a term of honour and respect. It is a term that describes
a skill, not an activity. K. Mitnick
Mravlek ::
Našel sem to če ti kaj pomaga.
http://www.webcartucho.com/blog/15-como...
Prevedi si s prevajalnikom, razen če ti španščina ni tuja :)
This printer model has a hidden support menu where you can access various services troubleshooting for use whenever our present unusual symptoms printer. To access this menu it is necessary:
Turn off the printer
Wait 10 seconds before turning it back on.
As the printer is turned ON, press the back button (arrow icon) on the front panel of the printer "4 times".
V čem je bistvo življenja? Ups...bistvo računalnika! To je zdaj vprašanje?
Tiskalnik Canon MG2150 megleno tiska
192728 (2394) francek1
Računalnik ne najde tiskalnika
102723 (2632) Miro-Slav
Nakup tiskalnika
184517 (4015) mat xxl
nujna pomoč - problem s tiskalnikom
61221 (1152) Highlag
HPjevi inkjeti so crap...
393214 (2597) Brane2
