Forum » Strojna oprema » omejitev velikosti HDD pri zunanjih ohišjih
kuglvinkl ::
Ko npr. proizvajalec navaja up to 2TB, kaj se zgodi, če daš notri večji disk, prepozna samo 2 TB ali sploh nič? V čem je sploh finta, v SATA to USB prevtovrniku?
To answer the subject line, USB's limit is the limit of its mass-storage class (MSC) spec. This spec is in turn based on the SCSI transparent command set. (See also USB mass storage device class @ Wikipedia. Looking at the SCSI read commands (SCSI Read Commands @ Wikipedia you can see that there are several versions of the API. The oldest supports 21-bit block addresses (and a 1GB limit), a later version supports 32-bit LBAs (imposing the 2TB limit many cases have today), and the latest has a 64-bit LBA which will impose an 8ZB limit (that's 8 giga-terabytes!).
Modern USB cases will support 64-bit LBAs and should support any drive you're likely to find. Older cases won't support this and will misbehave if they are attached to a drive larger than 2TB.
http://superuser.com/questions/308492/i...
kuglvinkl ::
Thnx :). Samo kako vedet, najbrž sortirat po letu izdelave.
| » | UEFI - kako ponovno namestiti windows 8Oddelek: Pomoč in nasveti | 12554 (10068) | krepki |
| » | Ali je pol HDD-ja umrlo ?Oddelek: Pomoč in nasveti | 7433 (6529) | opeter |
| » | Asus WL500gP, dd-wrt, printer and disk sharingOddelek: Omrežja in internet | 7326 (3730) | coyotee |
| » | Vedno dovolj prostora - 16GB microSDHC karticeOddelek: Novice / --Nerazporejeno-- | 7114 (4785) | MrStein |
| » | Linux na SCSI diskihOddelek: Operacijski sistemi | 1935 (1711) | civic_ |
