Program za iskanje določenega dela slike v drugih slikah
zzizek ::
Imam sliko, katere določen del ima pomembnost, ki jo želim najti tudi pri ostalih slikah. Se pravi en del slike želim poiskati tudi na ostalih slikah. Ostale slike so vse zelo podobne, tako da sama podobnost je nekje 80% pri vseh slikah, ampak jaz iščem tisti določen del, ki mora obstajat na drugi sliki, da je to, to, kar iščem.
Iščem nekoga, ki je ziher, da se točno to da delati v določenem programu, in bi mi zaupal ime le-tega.
LP,
Zvonko
zzizek ::
Našel sem en obetaven odgovor.
"What you are looking for is called "content based image search" software. I only know of one free tool that does this, imgseek. http://www.imgseek.net/ the download for windows is found here http://sourceforge.net/projects/imgseek...
There is a excellent image management system called DigiKam that has this imgseek built in. I use it on linux and it is very good. DigiKam can be compiled to run on Windows, but it is a bit of a chore. I don't now how stable imgseek is on Windows, but I hope it will work as well as it does on linux. It really is an amazing tool.
Here is another tool http://www.photo-freeware.net/imagesort... with similar technology, but it does not do exactly what you want. It just sorts images by visual similarity. An interesting tool none the less."
zzizek ::
Žal mi ni všeč, ker naredi samo 256 iskanj, jaz pa bi iskal med več tisočimi slikami. Potem bi jih moral razdeliti na mape po 256 ...
Da poenostavim, iščem v bistvu OCR, ki bi iskal sliko za sliko določen tekst v tej sliki, ker se gre samo za iskanje določenega teksta ...
zzizek ::
Noben OCR ne prebere območja, ki bi ga bilo potrebno prebrati.
Ostane mi torej, da bi ga nekako naučil (tu bi verjetno moral že programirati), ali pa, da bi naše nek program, kateremi bi iskal isti del slike v vseh ostalih slikah ...
GTX970 ::
Googlaj "content based image search" in boš našel ostale.
med drugim
List of CBIR engines @ Wikipedia
Content-based image retrieval = CBIR
http://octagon.viitala.eu/
  • spremenilo: GTX970 ()
zzizek ::
Tole zgleda zelo obetavno :)
iskanje slik
Oddelek: Omrežja in internet
82375 (2306) urban99
KDE 4.2.4 (strani: 1 2 )
549379 (7222) vbohinc
[Linux] Program za osnovno obdelavo fotografij
Oddelek: Programska oprema
111562 (1398) BigWhale
Intelovi odprtokodni gonilniki za grafiko (strani: 1 2 )
7810299 (8460) Jst
Kakovostne slike
132386 (2116) Matev
