Forum » Pomoč in nasveti » Win 7 Update KB3033929 fails with error code 80004005
waters ::
Ima še kdo to težavo pri Win 7 64 in kako jo je rešil?
Sicer svetujejo:
1. Open directory where is the file mentioned in the error, in my case: "C:\Windows\WinSxS\amd64_microsoft-windows-b..vironment-os-loader_31bf3856ad364e35_6.1.7601.18741_none_b9293c0383618646\winresume.exe"
2. Right Click on the file > Properties > Security > Advanced > Owner > (Set it to your Account) > OK
3. In previous Window: Edit > Add
4. You need to add two accounts
- "SYSTEM"
- "NT SERVICE\TrustedInstaller"
5. Give them both Read, Write, Execute permissions. > OK
6. Now KB3033929 which is one big nightmare should install without any problems and ask you to restart your computer afterwards.
Ampak jaz nimam dualboot z Linuxom.
Sicer svetujejo:
- "SYSTEM"
GTX970 ::
Kaj ima dualboot opraviti s tem ?
edit, našel:
http://windowsitpro.com/patch-tuesday/p...
Tudi pri meni stanje ne ustreza zgornjim pogojem (w7 x64).
https://social.technet.microsoft.com/Fo...
Ravno updejtal in je šlo skozi bp, trkam na les.
edit, našel:
The issues seems to stem from specific configurations - possibly with systems that dual-boot or that have hard disk partitions that are not enabled. It's still not clear what causes the patch to go haywire or which specific configuration might cause it.
- spremenilo: GTX970 ()
| » | dx11 na xpOddelek: Igre | 4657 (4297) | amigo_no1 |
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5655 (4203) | Gray_Warden_ |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7284 (7143) | ManDriver |
| » | Valve & STEAM & On-Line gaming (strani: 1 2 )Oddelek: Igre | 10023 (8445) | Tilen |
| » | nasvet za XPOddelek: Pomoč in nasveti | 4281 (3873) | [t502] |
