Forum » Igre » S.T.A.L.K.E.R. 2: Heart of Chornobyl
Sem raziskal mislim, da celoten CNPP in naredil še stransko misijo z plačancem Hacket
Sem mislil, da umre v vsakem primeru ampak kot kaže ni temu tako in je odvisno od tvojih prejšnjih odločitev.
AI - Če igrate po poti frakcije Ward (ali če obdržite njihovo značko/badge), to neposredno vpliva na Hatchetovo zgodbo. Če nimate ustreznih dokazov oziroma značke ("Ward Badge"), ki jo pokažete Fesenku v šefovem bunkerju, Hatchet ne dobi svojega "dobrega konca" in v določenih razpletih zgodbe umre zaradi sil ali spopadov, povezanih z Wardom.
Meizu ::
Hoho, jaz sem Zotov.
You are calculating, tactical, and pragmatic, know what you need to achieve and how. You are quite alright as for a Ward, you know when to keep it calm and how to approach those who do not like authority. You know you shouldn't go to someone's house with your rules, but still follow orders, though a bit bended to fit reality.
- spremenil: Meizu ()
Enaplusdva ::
Jst dobim Striderja
You are fighting against gods themselves to make sure your fate is yours. You are not going to be influenced by anyone or anything, you rather die than let anything or anyone to make you do something against your will. You have people under your care and you will sacrifice everything you have to keep them safe. Life was not so kind to you, but you do not care because you still have reasons to fight and live. You beleive in second chances and will do anything to avoid killing. You are a kind person. Follow your instincts
Your Result:
Zulu
You stubborn lil shit with anger issues, how I get ya. You have this blunt, no-nonsense attitude that makes you so lovable. But anger and grief is what burns you and while you are ready to sacrifice everything for your goal, you might forget about others and their choices. You care deeply about people and their lifes, but sometimes you forget to ask if they need saving that you give them. You believe you follow what is right and you will follow it till the end, giving in sacrifices if needed. Please make sure to listen to others, it might not change your opinion but will help you to work out things in a better way. Also, communication is a key, your usability to compromise might get you and your people into big issues.
Predsednik11 ::
To je tisti Vardovec, ki pride v bife na začetku Stalkerja ?
dronyx ::
Ali kdo ve čemu služi območje Jupiter? Če se prav spomnim tam ni nobene misije, niti stranske ne. So samo neke tovarniške hale, ampak ko prideš do tja, si tega videl že veliko. Jaz se spomnim da sem šel samo čez do Pripyata.
Enaplusdva ::
Predmestje Pripyata. Ja kolikor se spomnim tam ni nobene misije.
The Zone has many ways of making you stay. Sometimes, all it takes is the warm evening light, the quiet rustling of grass, and a sea of red flowers.
Stay for just a little longer. Lie down, rest. You are always welcome here...
Predsednik11 ::
DJ-DUST ::
Ne, dovolj pa je da mu uničiš samo dve (od treh) celic na hrbtu. Takrat tudi neha rushat v tebe in razkrivat hrbet - zgleda kot zadnja težja boss tehnika, v resnici je pa že ranljiv...
- spremenilo: DJ-DUST ()
DJ-DUST ::
Takoj ko se začne misija, ti Mavka da shotgun Guardian, pozabi na vse in se osredotoči samo na njega. Izprazni magazin v njega, umik ko te napade, ponovi enako še dvakrat in bo obležal. Potem pa greš stiskat gumbe...
JanBrezov ::
Če uničiš dve celici, menda postane ranljiv na strele tudi od spredaj. Sem vsaj enega pokončal tako.
DJ-DUST ::
To je bil moj point, zdi se težek fight ker neha "kazat" hrbet, v resnici je pa ranljiv tudi od spredaj.
Lojze1 ::
Ne vem zakaj se mi je zdelo, da je 5 celic. Jih n8sem nikoli videl prav od blizu. Vedno bežim stran kolikor je le možno.
Predsednik11 ::
yayo ::
Ja, Zulu je meni v tisti megli veliko težji kot Amok. Nisem ga še uspel premagati po kopici poskusov. Na veteran. Je en tistih bossov, ki mi dvigne adrenalin in me naredi živčnega, nakar sem pri vsakem naslednjem poskusu bolj okoren in jeznega razpoloženja. Mislim, da je moja glavna napaka, da se pri njegovem napadu nagonsko umikam nazaj in praznim puško vanj on pa kar juriša name s svojo lopato dokler mi ne pobere vsega zdravja. Pa tiste PSI halucinacije v drugi fazi ubijajo koncentracijo. Bom poskusil s taktiko omejenega števila strelov in bežanjem, da se vmes pozdravim. Drugače igram 4K HDR 1000nit. Zna biti, čeprav dvomim, ker sem sliko nastavljal po navodilih stručkotov, da imam tako naštimano, da se ga prepozno vidi. Ker, če bi ga opazil malce prej bi bilo veliko lažje. Moram kak video pogledati za primerjavo.
- spremenil: yayo ()
