83 / 109
Gregor459 ::
Your Result: Mercenaries 87%
You came to The Zone for financial gain. You have a focus on money, and are always up for doing jobs.--
Predsednik11 ::
Clear Sky
You understand the danger that The Zone poses, but you believe it still can be used for scientific pursuits. You want to keep The Zone balanced and in check. Coexistence is key.
Meizu ::
Kar dobro so me zadeli, mogoče bi edino sam monolith, bandits ter renegades postavil na dno, pa freedom višje ampak definitivno krepko pod clear sky.
  • spremenil: Meizu ()
Enaplusdva ::
Meizu je izjavil:
Se spomnim da si eden redkih kateri je odigral Sircaa tako , da me ne čudi, da si Duty >:D
yayo ::
Jaz sem imel takole: Loner
You're basically a centrist. -----------//////------------------------/-------\\---//--------==-=-----------/----------------
[i]Result Breakdown:[/i]
93% Loner
72% Mercenaries
68% Freedom
63% Bandits
55% Renegades
49% International Scientific Group
46% Clear Sky
38% Duty
38% Ecologists
36% Monolith
Pri vprašanju kaj je tvoj cilj v Coni pa ni bilo zadovoljivega odgovora, ki bi moral biti " to lose myself in the Zone" ali nekaj podobnega pa sem diplomatsko izbral "to get rich", ker ostali zvenijo preveč militantno. Žal kviz ni najbolj posrečeno sestavljen.
Izi ::
Kar dobro zadane tale kviz :D
Moj rezultat: International Scientific Group (92%)
 You're very secretive, and operate in the background. You want to understand The Zone without the Ukrainian government hiding anything, and are particular interested in the underground labs.
Motion ::
oo7 je izjavil:
Motion je izjavil:
https://www.gotoquiz.com/results/what_s...
Loner/Stalker /ClearSky.
V tvojem linku pravi Monolith ? :)
Čudno, aem 100% da je blo loner/clearsky na prvid dveh mestih
Motion je izjavil:
oo7 je izjavil:
Motion je izjavil:
Tole je bil tvoj rezultat iz tvojega linka >:D
Modify the Zone in S.T.A.L.K.E.R.: Legends of the Zone Trilogy -- Enhanced Edition now deeper than ever.
The Zone unlocks new possibilities for those brave enough to look beneath its surface. We've updated the modding guide for Legend of the Zone Enhanced Edition, adding tools that enable you to work directly with configs, shaders, and other game resources to create and publish your mods on the Steam Workshop.
Packing config files and shaders is now possible. The guide includes step-by-step instructions for preparing your mods, along with descriptions of the new toolset, opening the way for deeper manipulation of the game's structure.
This is just the first step. We're working towards enabling modification of all game resources in the future. Both the guide and available tools will continue to evolve and expand.
Mod guide is here: https://steamcommunity.com/sharedfiles/...
Meizu ::
Hmm največje vprašanje tu je, ali je posodobljen engine dejansko napredek napram monolit x64 enginu iz Anomaly. Če je razlika minimalna je vprašanje, če se bo to prijelo. Mogoče se pa motim.
Predsednik11 ::
Meizu je izjavil:
v1.7 - S.T.A.L.K.E.R.: Enhanced Edition
The Enhanced Editions of the STALKER series come with a new version of the X-Ray engine. It runs exclusively on DirectX12, is 64-bit, and has improved multithreading compared to previous versions. It also has support for game consoles and temporal anti-aliasing and image reconstruction techniques such as FidelityFX Super Resolution as well as Frame Generation.
Meizu ::
Kaj za njih pomeni "improved multithreading", ker izvirni xray sploh pojma nima kaj je to multithreading :))
Če torej število 0 povečaš za 1000%....
A pol ne bo single-core ampak dual-core support ;)
Hec.....evo multithreading support v akciji.
  • spremenil: D3m ()
Predsednik11 ::
Meizu je izjavil:
Saj Anomaly uporablja odprti X ray pogon kateri dela na 64 bitih in ima multithrea
To je verzija 1.7.
Verzija 1.7 je stara že vsaj 4 leta.
Meizu ::
Predsednik11 je izjavil:
Meizu je izjavil:
To je verzija 1.7.
https://www.reddit.com/media?url=https%...
Niti ne :D
Patch 1.5 naslednji teden.
Some new publicly disclosed information about Patch 1.5 and other interesting things coming from GSC-Answers channel on the official Discord.
-- Reload Stages are coming. This means Skif will be able to continue his reload from where he left off if the player interrupts the animation.
-- Ammo is getting a small rework for Sniper Rifles and Machine Guns
-- Custom difficulty, with sliders, is being discussed internally by the team - but without certainty that it's coming yet.
-- Mutant "sponginess" is a big topic internally, and GSC is tackling the issue carefully and working on balancing them right.
-- Ultrawide fixes are coming with 1.5
-- Seems like ZoneKit will be coming at the same date as Patch 1.5 (Modding tools)
-- Patch 1.5 is set to release next week
Meizu ::
Jebenti torej še vedno bo skiff pistol imel enak damage kot VSS? :|
Ne razumem zakaj ne potweakajo teh nastavitev, pa to ti vzame 5 min no...
Predsednik11 ::
Meizu je izjavil:
Meizu je izjavil:
To je verzija 1.7.
Niti ne :D
Ja imaš prav.
Katere vrste la je potem x ray open ali celo x ray oxygen engine ? So to sploh uradna imena v moding community ali sem zamešal vse skupaj ?
Gregor459 je izjavil:
Q2 bo kmalu konec. Koliko od tega so uresničili ?
S patchom 1.5 naj bi bilo vse uresničeno.
Julija potem bi morali dati ven Q3 roadmap. Čakam na DLC in mogoče kakšen deathmatch multiplayer :)
Meizu ::
Kot je meni znano trenutno ne obstaja multithread-ready xray engine, z izjemo mogoče posodobljenega xraya iz enhanced edition, ampak nisem uspel še stestirat. Kar pa je uspelo modderjem naredit je fork iz 32bit na 64bit arhitekturo.
Anomaly sicer recimo uporablja njihov lasten fork in sicer Monolith 64-bit engine.
Predsednik11 ::
Meizu je izjavil:
S katerim programom pa se, da to stestirat ?
Meizu ::
Stestirat kaj točno? Multithreading al kateri engine je?
Prvo stestiraš z običnim CPU metrom, drugo boš pa težko testiral brez vpogleda v kodo.
(razen če se engine sam podpiše v task manager)
Gregor459 ::
Stalker 2 devs confirm more realistic partial reloads, reworked ammo, mod kit and more are all coming in Update 1.5 alongside other tweaks https://www.videogamer.com/news/stalker...
First and foremost, the studio is adding reload renewal, a feature seen in games like Insurgency Sandstorm and other games. This feature allows players to partially reload weapons, allowing them to switch from, say, a shotgun halfway through reloading to a new weapon and to half-fill a gun.
Patch 1.5 v sredo ta teden.
Enaplusdva ::
So si pa vzeli veliko časa s dlcjem. Igra je zunaj že več kot pol leta.
S.T.A.L.K.E.R. 2: Heart of Chornobyl -- Guns & Looting Showcase | Patch 1.5
ZoneKit Phase 1 has been released!
8-O:O
Gregor459 ::
S.T.A.L.K.E.R. 2 -- New Zone Trailer
Predsednik11 ::
Added Shader Compilation Skip functionality.
Bolje pozno kot nikoli :D
Gregor459 ::
Patch 1.5 je spet ogromen https://store.steampowered.com/news/app... toliko ogromnih patchov zdaj bi morala biti igra pa že skoraj brezhibna ?
Se bomo učili delati mode :)
Learn how to make your first steps into the Modding Zone.
In this beginner tutorial, we'll walk you through the essentials of mod creation using Zone Kit -- our official toolset for crafting your own modifications. Together with Nazarii, our Producer and Game Designer, you will go from scratch to a fully-working project.
Good luck in your craft and see you in the Zone!
S.T.A.L.K.E.R. 2: Heart of Chornobyl -- Introduction to the Zone Kit
Bi probal pa ne morem, ker nimam 700GB praznega prostora na disku. V računalniku imam dva diska po 500 GB :)
Enaplusdva ::
S tem zadnjim obližem so popravili A LIFE. Sedaj naj bi bil polno funkcionalen in zona živa.
Izi ::
Glavne novosti obliža 1.5 so:
- Mutante lahko sedaj razrežeš in prodaš njihove dele. Do sedaj je bil boj z mutanti čisti nesmisel s katerim si samo po nepotrebnem zapravljal municijo.
- A-Life sedaj končno deluje po celi Zoni in ne samo v našem vidnem polju kot je bilo do sedaj.
- Dodali so eno novo anomalijo, Water Electric Tornado.
Gregor459 ::
Čisti nesmisel ni bil pobijati mutante nisi imel pa nič od njih.
Mutanti so agresivni prebivalci zone.
Predsednik11 ::
A je to normalno, da moding tool zavzame toliko placa ? Je pri ostalih igrah tudi tako veliko ?
Izi ::
Je malo nenavadno. Povprečno so Moderska orodja okoli 2 kratne velikosti igre, tukaj je pa kar 4 kratna velikost igre. Igra je trenutno okoli 160 GB
Če smo natančni je download za Stalker 2 Zone Kit "samo" 471 GB, ko pa zadevo odpakiraš se razleze na 659 GB.
Krivo je da so kompletno čisto vsi "Asseti" nekompresirani. To za Moding orodje ni potrebno zato pričakujem da se bo v prihodnje ta velikost precej skrčila ko zadeve malo optimizirajo.
Ta Zone Kit je trenutno še napol v preizkusni fazi. Sicer vse deluje in Moderji lahko gredo v akcijo, so pa orodje ven vrgli brez najmanjše optimizacije in vse dekompresirano.
Komentarji na redditu -Stalker 2's Modding Tools Require 700 GB Of Space :)
This has gotta be the most user facing access to a full game engine with its full library of uncompressed resources ever released with a public focus on modding.
Do y'all want mod tools with uncompressed assets, or do y'all want disk space? Cause you can't have both
99% of users in this sub have never modded or done asset creation in their lives.
If you create media, disk space is always a challenge. Receiving raw asset files and flexibility is far more important than 700gb. Anyone creating media seriously has TBs reserved just for it.
https://www.reddit.com/r/gaming/comment...
Gregor459 ::
THIS IS IT! - STALKER 2 Just Got a 32GB New Update
Patch 1.1.1 is out now for LOTZ Enhanced Edition.
Patch notes:
--Stability improvements - fixed several popular crashes. \[All titles]
--Fixed an issue with incorrect screen scaling on ultra performance preset on PS5 Pro console. \[PlayStation]
--Fixed freeze on loading saved game if user has more than 400-500 save files. \[All titles]
--Fixed crash while using 'Alt+Enter' key combination. \[Shadow of Chornobyl]
--Fixed issue with K&M setup on Xbox platform with inability to pick up items. \[Call of Prypiat]\[XBOX]
--Fixed reloading issues with modified RP-74. \[Clear Sky]
--Fixed several modded configs unpacking issues. \[All titles]
Gregor459 ::
Stalker 2 - Most Impressive Mod Yet? + Hotfix 1.5.1 Incoming!
Enaplusdva ::
Je že kdo sprobal program za modanje ?
Če koga zanima MODanje.
Inštrukcije iz prve roke :)
S.T.A.L.K.E.R. 2: Zone Kit — Adding New Weapon
S.T.A.L.K.E.R. 2: Zone Kit — Animation Modding
Enaplusdva je izjavil:
Nisem nimam dovolj prostora na disku.
Meizu ::
Če ste kaj od modanja se vam splača uploadat kaj na nexus, eventualno če imaš dovolj downloadov ti podelijo permanenten premium account, kar ne samo da ti olajša življenje na tistem websitu ampak ti prav pride tudi za druge igre - Elder scrolls recimo ima vse svoje modpacke poleg fallout serije na wabbajack platformi, ki samodejno downloada mode iz nexusa, za kar pa je potreben premium račun.
Itak offtopic, ampak čisto tako, če kdo še ni vedel.
Meizu je izjavil:
Nexus so zdaj pred kratkim prodali tako, da imajo novo vodstvo. Upajmo, da bodo bolj razumevajoči, do vseh vrst MODov.
Kot kaže manjši patch 1.5.1 že naslednji teden.
Gregor459 ::
oo7 je izjavil:
Meizu je izjavil:
Razumevajoči na kakšen način ?
DJ-DUST ::
Na takšen, da ne bodo več brisali modov, kateri se ne zdijo primerni njigovi agendi oz. po domače, woke agendi.
Problem namreč nastane, če mod:
- zamenja belo osebno z črno (OK)
- zamenja črno osebno z belo (izbris)
- zamenja državno zastavo z pride zastavo (OK)
- zamenja pride zastavo z državno zastavo (izbris)
Njihov zadnji izbruh je bil v Oblivion Remastered, kjer so brisali mode za body type (female seveda), folk je seveda popizdil in so se malo "omehčali". Tega je ogromno, zato nas je že kar nekaj pobrisalo svoje račune. Sedaj ko so prodani, bo verjetno še slabše, z pričakovanjem bolj agresivnega oglaševanja (tudi v samih modih)...
Gregor459 ::
DJ-DUST je izjavil:
Sem malo poguglal in ja so nekateri zaskrbljeni. V linku tudi izjava starega in novega lastnika https://www.nexusmods.com/news/15301
83 / 109
