Amis Technicolor TG788 in WRT54GL kot range extender
dajoker ::
Pozdravljeni!
Na WRTju sem nastavil vse parametre da postane range extender, v modemu od Amisa pa ne najdem nastavitev, da bi se videla med seboj. Obstaja kakšna rešitev?
Delal sem po teh navodilih:
How do I use WDS?
Here's an example basic 2-router setup as configured in the Basic/Network page:
#1 - 00:11:11:11:11:11
The WAN port of this router is connected to the Internet.
WAN
(configure normally)
LAN
IP Address = 192.168.1.1
DHCP Server = enabled
Wireless
Wireless Mode = Access Point + WDS
SSID = samessid
Channel = 3
Security = WPA Personal
Encryption = AES
Shared Key = samesharedkey
WDS = Link With
MAC Address = 00:22:22:22:22:22 (the *wireless* MAC of the 2nd router)
#2 - 00:22:22:22:22:22
The WAN port of this router is not used.
WAN
Type = Disabled
LAN
IP Address = 192.168.1.2
Default Gateway = 192.168.1.1 (the 1st router's IP address)
Static DNS = 192.168.1.1 (the 1st router's IP address or any DNS server)
DHCP Server = Disabled (the 1st router handles it)
Wireless
SSID = samessid
Channel = 3
Encryption = AES
WDS = Link With
MAC Address = 00:11:11:11:11:11 (the *wireless* MAC of the 1st router)
Zatakne se pri vnosu MAC od repeaterja v modem od amisa.
"Hacker" is a term of honour and respect. It is a term that describes
a skill, not an activity. K. Mitnick
b3D_950 ::
V linksysa vpišeš mac naslov od modema (ponavadi je napisan na nalepki) in to bi moralo bit vse. Mogoče je WPA overkill za modem?
Sicer pa testiraj Wireless Client ali Wireless Ethernet Bridge, če deluje in greš potem na izločanje, da vidiš katera kombinacija deluje.
mihec87 ::
Če ne rabi bit ravno wds..
Daš na wrt54gl dd-wrt fw ter samo daš repeater ali pa repeater bridge....Na Amis Technicolor TG788 pa ne rabiš ničesar nastavljat
http://www.dd-wrt.com/wiki/index.php/Li...
dajoker ::
A obstaja ista opcija (repeater) pri tomato FW?
  • spremenil: dajoker ()
WRT54GL RUTER(dostopna točka), povezava je omejena
61291 (1186) djforever
Repeater Bridge na Linksys WRT160NL??
157234 (4502) toncek1
Linksys WRT54G In Tomato Firmware (strani: 1 2 )
Oddelek: Omrežja in internet
7420848 (13785) Hayabusa
Dva routerja v repeated mode z vsaki svojim DHCP-jem?!
51986 (1839) BigSexy
Povezava med dvema routerjema in wireless
273909 (3617) ali3n
