Forum » Pomoč in nasveti » Win7 se noče zagnati
killa bee ::
Imam inštaliran Win7 ter Ubuntu 14.04. Včeraj sem probal na ta način spremeniti tip USB particije na ext4.
http://askubuntu.com/questions/149984/f...
Danes pa mi prikaže to napako ko se hočem logirati v Win7.
Lahko na kakšen način še vedno pridem v Win7?
- spremenilo: killa bee ()
GTX970 ::
Kristalna krogla ne dela aka tvoj post je brez repa in glave.
V Ubuntu prilepi izpis:
sudo fdisk -l
Kaj imaš na usb ključku ?
Kam imaš nameščen win in kam ubuntu & grub loader ?
Ni potrebno komplicirati v konzoli, uporabiš gtparted ali kaj podobnega in spremeniš/formstiraš.
sudo fdisk -l
- spremenilo: GTX970 ()
killa bee ::
Na hard drive-u imam inštaliran Ubuntu ter Windows 7.
Včeraj sem poskušal v linuxu spremeniti tip particije na praznem USB ključku in verjetno mi ni čisto uspelo in sem šele danes zjutraj opazil da se ne morem prijaviti v Win7.
Problem je v tem ker bi se rad prijavil v Win 7 pa se ne morem.
fdisk -l:
fdisk -l:
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes 255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk identifier: 0xcf66bec6 Device Boot Start End Blocks Id System /dev/sda1 * 2048 1591520770 795759361+ 7 HPFS/NTFS/exFAT /dev/sda2 1591521278 1953523711 181001217 5 Extended Partition 2 does not start on physical sector boundary. /dev/sda5 1945370624 1953523711 4076544 82 Linux swap / Solaris /dev/sda6 1591521280 1945370623 176924672 83 Linux Partition table entries are not in disk order Disk /dev/sdb: 7862 MB, 7862353920 bytes 37 heads, 37 sectors/track, 11217 cylinders, total 15356160 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xc3072e18 Device Boot Start End Blocks Id System /dev/sdb1 * 8064 15356159 7674048 b W95 FAT32
GTX970 ::
Bootaj iz win7 medija in uporabi funkcijo "startup repair".
Nato naredi enako za ubuntu: https://help.ubuntu.com/community/Recov...
Ne vem kaj bi imelo šarjenje po usb ključku opraviti z grub loaderjem na hdd (/dev/sda).Če ne veš kaj počneš, potem znajo biti posledice zanimive.
killa bee ::
Repair ni nič pomagal, mogoče je to v pomoč:
sudo parted -l
sudo blkid
sudo parted -l
Model: ATA WDC WD10EZRX-00L (scsi) Disk /dev/sda: 1000GB Sector size (logical/physical): 512B/4096B Partition Table: msdos Number Start End Size Type File system Flags 1 1049kB 815GB 815GB primary ntfs boot 2 815GB 1000GB 185GB extended 6 815GB 996GB 181GB logical ext4 5 996GB 1000GB 4174MB logical linux-swap(v1) Warning: Unable to open /dev/sr0 read-write (Read-only file system). /dev/sr0 has been opened read-only. Error: /dev/sr0: unrecognised disk label
sudo blkid
/dev/sr0: LABEL="UDF Volume" TYPE="udf" /dev/sda1: LABEL="New Volume" UUID="B604B3BB04B37D45" TYPE="ntfs" /dev/sda5: UUID="bcd2a988-fcf5-45ad-9a8b-9d8645acc189" TYPE="swap" /dev/sda6: UUID="ba19641f-631c-499f-a3ff-69fb6dc0d588" TYPE="ext4"
| » | Particioniranje diskaOddelek: Operacijski sistemi | 3406 (3098) | BlaY0 |
| » | SSD alignment pri dual-bootuOddelek: Strojna oprema | 1852 (1673) | CyberPunk |
| » | Software raid 1 (strani: 1 2 )Oddelek: Pomoč in nasveti | 16393 (15535) | uporabniik |
| » | Ubuntu težaveOddelek: Operacijski sistemi | 3479 (3121) | Icematxyz |
| » | Ubuntu netbook 10.4 in particioniranjeOddelek: Operacijski sistemi | 2336 (2048) | Icematxyz |
