Forum » Pomoč in nasveti » Pomoč pri tracert? T-2
adinfinito ::
Nekaj imam tezave s linijo, pa sem probal tracert, pa mi to ven vrze. Je to normalno? A bi lahko kdo od T-2 uporabnikov povedal, če dobijo enako. Hvala
tracert 195.12.232.102 Tracing route to 195-12-232-102.customer.teliacarrier.com over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.0.1 2 8 ms 9 ms 8 ms 93-104-0-5.gw.t-2.net [93 3 7 ms 8 ms 7 ms 84-255-209-249.core.t-2.n 4 11 ms 9 ms 9 ms 84-255-250-37.core.t-2.ne 5 * * * Request timed out. 6 * * * Request timed out. 7 * * * Request timed out. 8 * * * Request timed out. 9 * * * Request timed out. 10 * * * Request timed out. 11 * * * Request timed out. 12 * * * Request timed out. 13 * * * Request timed out. 14 * * * Request timed out. 15 * * * Request timed out. 16 * * * Request timed out. 17 * * * Request timed out. 18 * * * Request timed out.
OmegaBlue ::
Kaj točno ma pa to veze s T-2 če vmesni hopi ne odgovarjajo na icmp?
adinfinito ::
To temo sem nasel na neuradem forumu. https://t-2.rula.net/viewtopic.php?f=1&...
A mi lahko kdo od Telemacha/Siola pove ce je vse porihtano tam? Time to switch ISP.
snooze77 ::
Če igraš blizzardove igre je telia blokirala nezaželen promet na routerjih. Na drugih ponudnikih ti use dela normalno, sam t-2 ma probleme s packet-loss in pa high ms.
jc ::
Arnes, če ti kaj pomaga.
Tracing route to 195-12-232-102.customer.teliacarrier.com [195.12.232.102] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms 192.168.12.1 2 <1 ms <1 ms <1 ms vef-cef.uni-lj.si [193.2.96.154] 3 1 ms <1 ms <1 ms vul-vef-t2.uni-lj.si [193.2.96.13] 4 3 ms 2 ms 1 ms arnesul-vul.uni-lj.si [193.2.96.1] 5 2 ms 1 ms 2 ms larnes7-v819.arnes.si [178.172.80.172] 6 42 ms 50 ms 35 ms larnes6-v475.arnes.si [88.200.2.182] 7 1 ms 1 ms 1 ms rarnes2-i3.arnes.si [88.200.7.246] 8 2 ms 1 ms 1 ms te0-0-1-2.nr11.b021176-0.lju01.atlas.cogentco.com [149.11.116.1] 9 2 ms 2 ms 2 ms 154.25.3.89 10 8 ms 8 ms 8 ms te0-1-0-0.ccr21.vie01.atlas.cogentco.com [130.117.1.105] 11 15 ms 14 ms 14 ms be2223.ccr22.muc01.atlas.cogentco.com [130.117.49.137] 12 20 ms 20 ms 20 ms be2229.ccr42.fra03.atlas.cogentco.com [154.54.38.57] 13 20 ms 20 ms 20 ms be2188.agr21.fra03.atlas.cogentco.com [130.117.48.113] 14 * * * Request timed out. 15 * * * Request timed out. 16 * * * Request timed out. 17 * * * Request timed out. 18 * * * Request timed out. 19 * * * Request timed out. 20 * * * Request timed out. 21 * * * Request timed out. 22 * * * Request timed out. 23 * * * Request timed out. 24 * * * Request timed out. 25 * * * Request timed out. 26 * * * Request timed out. 27 * * * Request timed out. 28 * * * Request timed out. 29 * * * Request timed out. 30 * * * Request timed out. Trace complete.
adinfinito ::
Imaš kak link do tega, da zadeve malo raziščem?
A ve kdo, če se da kje pogledat katere t1 ponudnike imajo Amis,Siol, da ne bi šli z dežja pod kap.
snooze77 ::
Osebno sem pisal Telii, ker so mi na T-2 skos govorili, da ne morejo narediti nič in da težav sploh ni. Telia mi je odgovorila, da naj bi bilo use uredu. 30 min po prejmu odgovora Telie je usak trace enak tvojemu =)
SeMiNeSanja ::
Tole po moje nima nobene veze s T-2.
Probaj še od kje drugje v svetu narest traceroute, pa boš videl, da stvar ravno tako čudno pada.
Razlog mi ni jasen. RIPEstats pravi, da je routing announcan in b.p.
Potem pa probaš različne online traceroute, pa ti ni nič več jasno...
http://traceroute.nmonitoring.com/
http://ping.eu/traceroute/
Skoraj bi lahko pomislil, da jih je nekdo dal na kakšno blacklisto.....
AndrejO ::
Cogent in Telia se verjetno spet kregata. Ne bi bilo prvič in T-2 na njiju res ne more kaj dosti vplivati. Bomo videli, če se bo ponovilo 2008.
Izbira Cogenta za peering s strani T-2 je ekonomsko verjetno res upravičena, ampak za nizko ceno vedno obstaja razlog.
Reycis ::
Vprašanje, je če je dejansko kriv T-2 ali pa imajo samo nesrečo, da so ravno njihovi uporabniki prizadeti. Lahko ti potrdim iz prve roke, da Telekom in Telemach dela "tako, kot mora biti". Telemach uporablja he.net za mednarodnega mednarodni link in deluje zares super. Ping je v igrah konstanten in nizek. Zanimivo je, da SiOL prav tako uporablja Cogent vendar pa težav ni. Amis prav tako uporablja Cogent. Ne morem dati informacije iz prve roke vendar menda deluje brez problemov.
Kar se ekonomske računice tiče je težko govort na pamet pa vendar. Za zdaj je moja ocena sicer za zaradi težav še niso občutili večjega števila prekinitev pogodb. V bistvu se težava vleče že skoraj 4 mesece pa se je šele sedaj začelo govorit po forumih. Vendar zdaj ko je vsaj neke osnovne informacije o težavah na t-2 mogoče poguglat se bodo odklopi močno povečali v kolikor zadeva ne bo rešena v kratkem času.
Reycis ::
Še eno zadevo sem želel povedat. V teh 4 mesecih kar prijavljam napako se je za primer zavzel en tehnik šele sredi avgusta. Trajal je cel mesec, da je zadeva obrodila sadove. 16. Septembra ob 10:20 je mednarodna linija padla za eno minuto. In ko se je nazaj vzopostavila laga ni bilo več. Naslednji dan me je tehnik ponocno poklical da je problem rešen in da naj javim če se zopet pojavi. 23. Septembra ob 14:10 je linija ponovno padla in se vspostavila nazaj s starimi parametri. Lag se bil nazaj. Takoj sem poslal mail tehniku in kontaktiral helpdesk za uradno prijavo napake. Zdaj je že 10 dni odkar se zadeva ponovno rešuje.
Tudi če se lag reši pa bo še vedno pa bo ostal problem Cogent. Jaz se spomnem lansko leto je bila kvaliteta storitev na t-2 vrhunska. Jaz sem se logiral na game v Koreji in bil gor po 14 dni skupaj brez ene same prekinitve. Odkar pa T-2 uporablja cogent je že od v povprečju 1krat na dan (včasih tudi večkrat na dan, včasih cel teden OK) kratek mrk, ki povroči prekinitev povezave z igralnim strežnikom. Telemach v firmi zdaj testiram že več kot en mesec in v temu mesecu mi je povezavo z lineage (server se nahaja v koreji) prekinilo samo ko so imeli pri lineage maintenance. Zares fenomenalni prvi vtis. Na žalost vtis Telemach helpdeska - ravno obraten.
T-2 niti ni več najcenejši zato pomoje ni nobenega razloga za vztrajanje pri T-2 če ni kakšnih posebnih razlogov. Ni popolnega ponudnika in vsekakor obstaja riziko menjave in vezave. Vem koliko so Telemachovi uporabniki prekleli njihove storitve v preteklosti. Vendar pa trenutno tam zadeva deluje.
| » | Čudna reč z razrešitvijo naslovaOddelek: Informacijska varnost | 2138 (2009) | mr1two |
| » | Sinfonika (strani: 1 2 3 4 5 6 7 )Oddelek: Omrežja in internet | 32167 (16352) | overlord_tm |
| » | Slab ping na ŠvedskoOddelek: Omrežja in internet | 2487 (2223) | Bakunin |
| » | Naj Slo-Tech leti!Oddelek: Omrežja in internet | 3325 (2851) | podtalje |
| » | SLO ponudniki dostopa do internetaOddelek: Omrežja in internet | 1892 (1478) | Nemelk |
