LG 42PJ350 - LG MOD
LG 42PJ350 - LG MOD
miherli ::
Pozdravljeni,
Danes sem probal na plazmo 42PJ350 naloziti LG Mod, da bi lahko gledal divx preko usbja.
Ko se je namestitev koncala se je televizor ponovno zagnal in je bila slika in vse. Ko pa sem televizor ponovno zagnal ni bilo vec slike ampak samo sveti.
Probal sem ga odklopiti iz elektrike ampak ne pomaga. In ne deluje nic kar pritisnem z daljincem.
Podatki
Software: 3.32
LG Mod: 1.72
Lepo prosim za pomoc! Hvala!
dukedl ::
http://openlgtv.org.ru/forum/viewtopic....
always read before applying patches and modding your tv man. actually it goes for any device, not only your tv. the patch is supposed to work on the 3.28, not the 3.32, ive read some ppl tried downgrading before applying the patch, although it was not recommended. You soft bricked your tv and now you need to connect it to your pc with serial and reprogram the tv. i would recommend going to a specialist
http://openlgtv.org.ru/forum/viewforum....
lp dukedl
  • spremenil: dukedl ()
miherli ::
najlepša hvala :)
Pol ekrana je temno
Oddelek: Zvok in slika
154750 (3938) Yossarian
Kje tiči ta disk?
194031 (3666) solatko
3D video na tv
314745 (3659) Djz3l3
Lg Tv in internet
132246 (1926) AvtoR
Usb ne predvaja filmov na Tv
123185 (2986) dino111
