Forum » Operacijski sistemi » samba4 ne prikaze vseh filetov
MTm2H37rqt7B ::
pozdravljeni,
imam tezavo, ki je nikakor ne morem resiti
imam postavljne ubuntu 14.04.01 lts server in na njem sambo 4.1
ponujam en 3tb share - na ext4 filesystemu
klientov je vec sto, vecinoma windows 7 sp1+
tezava se mi pojavlja na samo dveh masinah in sicer
ko prva masina skopira na share filete, jih druga ne vidi. ne pomaga niti ponovni vstop v folder ali refresh/f5
pomaga pa da se naredi new folder, se ga zbrise. potem pa se pojavijo novi fileti
smb.conf:
nastavljeno je everybody fullcontrol
probaval sem z client specific loggingom in full_audit vendar nikjer nobenega errorja
kaksna ideja?
problemi so se zaceli ko sem naredil prehod iz samba3 na samba4
smb.conf:
[global]
server string = server
server role = standalone server
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
unix password sync = Yes
dns proxy = No
usershare allow guests = Yes
panic action = /usr/share/samba/panic-action %d
idmap config * : backend = tdb
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=8192 SO_RCVBUF=8192
load printers = No
printing = bsd
printcap name = /dev/null
syslog = 0
log level = 0
max log size = 1000
log file = /var/log/samba/log.%m
lanman auth = Yes
ntlm auth = Yes
server max protocol = SMB2
kernel oplocks = yes
[share]
path = /srv/share
read only = No
guest ok = Yes
create mask = 0664
directory mask = 0775
kaksna ideja?
b3D_950 ::
poglej kakšne pravice dobi file, ko ga kreira.
MTm2H37rqt7B ::
ce koga zanima resitev,
registry vnos v windows masino, kjer smo izklopili directory cache
pac windows... :)
pac windows... :)
- spremenilo: MTm2H37rqt7B ()
| » | domače omrežje + rasp piOddelek: Omrežja in internet | 5184 (4617) | Likalnik |
| » | Konfiguriranje SambeOddelek: Omrežja in internet | 1882 (1649) | Mr_Globus |
| » | Samba portiOddelek: Omrežja in internet | 2125 (1821) | hruske |
| » | Vaša smb.conf datoteka-nasvet?Oddelek: Operacijski sistemi | 1880 (1776) | Gh0st |
| » | SAMBA problemiOddelek: Programska oprema | 1911 (1810) | simon |
