Forum » Omrežja in internet » Konfiguriranje Sambe
|Luka| ::
Odločil sem se da si malo razširim obzorja in da postavim Samba strežnik. Konfiguracija slednjega je Celeron 433 + 256 MB RAM + 2 x 8.4 GB HDD.
Ni ne vem kaj a za učenje bo...
Na serverski mašini imam instaliran Vector linux z vso programsko kramo zraven, vključno s Sambo in SWAT orodjem.
Na drugi mašini pa so WIN XP.
Zatakne pa se pri sami konfiguraciji sambe. smb.conf sem uredil po svoje, ga "prekopiral" z neta (in popravil), prebral članek na S-Tju ampak na WIN mašini serverja ne vidim
. Kakšne hude varnosti ne potrebujem, zato bi prosil vas znalce če mi lahko kako pomagate.
LP Luka
LP Luka
zee ::
a se ti samba zažene?
zee
|Luka| ::
Tako smdb demon
kot nmbd demon se zaženeta bp. Tudi smbclient -L 127.0.0.1 lahko vidim detajle...
CCfly ::
Jaz imam tako smb.conf datoteko:
[global]
restrict anonymous = no
domain master = no
preferred master = no
workgroup = RINGNET
max protocol = NT
ldap ssl = No
server signing = Auto
[CCFLY]
path = /home/ccfly
guest ok = no
read only = no
case sensitive = no
msdfs proxy = no
valid-users = ccfly
write list = ccfly
Poglejmo kakšno konfiguracijo imaš ti.
[global]
domain master = no
workgroup = RINGNET
max protocol = NT
ldap ssl = No
[CCFLY]
path = /home/ccfly
guest ok = no
read only = no
case sensitive = no
msdfs proxy = no
valid-users = ccfly
write list = ccfly
"My goodness, we forgot generics!" -- Danny Kalev
|Luka| ::
Moja konfiguracijska datoteka:
[global]
server string = SAMBA
security = SHARE
encrypt passwords = no
wins support = yes
[test]
path = /data
guest ok = yes
browseable = yes
readonly = no
[global]
security = SHARE
wins support = yes
[test]
path = /data
guest ok = yes
browseable = yes
readonly = no
zee ::
pomembno je tudi tisto, kar je prej (iz mojega):
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = MSHOME
# server string is the equivalent of the NT Description field
server string = %h server
log file = /var/log/samba/log.%m
# Put a capping on the size of the log files (in Kb).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
; syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
obey pam restrictions = yes
; guest account = nobody
invalid users = root
socket options = TCP_NODELAY
[global]
workgroup = MSHOME
max log size = 1000
; syslog only = no
syslog = 0
zee
|Luka| ::
Imam občutek, da je nekaj narobe na client strani se paravi na win mašini.kako mora biti konfiguriran odjemalec?
CCfly ::
Poskusi za začetek vpisati \\ip_linux_mašine v "location bar" od Raziskovalca.
iNN ::
Nastavis na serverju, tako da kreiras uporabnika v sistem nato mu nastavis geslo za sambo. Google ti bolj podrobno opise postopek (samba howto)
Mr_Globus ::
Rabim nekaj pomoči za nastavit sambo
Hočem, da se na server z xubuntujem dostopa z računalnikov z XPjem. Naštimal sem deljenje map (preko GUIja), naredil uporabnika "nazor" in mu z smbpasswd dal geslo za sambo.
Preko XPjev se vidi linux računalnik in tudi pridem do deljenih map. Problem je, ko jih hočem odpret me vpraša za geslo - in tu je problem.. ne vem zakaj mi ne prime "nazor" in geslo, ki sem ga nastavil.
Tnx za pomoč
Tnx za pomoč
zee ::
sam nisem tega nikoli nastavljal. dovolj je bilo, da sem skopiral conf datoteko v ustrezno mapo in pognal demone. res pa je, da uporabljam najosnovnejši način dostopa - brez uporabe gesel & co. - v stilu Windows XP.
zee
| » | domače omrežje + rasp piOddelek: Omrežja in internet | 5182 (4615) | Likalnik |
| » | Samba guiOddelek: Omrežja in internet | 2055 (1770) | Bug |
| » | Samba portiOddelek: Omrežja in internet | 2124 (1820) | hruske |
| ⊘ | Samba, Linux, Windows XPOddelek: Omrežja in internet | 2345 (2117) | hruske |
| » | Samba pomočOddelek: Operacijski sistemi | 1714 (1552) | borchi |
