Forum » Pomoč in nasveti » BSOD neznana napaka?
DSQUARED2 ::
Pozdravljeni!
Imam sledečo težavo, namreč se mi velikokrat med igranjem igre zgodi, BSOD...Zdaj pa nevem kaj bi bil razlog tega.
Namreč ohišje imam zelo zračno in opremljeno z ventilatorji (CoolerMaster HAF922)
Grafična kartica je VTX3D R9280X, ki ima tudi normalne temperature namizje 36C, med igro (vent. 80%) 60-61C.FPS so normalni.
Procesor je i7 920 pred 7 meseci zamenjana termalna pasta, ventilator še normalno deluje.
Disk je Samsungov 1TB, je pa res, da ima kar nekaj delovnih ur okrog 19.600.
Rama je 6GB 133MHz.
Matična plošča MSI X58 PRO-E
OS je pa Windows 7 Home Premium 64 Bit.
Napajlnik EVGA SuperNova 650W
Vsi driverji so nameščeni nanovo za graf. sem imel na začetku Beta driverje je metalo BSOD potem sem dal stabilne driverje in je stanje isto.
Poročilo je pa sledeče:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 14.8.2014 22:03:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\081514-19453-01.dmp
uptime: 09:49:44
This was probably caused by the following module: win32k.sys (win32k!HmgLockEx+0xA3)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF960001A6483, 0xFFFFF880097A0070, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\win32k.sys
product: Operacijski sistem MicrosoftŸ WindowsŸ
company: Microsoft Corporation
description: Multi-User Win32 Driver
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Upam, da ni kaj z grafično saj je nova in sem založil račun.
Vnaprej Hvala!
Lep Pozdrav!
Rama je 6GB 133MHz.
Crash Dump Analysis
uptime: 09:49:44
Vnaprej Hvala!
Lep Pozdrav!
Mitch ::
Probaj najprej temeljito pobrisat drajverje za grafično z kakšnim specialnim programom recimo Guru3d's driversweeper nato pa inštaliraj najnovejše non-beta drajverje z uradne AMDjeve spletne strani...
| » | atikmpag.sys BSoDOddelek: Pomoč in nasveti | 4211 (3959) | zupanman |
| » | Sesuvanje računalnika (NVIDIA)Oddelek: Pomoč in nasveti | 1670 (1312) | KTr1sk |
| » | BSOD minidump problemOddelek: Pomoč in nasveti | 1272 (1120) | ru7 |
| » | Windows XP Black screenOddelek: Pomoč in nasveti | 4814 (4554) | Twix |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2926 (2665) | Duhec |
