Forum » Strojna oprema » ASUS garancija: grafične kartice
galu ::
Se mi je zazdelo, da bi marsikomu tole prišlo prav (predvsem tistim, ki kolebajo ali menjava hladilnika izniči garancijo).
Transcript chata z ASUS predstavnikom:
ASUS Live Chat Support
Kelsey G.
Support Representative
Kelsey G.
Hello zasa, thank you for contacting ASUS support. Please give me a few moments to review your information. I will be with you shortly.
Hi, how are you today?
zasa
hello, ok
do you know how ASUS' warranty works in Europe?
Kelsey G.
Unfortunately, I do not. You would have to consult with your regional support center.
zasa
we don't have it in our country
i just want to know, if i can directly send a (let's say: 2,5 year old) graphics card DIRECTLY to an ASUS repair shop
Kelsey G.
If the product is zoned to North America, you can send it to the US. Otherwise, no.
zasa
so i has to go through the retailer?
Kelsey G.
I would recommend that, yes.
zasa
but if a retailer offers a 2 year warranty
and you offer 3
how does this work
Kelsey G.
You can do either or.
zasa
either or?
i don't understand
Kelsey G.
It does not matter who you choose to warranty through, it will not void the longer warranty.
zasa
but how do i access the longer warranty
if a retailer says it wont accept it
because they only offer a 2 year warranty
Kelsey G.
You would have to send it in to a facility in Europe, where I am sure it is zoned to.
zasa
but you said "If the product is zoned to North America, you can send it to the US. Otherwise, no."
Kelsey G.
If you bought it in Europe, it is zoned there.
zasa
okay
and I can send it to (example) ASUS HQ in Germany
Kelsey G.
Correct.
zasa
and they need to repair it
Kelsey G.
Yes.
zasa
cool
one more question
how does ASUS stand on cooler modification?
Kelsey G.
For what kind of product?
zasa
graphics card
Kelsey G.
You can modify without voiding your warranty. However, when you send it in, you would have to put the original heatsinks back on.
zasa
great
and overclocking?
Kelsey G.
Supported by a specific department in US, not sure about Europe.
zasa
hm
so you would RMA it in US if the VRM was fried?
4:35 pm
Kelsey G.
No, as physical damage is not covered under manufacturer warranty.
zasa
thought so
thank you for the info
Powered by LiveChat
Torej, glede na pogovor ima ASUS:
- 3 letno garancijo (do katere lahko dostopaš direktno) // GG ASUS
- zamenjava hladilnika ne izniči garancije // na US strani majo sicer napisano, da garancija ne velja, če: "The product has been tampered with, repaired and/or modified by non-authorized personnel", kar je kontradiktorno
- fizične poškodbe (kot posledica navijanja) izničijo garancijo // obviously
Kelsey G.
Kelsey G.
zasa
hello, ok
Kelsey G.
zasa
Kelsey G.
zasa
Kelsey G.
zasa
and you offer 3
how does this work
Kelsey G.
zasa
either or?
i don't understand
Kelsey G.
zasa
Kelsey G.
zasa
Kelsey G.
zasa
okay
Kelsey G.
Correct.
zasa
Kelsey G.
Yes.
zasa
cool
one more question
Kelsey G.
zasa
graphics card
Kelsey G.
zasa
great
and overclocking?
Kelsey G.
zasa
hm
4:35 pm
Kelsey G.
zasa
thought so
Powered by LiveChat
Tako to gre.
- spremenil: galu ()
Xserces ::
Če imaš 2 levi roki bi pri menjavi lahko fizično poškodoval PCB ali kakšen drug element.
RejZoR ::
Navijanje se nikjer ne pozna razen če flashaš kartico in ti crkne ter gor ostane predelan BIOS, ki ga ne moreš (od)flashat.
Imajo pa ene firme politiko, da coolerje lahko menjaš pa ne komplicirajo, samo ko pošiljaš nazaj mora bit tovarniški, ker če zamenjajo grafično se ne boj zajebaval s premontiranjem in pošiljanjem tvojega. Zato se gre in nič drugega.
Garancija, ki jo da proizvajalec vedno velja ampak moraš poslat direktno k njim. Garancijo, ki jo da naš uvoznik pa skrbi on. Recimo sam imam ASUS 144Hz monitor, Mlacom daje 2 leti, ASUS pa 3. Če mi bo 3 leto crknil (bog ne daj) ga bom moral poslat direktno na ASUS. Če pa bo znotraj dveh let pa lahko nesem na Mlacom, pa bojo oni poslal naprej. Tko imajo vsi proizvajalci. Isto recimo Corsair napajalnik, ki ga imam. Pri nas 2 leta garancije, preko Corsaira pa 5 al celo 7 za moj high end model. To ni nič novega, ker tko furajo že kar pomnim.
galu ::
Potem ne crkne, ampak samo zafleša (kar sicer nima veze z navijanjem). To se da komot popraviti (in videti) s sekundarno grafično... Ampak vprašanje, če to sploh na servisu preverjajo.
Navijanje se lahko pozna, ampak v precej ekstremnih primerih - npr. http://www.xtremesystems.org/forums/sho.... Ampak še enkrat... Dvomim, da se jim sploh da iti razšraufavat grafulje, da najdejo tisto pešico graf na mesec, na katerih je to razvidno.
To je velikokrat problematično in ne drži vedno. Mnogi proizvajalci v Evropi ne sprejemajo izdelkov od končnih strank, ampak samo od uradnih dobaviteljev. Gigabyte je recimo en tak primer.
Tako to gre.
| » | Carinski postopek/dokumentOddelek: Loža | 4253 (3048) | scipascapa |
| » | Deli za vozilaOddelek: Kaj kupiti | 2479 (2173) | Polanc |
| » | Geekbuying garancijaOddelek: Loža | 6660 (5012) | N0t0ri0us |
| » | Nategavščina ???Oddelek: Kaj kupiti | 5104 (3391) | amigo_no1 |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20200 (17040) | arrigo |
