Forum » Kaj kupiti » Gaming PC za okoli 900 eur
Pa kater del, da za polno podporo rabiš novo arhitekturo (kar je lepo razloženo v 2 člankih, ki sem ti jih nalimal) ni jasen ?
Seveda bodo stare grafike podpirale DX12, samo novi featurji bodo izklopleni na teh grafah.
djready ::
"SUNNYVALE, Calif. -- Mar. 2014 -- AMD (NYSE: AMD) announced support for Microsoft(R) and its revamped graphics application programming interface, DirectX(R) 12, a new "console-like" version of the graphics API that has inspired PC gaming for nearly two decades. During the Microsoft(R)-sponsored panel, DirectX: Evolving Microsoft's Graphics Platform, AMD revealed that it will support DirectX(R) 12 on all AMD Radeon™ GPUs that feature the Graphics Core Next (GCN) architecture."
http://www.bjorn3d.com/2014/03/amd-demo...
Pa ker del "will support DirectX(R) 12 on all AMD Radeon™ GPUs that feature the Graphics Core Next (GCN) architecture." ti ni jasno?
Asus M5A97 R2.0, Fx 6300 4.4Ghz, XFX 280x OC BE, 8GB Ram, XFX 550w, Win7
Pa teb resno dela probleme bralno razumevanje. Sj podpirale bodo (hudača sej morejo, če je dx12 bacwards kompatabilen), sam vseh stvari pač nebodo
Še en dober komentar na to..
So far, Microsoft has mentioned only two DX12 features that will need new hardware: new blend modes and something called conservative rasterization, which can apparently help with object culling and hit detection. Neither of those additions sounds hugely groundbreaking, but as Tamasi hinted, they may just be the tip of the iceberg. We'll probably have to wait for another announcement from Microsoft to find out more.
i think you people are forgetting to read the word compatibility... and it has always been like that.
compatible doesn't mean that can run all it's features. that word comes from the stone age. you have been caught just because microsoft wanted to make some noise saying that dx12 will be compatible will this gen gpus
-hey look LOOK, we can make all these improvements on directx librires on existing hardware across all platforms, (not like mantle)-
silly boys..
- spremenil: iloveboobz ()
djready ::
"Neither of those additions sounds hugely groundbreaking" iz tvojga posta, pa še eni nevejo samo predvidevajo kaj bo in kaj ne bo.
- spremenil: djready ()
Glede na to da DX12 niti dokončan ni, medtem pa GCN obstaja vsaj že 5 let, kaj misliš, da ti to pove o kompletni kompatabilnosti ?
djready ::
Obstaja že 3 leta 7000 serija ne 5. V izdelavi novih R serij je pa samo eno leto nazaj in Glede na to da AMD in Microsoft sodelujeta na APIju mi pove veliko o kompatabilnosti.
Kaj misliš, da so začel delat GCN en dan pred izidom teh kartic ?
Pač jebat ga.Enim pojem _kompatabilnost_ ni čisto jasen.
PS:
Ni treba verjet čisto vsake malenskosti, ki jo servira AMDjov PR :)
To ti ne pove nič o kompletni kompatabilnosti obstoječih kartic, ker ta podjetja so od samga začetka vedno sodelovala pri razvojov APIjev, a je blo vedno treba za polno podporo kupit nov hardware. In sedaj ni nič drugače, samo njihov PR je to kompatabilnost (ki je itk bila vedno prisotna) obrno v svoj prid.
djready ::
Ne. Ampak so jo izpopoljnjeval par mesecev pred izidom Serije 7000.
Ti si začel z temo da "NE PODPERA DX12" Jest sem ti na to odgovoril da jo ja, nisem ti jest kriv da si se zajeb**
GCN se je začel razvijat vsaj par let pred samim izidom teh kartic (čisti začetki GCN gotovo segajo vsaj 5 let pred izidom).
In še vedno stojim za tem, da zadeve ne bodo podpirale dx12 v pravem pomenu :)
djready ::
Razvijat ja ampak ne končan izdelek.
Brias ::
@djready
pa sej ta "feature" pri direct X ti je recimo lahko jasen, ce si recimo kdaj laufal kak 3dmark test z staro graficno, katera je na pol podpirala DX10, za katero si imel naloadano knizico DX10 ...
potem si pa menjal grafiko, katera je bila full DX10, zagnal enak 3dmark test in kar naenkrat ni bilo, karikiram, 20 testov kot prej z staro grafiko, ampak 24 ...
@djready
my point exactly. Pač ovce na slepo verjamejo AMDjovem PR in potem...
kaj ti nuca končen izdelek na polici...
važno je, da je nek API finaliziran tekom razvoja neke arhitekture, ne pa takrat ko je izdelek že na prodajnih policah :)
FlyingBee ::
itak, da bo najprej dx12 potem pa grafe, vi se pa pogovarjate kot da je debata kaj je bilo prej: jajce ali kura
Ampak kaj moreš, če pa določeni osebki zmotno trdijo, da obstoječe grafe že polno podpirajo to :)
djready ::
Ne point je da neki govori da ne podpera DX12 ampak jo, v tem je sam point. Koliko features pa podpera se še ne ve ampak špekulerajo, dokler nebo nekih testov in official razlag kaj vse podpera in ne, je brez veze rekla, kazala po hojnikovo.
DX12 je že podpora na GCN arhitekturi. Koliko od tega bomo pa še vidl. DX12 bo pa tako ali tako imel več verzij DX12.1, DX12.2...
Dokler ne podpira vseh featurejev, je lahko samo kompatabilna, ne pa tudi v celeti podprta.
ker če bo igra narejena za dx12, kartica bo pa le kompatabilna z nekaterim spektrom dx12 ukazov/featurjev, pač stvar nebo špilala.
Ista zgodba je bla z dx9,10,11....
klkkkkkkkkkk ::
Odvisno za GCN je največ možnosti glede vseh features.
Hojnik glede MT-ja ne preveč govorit... ko sme naredil z FX 2 jedra 4.5Ghz vs 4 2.0Ghz so bla nekako 50% 4 jedra hitrejša.
GA-990XA-UD3, FX 6300 4.6GHz, R9 270X, 8Gb Ram, 1TB, G-550W, Win7
- spremenilo: klkkkkkkkkkk ()
pozabljaš, da cache ostaja enak, medtem ko ti znižuješ frekvenco :)
pač 1.6Ghz 8core pač nemore bit hitrejši od 5Ghz 4 core...
Not a chance...
Not a chance...
klkkkkkkkkkk ::
iloveboobz je izjavil:
Ko sem gledal Athlon 5350 v Bf3 Mp je vsekakor hitrejši od FX 4.0Ghz
klkkkkkkkkkk je izjavil:
sure :)
klkkkkkkkkkk ::
PS:
athlonček ima samo 3 pci-e steze proti 32 bulldozerjevmi :)
dobro veš kaj mislim stem. Če primerjamo recimo FX 8320 z i5 4440
NoBoDy191 ::
http://www.dinokomp.at/konfigurator/?mb...
Je to dober build? ( vem, da pravite da je intel CPU boljši, ampak meni se gre zarad grafične)
A bi sploh 550W napajalnik bil dost?
A bi lahko overclockal procesor na tej plati? ( nekje seml bral da je plata pr overclockanju tud pomembna).
+ nehejte se kregat, ker ne bo nč drgač :)
- spremenilo: NoBoDy191 ()
FlyingBee ::
edino wd blue 1tb ima razmeroma visoko ceno, vse ostale komponente so tam tam z DE trgovinami preko Idealo ... ohišje je za to ceno res OK, 3 venti bodo še zelo prav prišli pri teh zverinah
FlyingBee ::
popravek: na Hardwareversand (vsaka posebej izbrana preko Idealo.de) bi te popolnoma enak build s stroškom prevoza stal: 846,98 EUR
torej občutno manj, za 90 eur več že komot lahko ali večji SDD + boljše ohišje ali napajlnik, ali Intel xeon 4 jeder/8 ali Intel s K ALI seveda boljo grafično, ker se gre za gaming zadevo, čeprav je 290 trenutno super kar se raw perfomance tiče
- spremenil: FlyingBee ()
NoBoDy191 ::
V kolikšnem času pa ti približno pošljejo vse komponente?
Ali si že kdaj kupoval tam in kakšne so tvoje izkušnje z njimi?
FlyingBee ::
če je komponenta na zalogi, traja pač da denar pride na njihov račun in zna se zgoditi, da kakšne komponente več ni na zalogi, vendar če se le ne gre o neki posebnosti potem bo kmalu spet in seveda počakaš da so vse komponente skupaj poslane (1-2 dni za tvoje nakazilo in obdelavo, 2 dni za pošiljanje, tako da v enem tednu je ponavadi roba pri tebi), drugače pa so super, reklamacij pa še nisem z njimi reševal, to pa je več v temi prav o njih
NoBoDy191 ::
Ali bi mi lahko poslal link od builda na hardwareversand.de prek idealo.de ( nevem za kaj je sploh gre :P). Pa če je že toliko ceneje, bi lahko mogoče vključil še gtx 780 zravn?
klkkkkkkkkkk ::
Če boš kupil pri hardwareversand.de si privošči malo boljši hladilnik in malo boljšo plato... priporočena ferkvenca za FX proce je nad 4.7Ghz- ker nekatere plate omogočajo vsaj 300-400mhz več pri isti voltaži
NoBoDy191 ::
Kero plato pa hladilnik pa???
djready ::
Samsung SH-224DB schwarz - 13,99 €
http://www.hardwareversand.de/S-ATA/101...
8GB-Kit Crucial Ballistix Sport Series DDR3-1600, CL9 - 55,99 €
http://www.hardwareversand.de/1600+Low+...
WD Blue 1TB 6Gb's - 46,98 €
http://www.hardwareversand.de/7200+RPM/...
XFX PRO550W Core Edition Full Wired Power Supply - 49,52 €
http://www.hardwareversand.de/500+-+600...
AMD FX-8320 Prozessor, Boxed, Sockel AM3+ - 122,58 €
http://www.hardwareversand.de/Sockel+AM...
Crucial M500 120GB SATA 6GB/s 6,4CM (2,5") 7mm - 61,46 €
http://www.hardwareversand.de/Solid-Sta...
ASUS M5A97 R2.0, AM3+, ATX - 68,73 €
http://www.hardwareversand.de/DDR3/6377...
Thermalright HR-02 Macho Rev.A (BW) - 36,02 €
http://www.hardwareversand.de/Intel+AMD...
GeForce GTX 780, 3GB GDDR5 - 419,02 €
http://www.hardwareversand.de/3072+MB/1...
Total:
907,97 €
(907,97 € + Shipping costs + 6,99 € = credit amount 914,96 €)
Plata je čist vredu in bo dovolj za navijanje. Hladilnik je tudi dovolj vse do 4.7,4.8Ghz, folk z Cooler master evo 212 pride do 4.7Ghz.
Kako ta trgovina posluje in kako pošilja, cene... to pa nevem, ti pa lahko mogoče drugi uporabniki povejo.
Total:
907,97 €
djready ::
Glede da ga imam sam to matično in sem spravil Fx 6300 na 4.4Ghz in tudi na 4.5Ghz overa me samo temperatura ki je pa stari zalman Cpns zalman 11x performa in je v Prime95 full load 63c, macho je pa ene 5-6c boljši od Zalmana ki ga imam jaz.
s6c-gEL ::
Amd vir za tole tezo ?
pač potegnjeno iz riti, kaj pa drugega :)
fx8320 je mal drgačna zverina kot 6300 :)
djready ::
Isti clock kot Fx 6300, v bistu ima 6300 večji turbo clock, ima eno jedro več in 125 TDP. Drugače se pa da navijat isto na tej matični 8320 kot 6300.
Hočem povedat,da bo 8320 porabil več štroma na isti frekvenci kot 6300. En modul (2 jedra) pač vzameta svoj davek.
djready ::
zato pa ima XFX 550w in machota za temperaturo.
Fx 8350 4.6Ghz in to z ASUS m5a97 le r2.0 verzijo ki je slabša od R2.0,
http://www.overclockers.com/forums/show...
Najdeš tudi Asus M5A97 Rev 1.0 je tip isto navil 8350 na 4.6Ghz.
Se strinjam da kakšna Asus Evo R2.0 bi lahko še bolje navil in 990FX še bolje, ampak je tudi dražja. Je res potrebno preko 4.5Ghz tistih 2Ghz ti ne bo dala nekega FPS boosta, dobil boš samo več voltaže in več temperature. Sam probu FX 6300 na 4.3Ghz in 4.4Ghz na Unigine Heaven dobu sem 1 FPS več. Tako lahko še vedno neki navije 4.5,4.6Ghz in ima boljšo grafično kot pa da vlaga v matično in dobi mogoče 2,3Ghz več.
NoBoDy191 ::
http://www.hardwareversand.de/basket.jsp
Evo, mislim, da se našel build ki mi je všeč :D ( povejte se svoje mnenje). Grafično sem se odločil za 280x zato, ker bom igral samo na 1080p (1920x1080).Vse komponente sem izbral tudi preko Idealo.de
FlyingBee ::
ne gre tako, da link do basketa daš
copy paste, če se ne misliš s slikami tukaj gor nalepvat obadat
klkkkkkkkkkk ::
Article No. HV20XE33DE
Intel Xeon E3-1230v3 Bx, LGA1150
ready for dispatch
211,11 €
MSI R9 280X GAMING 3G, AMD Radeon R9 280X, 3GB DDR5
Delivery date unknown
269,91 €
8GB-Kit G.Skill RipJaws-X PC3-12800U CL9
65,68 €
WD Blue 1TB 6Gb's
ready for dispatch
49,80 €
ready for dispatch
60,40 €
ASRock Fatal1ty B85 Killer, Sockel 1150, ATX
ready for dispatch from 2014-05-07
74,89 €
Corsair Carbide Series 300R, ATX, ohne Netzteil
67,19 €
Seasonic G-550, 550 Watt, 80PLUS Gold
93,30 €
892,28 € top build za 900€ išči preko idealo.de pa boš dobil ceneje. Zdej nekaterih izdelkov ni na zalogi dal sem normalno ceno.
Imaš pa i7 z boostom na 3.7Ghz + R9 280X
ready for dispatch
211,11 €
269,91 €
65,68 €
WD Blue 1TB 6Gb's
ready for dispatch
49,80 €
ready for dispatch
60,40 €
74,89 €
67,19 €
93,30 €
NoBoDy191 ::
My basket
Important:
Please put a basket notice of your shopping basket, if you do not want to go directly to the cash desk. It is especially sensible because you will be disconnected after 30 minutes, if the shop recognizes no activity on this page.
Article Availebility Price per unit Quantity Price
Total:
861,07 EUR
Article No. HV1145UNDE
ASUS SABERTOOTH 990FX R2.0, AM3+, ATX
ready for dispatch
139,11 EUR
139,11 EUR
Article No. HV1033SADE
Sapphire Toxic R9 280X, AMD Radeon R9 280X, 3GB DDR5
ready for dispatch
300,62 EUR
300,62 EUR
Article No. HV20MI61DE
8GB-Kit Crucial Ballistix Sport XT Series DDR3-1600, CL9
ready for dispatch
54,34 EUR
54,34 EUR
Article No. HV30THRFDE
36,02 EUR
36,02 EUR
Article No. HV12KV12DE
Kingston SSD V300 120GB SATA III
ready for dispatch
56,53 EUR
56,53 EUR
Article No. HV20X835DE
AMD FX-8350 Prozessor, Boxed, Sockel AM3+
ready for dispatch
150,99 EUR
150,99 EUR
Article No. HVR651CSDE
Corsair CS Series Modular CS650M 650W ATX 2.3
ready for dispatch
76,48 EUR
76,48 EUR
Article No. HV13WG1ZDE
WD Green 1TB, SATA 6Gb/s (WD10EZRX)
ready for dispatch from 2014-05-06
46,98 EUR
46,98 EUR
notice basket
Clear your basket
Mal je čudno :P
klkkkkkkkkkk ::
jst grem lahko na 1.5V z voltažio na air in dosežem okoli 4.7Ghz stabilno seveda. Imel sem tud že 1.55V na 4.9-4.8Ghz vsekakor 4.9ghz ni bilo stabilno 4.8Ghz pa ravno prav za gaming. Ko grem nad 4.4-4.5 Ghz rabim veliko več voltaže. Normalno dosežem lahko 4.7-4.8Ghz sem pa že testiral 1.67V za 5.3Ghz
FlyingBee ::
Total:
861,07 EUR
139,11 EUR
300,62 EUR
54,34 EUR
36,02 EUR
56,53 EUR
150,99 EUR
76,48 EUR
46,98 EUR
Mal je čudno :P
še najbolj čudno je to, da nisi sploh upošteval kaj smo ti svetovali, razen pri cpu coolerju in spominu
klkkkkkkkkkk ::
Stojansto če hoče naj vzame FX 8*** - jaz ti priporočam FX 8320 pa malo bolj Cpu cooler. Plata je odlična bi moral it vsaj na 5.0Ghz edino tam ti lahko dela temperatura probleme. Fx 8320 sploh ni slab ko je enkrat navit je res odličen deal :)
SSD vzami za 120Gb od crucial M500 lahko tudi 240Gb (90€). Pa preko idealo. de išči ,ker tale cena za ta GPU (max 260-270€)... Vzami potem R9 290.
PSU
http://www.hardwareversand.de/600+-+700...
pol-modularen za 10€ več.
Hlajenje- lahko tudi malo boljše zračno vzameš :)
PSU
NoBoDy191 ::
Total:
861,07 EUR
139,11 EUR
300,62 EUR
54,34 EUR
36,02 EUR
56,53 EUR
150,99 EUR
76,48 EUR
46,98 EUR
Mal je čudno :P
Nekaj izdelkov ki ste mi jih svetovali jih nimajo na zalogi. (SSD, ohišje, plata...)
djready ::
M500 je na zalogi
http://www.hardwareversand.de/articlede...
Zalman Z11 Plus imaš na zalogi
http://www.hardwareversand.de/Midi/7354...
MSI 990FXA-GD80 na zalogi
NoBoDy191 ::
Kaj pa ce bi mogoce narocil iz Amazon.de (videl sem, da je ceneje) .
Ali pri Amazon.de posebej placas davek???( ali je ze vstet v ceno?)
| » | Poceni gaming pc (strani: 1 2 3 )Oddelek: Kaj kupiti | 15440 (14268) | Šolar |
| » | Streaming PCOddelek: Kaj kupiti | 2471 (2123) | klkkkkkkkkkk |
| » | računalnik 900eOddelek: Kaj kupiti | 2293 (2153) | ruupkee |
| » | nakup novega pcja, CPU?Oddelek: Kaj kupiti | 4052 (3447) | Ales47 |
| » | Kakšen gaming računalnik kupitiOddelek: Pomoč in nasveti | 2423 (2092) | teknoslo |
