Linearni sistem matrik
valkyrie ::
 Ali ima dan homogen sistem linearnih enacb netrivialno resitev? Ce jo
ima, jo izracunajte.
5x + y + 8z = 0;
3x + 2y + 9z = 0;
2x + 3y + 11z = 0:
Vpisite tisto trojico resitev, ki ima zadnjo komponento normirano na 1.
Če bi lahko kdo pomagal kako se to zračuna. Hvala.
alexa-lol ::
https://www.wolframalpha.com/input/?i=5...
Rešitev: y = 3x, z = -x
Zadnja komponenta (z) je enaka 1.
( x, y, 1) in z = -x < = > (-1, y, 1) in y = 3x < = > (-1, -3, 1)
Wikipedia - System of linear equations @ Wikipedia
Every homogeneous system has at least one solution, known as the zero solution (or trivial solution), which is obtained by assigning the value of zero to each of the variables. If the system has a non-singular matrix (det(A) ? 0) then it is also the only solution. If the system has a singular matrix then there is a solution set with an infinite number of solutions.
https://www.wolframalpha.com/input/?i=d...
Determinanta je 0 => singularna matrika
A matrix is singular iff its determinant is 0.
- http://mathworld.wolfram.com/SingularMa...
PS najprej z determinanto pokažeš ali je matrika singularna. Če je det != 0 pomeni da matrika ni singularna in da je trivialna rešitev edina.
PSS Kater faks ? :)
Matematika
Oddelek: Šola
314195 (2975) Math Freak
razstaviti izraz
Oddelek: Šola
353746 (3366) Math Freak
Gaussova eliminacija
Oddelek: Šola
116629 (5995) Math Freak
Sistem linearnih enačb
Oddelek: Šola
71359 (1281) Math Freak
Matematika
Oddelek: Šola
284816 (4209) galu
