Forum » Pomoč in nasveti » Help od logitecha- rabim pomoč.
Konlov ::
Nagaja mi volan (vsakič ko prižgem računalnik moram USB od volana iztakniti in zopet priklopiti, da zopet deluje)
Na Logitechu predlagajo tole, pa ne vem, če bi šel v to, ker mi vse ostalo deluje v redu:
I'm very sorry, I understood that the issue was already solved.
As you are experiencing a software related issue, I would suggest that we attempt a software reinstallation while your Windows installation has been placed in a clean boot state.
Clean boot is a state where only the core functions in Windows run thereby minimizing the potential interference from third party applications. This may sound very complex, but if you follow the FAQ linked below, the instructions will take you through the process step by step. I would recommend that you read through the FAQ (and this email) before begining and also print the FAQ or write down the instructions.
Answer Title: Booting Clean in Windows 7, Vista, XP, ME and 98
Answer Link: http://logitech-en-emea.custhelp.com/ap...
While your Windows installation is in the clean boot state, you should attempt to reinstall our software. You can find and download the latest version of our software for your product by going to the website http://www.logitech.com/support.
It is expected, while in the clean boot state, that some of your installed applications may not function or function as you have been used to. Do not be alarmed, once you follow the clean boot FAQ's instructions on how to restore your Windows installation to normal operating status your applications should function as usual again.
Important: As the clean boot process will disable anti-malware, security and protection software, such as third party firewall, anti-virus and anti-spyware applications, we kindly ask you to disconnect from the Internet before starting the clean boot. This will also mean, that if you need to download any software, you should do so before disconnecting from the Internet and following the clean boot instructions.
Konlov ::
Pred vsem, če je tole: http://logitech-en-emea.custhelp.com/ap... za nooba pametno počet, ker mi ostalo deluje v redu?
- spremenil: Konlov ()
Konlov ::
Tole naj bi naredil, pa ne vem, če bi, ker ostalo deluje v redu:
Clean boot in Windows 8
To perform a clean boot in Windows 8:
Press the "Windows + R" key to open a Run box.
Type msconfig and click OK.
On the General tab, click Selective startup.
Clear the Load startup items check box.
Click the Services tab.
Select the Hide all Microsoft services check box (at the bottom).
Click Disable all.
Click the Startup tab.
Click Open Task Manager.
On the Startup tab, right-click each enabled startup item and select Disable.
Click OK.
Click Restart.
After completing your troubleshooting, restore your system by doing the following:
On the General tab, select Normal startup.
Clear the Hide all Microsoft services check box.
Click Enable all.
Click Open Task Manager and enable all of your startup programs.
Click OK.
Click Restart.
NOTE: Be sure you "Enable all" Microsoft services when you are done troubleshooting, and re-enable all programs in the Startup tab, or will you lose some OS functions (ex. internet connection) and some applications won't get loaded during startup.
Click Disable all.
Click OK.
Click Restart.
Click Enable all.
Click OK.
Click Restart.
| » | Win10 restart po nekaj sekundahOddelek: Operacijski sistemi | 3206 (2935) | Manager |
| » | BSODOddelek: Operacijski sistemi | 2823 (2497) | Bolf3nk |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3702 (3092) | fr!Xy |
| » | microsoft update (problemi)Oddelek: Operacijski sistemi | 2450 (2270) | TechBeats |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2599 (2195) | Swiwer |
