Forum » Programiranje » Kako določiti masko?
erik ::
A ma kdo kako idejo, kako text boxu v VB6 določiti masko za vnos podataka.
Npr.: za datum, da so v polju že postavljene pike (XX.XX.XXXX). A se to kje nastavi ali je potrebna koda?
Hvala...
Hvala...
StratOS ::
Lahko uporabis microsoft masked textbox kontrolnik ali pa narediš kodo za preverjanje v normalnem txt box-u
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Eon Telemach in Android box (strani: 1 2 3 4 )Oddelek: Zvok in slika | 83726 (901) | freaky_h2o |
| » | Siol Box-a Media CenterOddelek: Omrežja in internet | 7351 (4245) | moat |
| » | Login popup box login error.Oddelek: Programiranje | 1597 (1485) | usoban |
| » | Odpiranje programa v Visual StudioOddelek: Programiranje | 1255 (1113) | darkolord |
| » | SiOL BOX ali BOX S vprašanjeOddelek: Zvok in slika | 5619 (5235) | Zvezdica27 |
