Forum » Pomoč in nasveti » "Križec" pri povezavah
Anonsm ::
Zdravo, imam problem.
Računalnik je povezan v omrežje preko ethernet kabla. Internet dela, dostop do ostalih računalnikov v domeni dela, skratka vse dela.
Ampak vseeno pri ikoni (slika) kaže križec, kot da računalnik ni povezan v omrežje s kablom.
Morda kdo ve, zakaj je temu tako in morebitno rešitev?
Hvala.
[edit]typo
Hvala.
[edit]typo
- spremenilo: Anonsm ()
Anonsm ::
Če je wireless izklopljen, je isti problem. Ta ikona je taka ne glede na to, ali je kaj vklopljeno ali ne.
Good Guy ::
Click Start, [click Run], type regedit, and then press ENTER.
Locate and then click the following registry subkey:
HKEY_LOCAL-MACHINE\SYSTEM\CurrentControlSet\Control\Network
Right-click this subkey, click Export , and then save the selected branch in a file.
Click the Network subkey again, and then delete the Config entry. Do not delete the >Network subkey. The Config entry will be reconstructed when you restart the computer.
Restart the computer. You may have to manually turn off the computer.
The config key is re-created on the next boot up.
The final step (6) takes a few minutes to complete. During that time, I unplugged my network cable and replugged to initate the internet connection and the key rebuild.
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
Skurjen Ethernet port ...
BorutK-73 ::
Možno da je to še kakšna druga povezava(virtual box ipd). Klikni nanjo in poglej če je "Local Area network".
Windows ima privzeto nastavljeno da ko si povezan preko kabla, se ikona skrije.
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3679 (3069) | fr!Xy |
| » | Word - ne odpre doc fajlaOddelek: Pomoč in nasveti | 2211 (2016) | Fave |
| » | Remote desktop v XP SP3Oddelek: Pomoč in nasveti | 2891 (1961) | neres |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2505 (2471) | Mercier |
| » | windows 2000 in resursiOddelek: Programska oprema | 1737 (1653) | Thunder |
