Forum » Zvok in slika » AMD Mantle
AMD Mantle
klkkkkkkkkkk je izjavil:
== Results ================================================
Test Duration: 360 Seconds
Total Frames: 15211
Average FPS: 42.25
Average Unit Count: 4103
Maximum Unit Count: 5452
Average Batches/MS: 703.49
Maximum Batches/MS: 2425.97
Average Batch Count: 18507
2M/4C nekako podoben rezultat kot z 6 jedri oz. je tale celo malce hitrejši :) Pomembno je, da ni CPu bottlenecka :)
tulk o tem da koristi 8 jeder..
klkkkkkkkkkk ::
Ja sej pravim... GPu load je na 100% nonstop
GA-990XA-UD3, FX 6300 4.6GHz, R9 270X, 8Gb Ram, 1TB, G-550W, Win7
klkkkkkkkkkk ::
Total Frames: 13819
Average FPS: 38.38
Average Unit Count: 4319
Maximum Unit Count: 5503
Average Batches/MS: 674.70
Maximum Batches/MS: 3400.79
Average Batch Count: 19600
2M/4C 1.8Ghz ....
No tudi tu je bil GPU na 100%.... ampak opazil sem veliko stutteringa
Total Frames: 13819
Average FPS: 38.38
2M/4C 1.8Ghz ....
Clubraider ::
Mene pa zanima, kako sploh v igri Battlefield 4 nastavim na Mantle?
|Corsair ATX RM 850W|RYZEN 5800X3D 3,8GHz+NEPTUNE 240|
Gigabyte X570 Aorus Elite|4x16GB DDR4|ZOTAC RTX 4090 AMP EXTREME AIRO|
Crucial BX500 240 GB|27" ACER Nitro x273kpb 4K HDR|Headset SteelSeries|
klkkkkkkkkkk ::
Video settings
DirectX - imaš spremeniš v MANTLE
- moraš imeti GCN in zadnji patch prav tako 14.1 beta driverje
klkkkkkkkkkk ::
Še en test
i3 4330 3.5Ghz vs FX 4300 3.5Ghz
RTS LOW
Total Frames: 21808
Average FPS: 60.58
Average Unit Count: 4585
Maximum Unit Count: 5671
Average Batches/MS: 1256.84
Maximum Batches/MS: 2069.39
Average Batch Count: 20616
Maximum Batch Count: 33313
http://hothardware.com/News/AMD-Mantle-...
RTS LOW
Total Frames: 21808
Average FPS: 60.58
- spremenilo: klkkkkkkkkkk ()
Clubraider ::
FlyingBee@ moraš imeti GCN in zadnji patch, kako to misliš?
14.1 beta driverje, to pa imam.
klkkkkkkkkkk ::
GCN - 7000 serije ali višje
Bf4 mora bit updatan
Clubraider ::
Aha....razumem.
Grafično imam 7970
Bf4, pa bom updatal.
Hvala.
Grafično imam 7970
Hvala.
Bizkit45 ::
a mi lahko kdo na hitro pove ali 6800k (8670d) podpira mantle? in kateri špil bi lahko potestiru? je res da samo BF4 in pa neki swarm deluje na mantle? tnx
klkkkkkkkkkk ::
boš moral počakat
Če vi mislte, da bo AMD portal tale API na stare arhitekture... well.. good luck :)
iloveboobz je izjavil:
Kaj pa veš, kaj jih piči v tistem momentu. Moje mnenje je, da bo, kar GCN ostal.
Clubraider ::
Meni je tale Mantle v igri Bf4 ni nič povečal FPS.
Mogoče zato, ker ni še zajeta 7970?
klkkkkkkkkkk ::
Imaš 14.1 driverje in ko premeniš na MANTLE moraš restartati
Clubraider ::
Imam 14.1 driverje.
Restartati igro ali rač.?
Igro sem restartal in ni bilo nobene spremembe, FPS je bil isti.
klkkkkkkkkkk ::
Video setting pa namesto directX naštimaš MANTLE
Clubraider ::
Sem, pa dal applay, pač potrdil, restartal igro in se ni nič zgodilo.
fireX88 ::
Kaj lahk napiš kakšen pc imaš?
fireX88 ::
Sicer je pa tako, ce imas vsyn vklopljen in imas neprestano na 60fps-jev razlik nebos videl. Opazil bi, če bi imel slabšo grafično kartico.
Clubraider ::
V podpisu piše kakšen PC imam.
Nimam vsyn vklopljen.
klkkkkkkkkkk ::
Samo probaj dati na najnižjo resolucijo za 5 min gameplaya pa poročaj rezultate
fireX88 ::
Clubraider je izjavil:
VČeraj sem bil na tablici in mi ni pokazalo tvojega podpisa. Očitno ti že tako dobro dela, da mantla sploh ne potrebuješ. Koliko pa imaš fps-jev. Povprečno?
Clubraider ::
fireX88@nič hudega. :)
Ja v povprešju imam nekje med 50-60 FPS.
Vem, da lahko imam več, vsaj na Youtubu ko gledam kak drugim dela z podobno konfiguracijo, mislim, da bi lahko bilo več. Je pa res, da tudi če včasih na 40FPS pade, se ne opazi nobeno zatikanje... Ali pa je to samo optično, ker sem full bulil not, če vidim razliko :D
So pa vse nastavitve na ULTRA. Resolucija 1920x1200
FlyingBee@ bom zvečer poročal o rezultatih. Hvala.
Spock83 ::
Phenomenalno :)
Jaz imam pri isti ločljivosti, vse na ultra od 70fps (parcel storm, okoli 60 igralcev in med nevihto, ko je na višku) pa do 120fps. Mantle sem na hitro sprobal, sam sem takoj vrnil na directX. Preveč težav je bilo.
Clubraider ::
Spock83@ Kako grafično imaš?
TechBeats ::
Fora ni samo v FSP boost, z Mantle se bo dalo iztisniti več draw calls, kar bo naredilo bolj živ svet z več detajli. Driectx je tam do max 15.000calls, Mantle baje tudi do 90.000calls, povprečno tam 30-50K calls.
AciD TriP
klkkkkkkkkkk ::
Ja to je šele začetek, kar zmore MANTLE
klkkkkkkkkkk ::
Saj imajo že boljđši directx to je vsem jasno - ampak ali ga bodo uporabili?
Clubraider ::
FlyingBee@ Evo prišel sem do rezultatov.
Zmanjšal sem resolucijo na najmanjšo in FPS je poskočil za enkrat. Kaj bi naj zdaj to pomenilo?
Hvala.
Hvala.
klkkkkkkkkkk ::
GPU bottleneck
problem je ker mantle ne deluje dobro - včasih ja včasih ne in nekateri imajo slabši GPU perfromance z MANTLE kot pa brez - CPU perf. pa je vedno boljši :)
Clubraider ::
NightHawk @
Mantle performance for the AMD Radeon HD 7000/HD 8000 Series GPUs and AMD Radeon R9 280X and R9 270X GPUs will be optimized for BattleField 4 in future AMD Catalyst releases. These products will see limited gains in BattleField 4 and AMD is currently investigating optimizations for them.
Zato ne morejo biti še pravi rezultati.
klkkkkkkkkkk ::
NightHawk @
Tu se dobro opazi kaj naredi mantle - Glej graf
Nwm kaj izumljate toplo vodo.. Mantle boosta performance na lowend cpujih (in amdjih
) to je pa to... GPU bottlenecki še pa vedno ostanejo. Mantle nebo magično naredu 260X v 290X...
Senitel ::
That's so 3 years ago...
Mantle tega ne more spremenit, ker je zaklenjen na AMD (da je odprt se bomo začeli pogovarjati, ko mi bo nekdo dal link na SDK). Da se bodo developerji dejansko lahko šli tako število draw klicev, bodo najprej moral izbrat API, ki to ponuja na več kot enem proizvajalcu GPU-jev. Sicer bo zadeva samo nek tech demo in nič drugega. Tako kot StarSwarm.
vaščan ::
Napovedanih je nekaj špilov s mantlom če bo zadeva na mantlu dejansko delovala precej bolje kot na dx potem mislim bodo nvidia userji tolk časa težil da podprejo api samo bo treba amdju navržt kakšen eur da dovolijo. Sej hvala bogu da se zadeva razvija sploh mi je všeč ko trdijo da se bo dalo s mantlom zelo približat code to the metal kot na konzolah in bo posledično tudi gpu boost ne samo draw calls per frame boost. Že pri battlefieldu se porajta da je s mantlom gpu res 100% izkoriščen sej ne rečem da na dx ni ampak gpu mantle tolk bolj fila s podatki da dejansko dobiš višje minimalne fpsje to pa je tudi tisto kar največ šteje. Sicer je zadeva še v beti in je med špilom stuter naj bi se to zrihtalo.
klkkkkkkkkkk ::
AMD mantle je beta in dokler nebo dokončan, bo ZAPRT. To je že kar nekaj časa znano.
Čeprav XO/PS4 niso imeli v načrtu MANTLE-a je mogoče, da bodo vseeno podprli MANTLE. No to bo pa potem zelo zleo zanimivo.
http://www.inquisitr.com/1120277/amd-ma...
In tudi nvidia se nebo odrekla MAntlu, če ga bodo ostali pdoprli
http://www.eteknix.com/nvidia-asked-amd...
Fino bi bilo, da bi se zmenili Physx/Mantle
Brane22 ::
Ne vem no. če je ta "eden od proizvajalcev" AMD, potem stvar že ne bo tako obskurna, tudi če obstane na tem IMHO.
Pa ne verjamem. Domnevam, da bo kakemu Intlu v interesu, da mu bo sledil, če ne že nVidii...
kriko1 ::
Napovedanih je nekaj špilov s mantlom če bo zadeva na mantlu dejansko delovala precej bolje kot na dx potem mislim bodo nvidia userji tolk časa težil da podprejo api samo bo treba amdju navržt kakšen eur da dovolijo. ...
Teh nekaj špilov si lahko nekam vtaknejo.
Še posebej v takem release-stanju kot BF4. I ain't buying them.
- spremenil: kriko1 ()
klkkkkkkkkkk ::
Dobro se zavedam.
Pa se ti zavedaš, da lahko MANTLE postane hitrejši od teh lowlevel api-jev?
Če jim to uspe, čeprav je malo možnosti imajo možnost, da ga PS4 podpre...
tale komentar lepo povzame cel članek
Kateri del, da je API konzol dosti bolj low level ti ni jasen ?
Mantle je namenjen PCjem, da dobijo console "like" izkoriščenost. Implementacija le-tega na konzole nima abosolutno nobenga smisla, zaradi razlogov ki sem jih zgoraj naštel...
The PS4 and Xbox One already have a low level API (a much more efficient and lower level one at that), why the hell would they need Mantle? Seriously, stop writing about things you don't understand. No offense, but it's annoying. Thanks.
Dobro se zavedam.
- spremenil: iloveboobz ()
Niti malo ti ni jasno.
Konzolski APIji so že narejeni tako, da iztisnejo max iz tistega hardware-a.
Mantle je narejen tako, da lahko iztisne karseda veliko iz PC hardwareskih konfiguracij...
Lahko bi rekel, da je mantle okrnjen console API, da deluje na več kot eni grafi :)
Zakaj hudiča bi potem to nazaj implementiral na konzole ?
klkkkkkkkkkk ::
Mantle je narejen tako, da lahko iztisne karseda veliko iz različnih hardwareskih konfiguracij...
Vidiš tu se motiš. Ja konzole maximalno izkoristijo CPU, kaj pa GPU? Mislim, da se nekaj med 7850 in 7870 (GPU- PS4), da igrati na PC-ju vse na 1080P.
Mantle je narejen za GCN - oz. da dobi GCN boost.
In to so govorili v tem članku GPU boost - ne pa CPU boost... in če mantle povzroči GPU boost (sedaj je že na 10-15%) mislim, da bi ga konzole podprle...
Vsekakor se govori tudi o HSA - ali imajo konzole podporo? Lahko MANTLE to v gamingu podpre?
Ni potreben boost GPu boost za 50% ... vsak procent šteje vsaj na konzolah.
54j0 ::
Sprva tudi jaz nisem točno vedel, kako je okoli teh api-jev na konzolah, zdaj pa mi je čisto razumljivo, da jih bi mantle/directx/opengl kvejčemu okrnil. Res škoda, da sta se konzola in pc razvejala, namesto da bi ubrala neko srednjo pot (običajni pc, ki bi imel "pure game mode" ali nekaj takega). Konkurenca je blagoslov in prekletstvo obenem :).
Konzolski API je optimiziran za GPU in CPU. In to bolje kot mantle, ker je hardware fiksen in dobro poznan.
Razlog, da niso vse igre 1080p in/ali 60fps je v nepoznavanju platforme, kar potem pride do tega, da te early igre še niso tako optimizirane. Morš vedet, da te igre ki so zdaj na ps4, so ble razvite v času, ko ps4 še sploh ni obstajala v takšni obliki kot je danes.
klkkkkkkkkkk ::
Ja trenutno bi jih okrnil...
Če povežeš dejstva
Mantle beta 2014
GPU 10-15 boost
CPU huge boost
Če so zmožni dodati še GPU boosta (kar je malo verjetno)... lahko to podprejo tudi konzole...
Tako, sem jaz razumel smisel tega
Če bodo dali dodaten boost GCN jedru potem se lahko zgodi, da bo PS4 podpru
Hojnikb razumem te,
jaz sem samo povedal, kako razumem ta članek...
| » | Directx 12Oddelek: Programska oprema | 2915 (1880) | Dr_M |
| » | NVIDIA pripravlja osvežitev Titana (strani: 1 2 3 )Oddelek: Novice / Grafične kartice | 47630 (41388) | CellarDoor |
| » | Mantle za Battlefield 4 končno prihaja (strani: 1 2 )Oddelek: Novice / Igre | 31697 (27524) | Jst |
| » | nVidia odgovarja AMD-ju (strani: 1 2 )Oddelek: Novice / Grafične kartice | 20649 (15964) | Furbo |
