Zevera multihoster
Zevera multihoster
2
gregor ::
Lahko si nastaviš tako kot jaz:
Settings -> General -> Remove finished downloads: immediately
Settings -> Archive Extractor -> Delete archive files after extraction: Delete files from hard disk; Delete archive download links after successful extraction ✓
to sem nastavil in deluje brezhibno, hvala
ne uspe pa mi da bi se prenosi takoj ko se dodajo, avtomatsko premaknili iz grabberja v downloads
sem dodal zgoraj navedeno packagizer pravilo a ne pomaga
_Denny_ ::
Sem se malo igral in je zgleda uspelo.
Naredi si takšno pravilo:
Potem se bo pri Start all downloads pokazal gumb z odštevalnikom, po 5s pa se začne avtomatski download (sem gledal pa se ta zakasnitev žal ne da izklopiti)
gregor ::
super, hvala :):)
5 sek gor ali dol, to sploh ni pomembno...
sprobam danes zvečer in poročam
zadeva deluje odlično, hvala za nasvet :)
  • spremenil: gregor ()
gregor ::
sicer offtopic....
We are excited to announce that we've upgraded our NNTP Usenet retention to 2000 days.
Now you can access all newsgroup posts that were added up to 2000 days ago, with 99%
completion with no additional cost. As always if you have any feedback we would love
to hear it, either through the Easynews Support Forum or email us at support@easynews.com.
Thank you,
The Easynews Team
torej sedaj imajo retencijo več kot 5 let na NNTP
gregor ::
Da oživim staro temo :)
Kmalu mi bo potekel zavera račun.
Sedaj pa ne vem kateri multihoster je najbolje izbrat, poceni in hiter.
http://www.alldebrid.com/
https://secure.premiumize.me/?show=about
https://real-debrid.com/
http://www.multi-debrid.com/
https://simply-debrid.com/
http://unrestrict.li/
ali katerega drugega?
Tukaj
http://multihostreview.blogspot.com/
pravijo da je premiumize najboljši vendar pa gre morda samo za reklamo, ne vem...
Hvala
_Denny_ ::
Unrestrict je pred nekaj meseci menjal lastnike in je več ali manj poden (če ga uporabljaš za kaj drugega razen uploaded.net), za druge pa ne vem; trenutno vsi na dl straneh priporočajo uporabo free generatorjev s tega seznama, ker je večina plačljivih postala nezanesljiva.
Če se ti da lahko tudi pogledaš JD seznam, malo stestiraš (nekateri ponujajo trial accounte) in se potem odločiš.
gregor ::
Hvala za odgovor. Nisem vedel da to obstaja.
Je pa tega ogromno. Ali morda veš kateri so najboljši, kaj ti uporabljaš?
Ali potem še rabim Jdownloader oz lahko uporabim kateri drug program? Kaj ti uporabljaš?
Hvala
_Denny_ ::
Več ali manj so vsi isti, ker samo generirajo link, downloadaš pa od hosterja; razlikujejo se samo po številu reklam (nekateri zahtevajo izklop adblocka), to pa je vse. Glede dl strani je najboljši tisti, ki deluje, to pa žal samo ugotoviš samo s testom.
Download poteka direktno preko browserja (dvomim, da katera od teh strani podpira kak dl manager), linke pa generiraš enega po enega...je nadležno, se pa od free stvari več tudi ne more pričakovati.
gregor ::
Ok, hvala, bom sprobal, pa da vidimo kako se obnese.
Če bo preveč zamudno pa grem na premium multihoster - 20, 30... eur na leto ni neka blazna cifra.
kumer ::
ali kateri multihoster podpira nitroflare?
opažam da je NF vedno bolj prisoten na tem področju
hvala
knap ::
ponovno obujam to zelo staro temo...:D
ali morda veste če kateri multihoster še podpira rapidgator, sam imam real debrid vendar pa že precej časa rapidgator ne deluje
kaj vi uporabljate?
oz je kakšen drug način za uporabo rapidgatorja brez omejitev glede hitrosti ipd
hvala
hdx ::
_Denny_ ::
knap je izjavil:
kaj vi uporabljate?
hvala
http://premium.to/
1500gb special traffic - 25€
Teh 1500gb velja za uploaded.net, share-online.biz (začuda tu zaenkrat deluje, pri 99% ostalih multihostih ne), rapidgator.net, filer.net in oboom.com, za vse ostale podprte dobiš samo 15gb. Uporabljam ga že od decembra in nimam nekih pripomb. Marca so edino imeli neke težave z DNS serverji, kar so v manj kot enem dnevu odpravili. Sem poskusil en rapidgator link in zadeva deluje z 1,7-2,5mb/s od maksimuma 3,2mb/s moje povezave.
Če boš vzel ta special paket, ti svetujem, da si na strani v DLM tabu obkljukaš samo teh 6 hostov. Hitro se zgodi, da pomotoma v JD2 dodaš napačne linke in po nepotrebnem porabiš tistih 15gb. Če boš rabil preostale hoste, si lahko še vedno v Download tabu generiraš linke.
S free link generatorji pa je tako...od začetka je še šlo, zdaj pa pretiravajo z adfly/linkbucks sranjem. Nek download ima 100 delov in zdaj boš za čisto vsakega posebej zapravil 5 min s klikanjem in na koncu še dobil darilo v obliki "error, try again". Sem škrt oseba, a imam vseeno rajši mirne živce kot pa 25€ v žepu.
knap ::
Se strinjam z tem kar si napisal v zadnjem odstavku.
Jaz sem za real debrid - 1 letno naročnino dal cca 50 eur, prenosi pa so neomejeni.
RG in ostali do sedaj niso povzročali večjih problemov.
No, včeraj sem spet poskusil v JD2 in začuda je RG deloval, vendar pa samo 3 linke hkrati, nato je pri vseh ostlih napisalo "skipprf captcha is required" in zadeva se je ustavila, da sem potegnil nove 3 linke semo moral vedno znova kliknit na "force download start"
Bolje kot prej, ampak čisto brez moje intervencije pa ni šlo.
Upam, da bodo uredili RG.
hdx ::
https://adsbypasser.github.io/
V parih sekundah preskoči vse oglase in začne downloadat
knap ::
hvala, bom preizkusil
ali uporabim lite ali full verzijo?
hdx ::
Jaz imam full
knap ::
sem mislil da je na zgornjem linku program ki se inštalira
sedaj pa vidim da gre skript in nimam pojma kako to spravim v JD2, uporabljam...
sem iskal z googlom za rešitev problema vendar ne najdem vodiča, nasveta kako inštaliram ta skript
prosim za pomoč
hvala
hdx ::
To pa ne vem, ker downloadam vedno preko brskalnika. Če veliko uporabljaš filesharing strani, potem je verjetno najboljše, da kupiš acc oz. pogledaš malo cbox leech strani, ter nabaviš VIP acc.
knap ::
imam račun pri multi hosterju real debrid...., je pa tako kot pri vseh MH, včasih RG, UL ipd strani delujejo odlično, včasih pa niso podprte
gre pač za večno borbo med multi hosterji in one click hosterji..., slednji ne odobravajo počejta MH
kako pa preko brskalnika dolvlečeš, kateri dodatek uporabljaš za skripte, lahko kaj več poveš o tem?
ali ne uporabljaš plačljivih storitev?
hvala
hdx ::
Če imaš chrome https://chrome.google.com/webstore/deta...
Potem greš na https://adsbypasser.github.io/ in klikneš full edition in v tampermonkeyu klikneš na install.
Greš na neko cbox leech stran se registriraš in označiš "auto check link" ter kopiraš RG link in počakaš da ti bot pošlje nazaj stran s katere downloadaš.
Enkrat sem kupil vip račun za en mesec na cboxera, ker sem vlekel nanizanko dol in se mi ni dalo ukvarjat z limiti. Ponavadi lahko free uporabniki downloadajo eno datoteko vsakih 5 minut.
Edino http://leechpremium.link/cbox.html nima te omejitve
Imaš pa tukaj celo listo cbox in debrid strani
https://freerapidleechlist.blogspot.si/
  • spremenilo: hdx ()
knap ::
ok, hvala
očitno se bom nekaj novega naučil :)
sicer uporabljam FF, ali morda veš če tukaj uporabim greasemonkey addon za install script?
hdx ::
Ja greasemonkey
2
Youtube to Mp3 (strani: 1 2 )
6425379 (614) BlackFox101
Kam shraniti slike na splet
Oddelek: Omrežja in internet
135403 (4212) pixelzgaming
Spletna stran na lastnem serverju
234371 (3879) #000000
Google želi ponujati glasbo z naročnino
84648 (3738) refaktor
AT&T z majem vpeljuje omejitve prenosa (strani: 1 2 3 )
10228255 (24634) Bistri007
