Lenovo 3000 n200 KAMERA NE DELA
ana83 ::
Na laptopu mi ne dela kamera. Delala je do ponovne namestitve Windows XP. Driverje imam instalirane. Med COMPUTER MANAGMENT tudi ne kaže da bi bila kakšna naprava s nedelujočim driverjem ali da bi bila kjerkoli kakšna kamera nasploh...
Prosim na pomoč :)
LP Ana
Duhec ::
Kako pa si inštalirala driverje?
Program za kamero je Setup.exe program, ki izvede inštalacijo.
Je na lokaciji:
C:\DRIVERS\Vista32\CAMERA\SETUP.EXE
Če je to inštalirano poglej še tale fix:
"To fix the problem, go to the Device Manager (My Computer -> Right-click -> Properties -> Hardware tab -> Device Manager button). Switch the view to Devices by Connection (View menu).
Now navigate down the treeview as follows: ACPI Multiprocessor PC -> Microsoft ACPI-Compliant System -> PCI Bus -> Intel(R) ICH9 Family USB2 Enhanced Host Controller 293C -> USB Root Hub -> Integrated Camera
(A couple things to note... If you don't have a T400, the top level of this treeview might say something slightly different if it's not a multi-core CPU, so just find the one that talks about ACPI. or the PC itself. It'll be one of the few that you can expand. You also may have different entries for the USB Host Controller, so just pick one of those. You might have to go searching for which controller and root hub connects to your integrated camera... just try all of the USB entries until you find it.)
Once you've found your integrated camera in the Device Manager (has to be Devices by Connection view), right-click on the Root Hub to which the camera is connected in the treeview, and select Properties. Go to the Power Management tab and UNCHECK the box that says "Allow power management to turn off this device to save power"."
  • spremenil: Duhec ()
Gigabyte 970A-UD3P Rev 2.0 in USB 3.0 problem
103812 (3617) Sami
usb disk-flash drive/pc ga ne zazna?!
141183 (1056) iloveboobz
USB ne dela
74502 (3553) bastadu
USB.ji ne delajo. nujno
161795 (1552) celebro
Win XP SP2 in Blutooth
82449 (2294) jast
