wordpress delete posted by
XzupanX ::
Kako bi zbrisal, da mi napiše posted by in pa recimo da sem na strani o nas, da zgoraj nad postom napiše Home>O nas
<?php
// Exit if accessed directly
if( !defined( 'ABSPATH' ) ) {
	exit;
 * Blog Template
Template Name: Blog (full posts)
 * @file           blog.php
 * @package        Responsive
 * @author         Emil Uzelac
 * @copyright      2003 - 2013 ThemeID
 * @license        license.txt
 * @version        Release: 1.1.0
 * @filesource     wp-content/themes/responsive/blog.php
 * @link           http://codex.wordpress.org/Templates
 * @since          available since Release 1.0
get_header();
<div id="content-blog" class="<?php echo implode( ' ', responsive_get_content_classes() ); ?>">
	<?php get_template_part( 'loop-header' ); ?>
	<?php
	global $wp_query, $paged;
	if( get_query_var( 'paged' ) ) {
		$paged = get_query_var( 'paged' );
	elseif( get_query_var( 'page' ) ) {
		$paged = get_query_var( 'page' );
	else {
		$paged = 1;
	$blog_query = new WP_Query( array( 'post_type' => 'post', 'paged' => $paged ) );
	$temp_query = $wp_query;
	$wp_query = null;
	$wp_query = $blog_query;
	if( $blog_query->have_posts() ) :
		while( $blog_query->have_posts() ) : $blog_query->the_post();
			<?php responsive_entry_before(); ?>
			<div id="post-<?php the_ID(); ?>" <?php post_class(); ?>>
				<?php responsive_entry_top(); ?>
				<?php get_template_part( 'post-meta' ); ?>
				<div class="post-entry">
					<?php if( has_post_thumbnail() ) : ?>
						<a href="<?php the_permalink(); ?>" title="<?php the_title_attribute(); ?>">
							<?php the_post_thumbnail(); ?>
						</a>
					<?php endif; ?>
					<?php the_excerpt(); ?>
					<?php wp_link_pages( array( 'before' => '<div class="pagination">' . __( 'Pages:', 'responsive' ), 'after' => '</div>' ) ); ?>
				</div>
				<!-- end of .post-entry -->
				<?php get_template_part( 'post-data' ); ?>
				<?php responsive_entry_bottom(); ?>
			</div><!-- end of #post-<?php the_ID(); ?> -->
			<?php responsive_entry_after(); ?>
		<?php
		endwhile;
		if( $wp_query->max_num_pages > 1 ) :
			<div class="navigation">
				<div class="previous"><?php next_posts_link( __( '&#8249; Older posts', 'responsive' ), $wp_query->max_num_pages ); ?></div>
				<div class="next"><?php previous_posts_link( __( 'Newer posts &#8250;', 'responsive' ), $wp_query->max_num_pages ); ?></div>
			</div><!-- end of .navigation -->
		<?php
		endif;
	else :
		get_template_part( 'loop-no-posts' );
	endif;
	$wp_query = $temp_query;
	wp_reset_postdata();
</div><!-- end of #content-blog -->
<?php get_sidebar(); ?>
<?php get_footer(); ?>
Arctander ::
Odvisno od izbrane teme, kje vse izpisuje "posted by". Če izpisuje povsod, potem moraš pobrisati iz index.php (glavna stran), single.php (prikaz posameznega članka) in page.php (prikaz posamezne strani) - seveda v datotekah od teme, ki jo trenutno uporabljaš.
Izbrisati moraš tale del kode:
<?php _e('posted by'); ?> <?php the_author(); ?>
  • spremenilo: Arctander ()
XzupanX ::
Hm, nikjer ni tega. Sem povsod pogledu pa ni nikjer te kode...
  • spremenil: XzupanX ()
Arctander ::
Katero temo uporabljaš?
XzupanX ::
XHTML povezava
Oddelek: Izdelava spletišč
212105 (1847) HardFu
Joomla 1.7 problem
51457 (1236) shovty
Objavljeni rezultati zunanje revizije Googlovega prisluškovanja
Oddelek: Novice / Zasebnost
106945 (6452) fosil
Naprava za branje knjig
142912 (1913) Firebat
Ikona v Delphiju
Oddelek: Programiranje
131204 (1029) skorc_norc
