Forum » Izdelava spletišč » wordpress delete posted by
XzupanX ::
Kako bi zbrisal, da mi napiše posted by in pa recimo da sem na strani o nas, da zgoraj nad postom napiše Home>O nas
<?php
// Exit if accessed directly
if( !defined( 'ABSPATH' ) ) {
exit;
* Blog Template
Template Name: Blog (full posts)
* @file blog.php
* @package Responsive
* @author Emil Uzelac
* @copyright 2003 - 2013 ThemeID
* @license license.txt
* @version Release: 1.1.0
* @filesource wp-content/themes/responsive/blog.php
* @link http://codex.wordpress.org/Templates
* @since available since Release 1.0
get_header();
<div id="content-blog" class="<?php echo implode( ' ', responsive_get_content_classes() ); ?>">
<?php get_template_part( 'loop-header' ); ?>
<?php
global $wp_query, $paged;
if( get_query_var( 'paged' ) ) {
$paged = get_query_var( 'paged' );
elseif( get_query_var( 'page' ) ) {
$paged = get_query_var( 'page' );
else {
$paged = 1;
$blog_query = new WP_Query( array( 'post_type' => 'post', 'paged' => $paged ) );
$temp_query = $wp_query;
$wp_query = null;
$wp_query = $blog_query;
if( $blog_query->have_posts() ) :
while( $blog_query->have_posts() ) : $blog_query->the_post();
<?php responsive_entry_before(); ?>
<div id="post-<?php the_ID(); ?>" <?php post_class(); ?>>
<?php responsive_entry_top(); ?>
<?php get_template_part( 'post-meta' ); ?>
<div class="post-entry">
<?php if( has_post_thumbnail() ) : ?>
<a href="<?php the_permalink(); ?>" title="<?php the_title_attribute(); ?>">
<?php the_post_thumbnail(); ?>
</a>
<?php endif; ?>
<?php the_excerpt(); ?>
<?php wp_link_pages( array( 'before' => '<div class="pagination">' . __( 'Pages:', 'responsive' ), 'after' => '</div>' ) ); ?>
</div>
<!-- end of .post-entry -->
<?php get_template_part( 'post-data' ); ?>
<?php responsive_entry_bottom(); ?>
</div><!-- end of #post-<?php the_ID(); ?> -->
<?php responsive_entry_after(); ?>
<?php
endwhile;
if( $wp_query->max_num_pages > 1 ) :
<div class="navigation">
<div class="previous"><?php next_posts_link( __( '‹ Older posts', 'responsive' ), $wp_query->max_num_pages ); ?></div>
<div class="next"><?php previous_posts_link( __( 'Newer posts ›', 'responsive' ), $wp_query->max_num_pages ); ?></div>
</div><!-- end of .navigation -->
<?php
endif;
else :
get_template_part( 'loop-no-posts' );
endif;
$wp_query = $temp_query;
wp_reset_postdata();
</div><!-- end of #content-blog -->
<?php get_sidebar(); ?>
<?php get_footer(); ?> Arctander ::
Odvisno od izbrane teme, kje vse izpisuje "posted by". Če izpisuje povsod, potem moraš pobrisati iz index.php (glavna stran), single.php (prikaz posameznega članka) in page.php (prikaz posamezne strani) - seveda v datotekah od teme, ki jo trenutno uporabljaš.
Izbrisati moraš tale del kode:
<?php _e('posted by'); ?> <?php the_author(); ?> Zgodovina sprememb…
- spremenilo: Arctander ()
XzupanX ::
Hm, nikjer ni tega. Sem povsod pogledu pa ni nikjer te kode...
- spremenil: XzupanX ()
| » | XHTML povezavaOddelek: Izdelava spletišč | 2105 (1847) | HardFu |
| » | Joomla 1.7 problemOddelek: Izdelava spletišč | 1457 (1236) | shovty |
| » | Objavljeni rezultati zunanje revizije Googlovega prisluškovanjaOddelek: Novice / Zasebnost | 6945 (6452) | fosil |
| » | Naprava za branje knjigOddelek: Kaj kupiti | 2912 (1913) | Firebat |
| » | Ikona v DelphijuOddelek: Programiranje | 1203 (1028) | skorc_norc |
