Prvi grafenski holografski optični disk
T-h-o-r ::
Scientists in Australia have succeeded in creating the first graphene-based optical disc. Owing to the magical properties of graphene, we’re not just talking about a Blu-ray or DVD disc that has had its recording layer replaced with graphene, either — we’re talking about holographic storage with absolutely monumental capacity, intrinsically high security, and apparently the ability to recover the data even when the discs are broken.
In this case, the Australians say they’ve reached a density of around 0.2 terabits per cubic centimeter, or 3.2 terabits per cubic inch. It’s hard to compare holographic to non-holographic storage, but hard drives are slowly creeping towards 1 terabit per square inch, while Blu-ray discs are a few orders of magnitude less, in the gigabits-per-square-inch range.
http://www.extremetech.com/extreme/1679...
black ice ::
Zanimivo mi je predvsem to, da se bo lahko obnovilo podatke tudi iz zlomljenih koščkov. Toliko o "ruskem" načinu uničevanja *khm* podatkov.
RejZoR ::
Si že kdaj videl uničevalnice diskov? Ko mlin zmelje disk praktično v prah. Tam ne moreš ničesar obnovit.
black ice ::
Nisem. Bom poguglal.
Edit:
1:50
  • spremenilo: black ice ()
Hayabusa ::
Kje se da kupiti kaj podobnega v Slo/Eu ?
black ice ::
Ko boš videl ceno te bo minilo (3895$).
Yacked2 ::
black ice je izjavil:
A to je cena tega uničevalca diskiv al bodoča cena tega novga optičnega diska ?
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
black ice ::
Cena uničevalca.
Brane22 ::
Mah, novinarsko nakladanje predhodno spinanih podatkov.
"Ogromna gostota" reda Terabit na _kubični_ cm. nato jo primerja z doseženo gostoto HDDjev na _kvadratni_ cm.
WTF ?
Kako naj to primerjam ?
msjr ::
Teoretično gledaš tako, da primerjaš vzameš medija kot 3. dimenzijo, sicer pa tudi v članku priznavajo, da je težko primerjat.
Meanwhile: blender vse reši :D
  • spremenil: msjr ()
Brane22 ::
msjr je izjavil:
Dobro, poglejmo tretjo dimenzijo. magnetni nanos na disku kot pravijo dosega 1Tb/palec ali nekje 0.15Tb/cm2
Njegova debelina je nekje 100 nm ali nekaj v tem razredu.
To pomeni 10 milijonov takih slojev za debelino 1cm. Kocka 1cm3 takega materiala bi torej lahko vsebovala 0,15Tb * 10.000.000 informacij ali nekako milijon in pol-krat VEČ kot tale zadeva.
Kako je potem tole neverjetna gostota ?
msjr ::
Brane22 je izjavil:
Hm, ja, samo do teh podatkov ne moreš priti, rabiš še čitalce vmes, po moje je zato neverjetna gostota. Sicer pa, živi bili pa vidjeli.
Grafen obljublja tudi zaslone
2520711 (16713) Mcsin
Samsung predstavil izboljšan Galaxy S5 (strani: 1 2 3 )
Oddelek: Novice / Android
10231046 (27076) MrStein
bar=kil?
Oddelek: Šola
162862 (2551) Ancalagon
Na obzorju tehnika zapisovanja enega terabita na kvadratni palec
186715 (5179) Jst
Prvo snemanje filma na holografskem disku kapacitete 1 Terabajt
82495 (2126) neres
