Forum » Strojna oprema » AMD Radeon R9-2xx
AMD Radeon R9-2xx
Skyman ::
naslednji teden lahko pričakujemo 290 in 290x.![]()
Kje si kupil kristalno kuglo?
Drugace pa:
Barring the recent reveal of MSI's Radeon R9 290X Lightning PCB, we've not come across a single custom-design R9 290 series card. Sources told ComputerBase.de that custom-design R9 290 (non-X) cards could launch first, in the mid/late-December thru January time-frame, and R9 290X could follow "later." One AIB partner which did not want to be named, attributed it to under-supply of the "Hawaii" silicon, and not any design defects that AMD is working to correct. The Radeon R9 290 (reference) is priced at $399.99, and the R9 290X for $549.99.
http://www.techpowerup.com/195371/custo...
290x se omenjajo po CES sejmu da pridejo na police oz vn.Sami CES sejem je pa od 7-10 januarja v Las Vegasu
- spremenil: Skyman ()
Ajnstajn` ::
Kyle_Bennett HardOCP Editor-in-Chief, 16.5 Years
R9 290/X AIB Cards
Just talked to AMD as well as three big AIB partners and AMD as well as one big AIB told me that we should expect to see custom R9 290 and 290X cards in etail the second week of December. FYI....
R9 290/X AIB Cards
Ajnstajn` ::
tak dolgo bojo mečkali, da nazadnje kupim nereferenčno pa custom vent zraven. Konec koncev, vprašanje, če se bojo dale referenčne odklenit na 290x
- spremenil: Ajnstajn` ()
Xserces ::
referenčne so zunaj zdaj... nereferenčne še pridejo.
Shybby ::
pa pri kateri ne zgubiš garancije če menjaš kuler?
ker je tale kar všečen..
http://www.techpowerup.com/195042/nzxt-...
Skyman ::
Kaj ste tako nestrpni,to je samo nastavek za vodno+ vodno kupis posebej lahko das gor corsair ali nzxt ali thermaltake itd.. to te pride cca 100€+
Shybby ::
nevem kaj so tak bedni da zgubiš garancijo če menjaš hlajenje.. že mesec dni + brez grafe ;/
Xserces ::
Zakaj? Ker se spravjo menat hladilnik taki ljudje k še šraufncigrja neznajo drzat... Pol pa crkne pa jokajo. Imel teden nazaj tak problem. Limal heatsinke na rame gor s ker nekim limom in so mu med igranjem dol popadal... se je sam pokadil iz rama.
- spremenil: Xserces ()
Xserces ::
nekaj časa nazaj jo je imel hoh.de za 450€...
Hayabusa ::
Recimo za ceno do 250E, katera grafična se sedaj za igre najbolj splača (p/p/ ratio) ?
Amd XX ali nvidia YY ?
Hayabusa ::
Gledam na hitro bencehe za igre iz te strani
http://ht4u.net/reviews/2013/sapphire_r...
amd R9 280X toxic je pri vrhu, vendar je cena 250+130 ;P.
GTX 770 je že bližje p/p/ pogoju, 250+40 in malce slabša napram r9 (Radeon HD 7970 je spet dražji od gtx 770).
- spremenilo: Hayabusa ()
Xserces ::
So vse nad 250EUR... najcenejša je http://www.hardwareversand.de/3072+MB/1...
280X ~270EUR + poštnina
760 ~200-230 + poštnina
klkkkkkkkkkk ::
280X 240-270EUR
Vmesne ponudbe imaš po 230EUR samo moraš vsak dan gledat
http://www.mindfactory.de/product_info....
- spremenilo: klkkkkkkkkkk ()
Xserces ::
v račun sem vzel malo "firme" ker nekateri ne pristanejo na club3d
Hayabusa ::
Pozabil omeniti, za primerjavo cen med modeli gledam dino.at cene.
klkkkkkkkkkk ::
Xserces ::
ostane sam 760... pol pa pogledaš še par reviewev in se odločiš za najtišjo ...
RC14 ::
Joj ste hecni nekateri, a vam še zdj ni jasno, da sta 760 vs 7950 in 770 vs 280 (7970 GHz) zelo podobne po zmogljivosti.
Ene prednjačijo v enih igrah, druge spet v drugih. Pa tudi če je katera rahlo hitrejša od konkurence, so razlike MAJHNE in se v igrah tistih dodatni 3-4 FPSji res ne poznajo. Men je čist vseen, al ma igra 45 al pa 49 FPSjev oz če ma ena 90 druga pa 100 FPSjev. Ko pa klecne ena, bo tudi druga, to je dejstvo. Gleda se samo cena, oz če je komu pomembna tišina pač da je kartica zelo tiha...... In oba taborja se PODOBNO NAVIJATA !!, pač moraš tudi imete nekaj sreče in nekak v povprečju se 7950 malo bolje navija od 760. Ampak set niso tako ogromne razlike, da bi si pulili lase zaradi teh par slikic razlike. Če je cenejša vzameš 7950 oz 7970, če je 760 cenejša, pač 760.
Glede na trenutno stanje, so cene za 760 in 7950 podobne, tk da je vseen kaj vzameš. Pred mesecem dni pa se je vsekakor bolj splačalo vzeti 7950, ker je bila ~ 40 eur cenejša od 760.
280X pa je trenutno v povprečju nekje ~ 20 eur cenejša od 770 in pač vzameš 280.
Čist enostavno, ampak nekateri tukaj bi si dali luknjo vrtat, ker ma sosed za 2 FPSja hitrejšo kartico od njega
:4770K@4.5GHz @ BeQuiet!Dark Rock Pro2; MSI Z87 GD65 Gaming; 16GB RAM:
::GTX 1060 6GB; SSD Samsung 840 EVO 250GB; SEAGATE 3TB+3TB+1TB; LG 27"IPS::
:::: XFX 850W Black Edition; X-Fi Titanium; Fractal Design ARC R2 ::::
- spremenil: RC14 ()
klkkkkkkkkkk ::
7950 se bolje navija od GTX 760 in je tudi pri 1150-1200 dosti hitrejša od ... vseeno se nesplača... No jaz bi gledal takole.. Če hočeš imeti fiziko potem greš GTX 760, če ne pa 7950...
Ajnstajn` ::
ja... in res ne vem zakaj je nisem vzel... mi je zdaj žal...
Zdajle je pa praktično nikjer ni za dobit pod ceno 600 eur... nikjer! (hd 7990)
Skyman ::
SuperVeloce ::
Kaj je s temi designi ventilatorjev (cooltech)? S sredine proti stranem lopatic zrak vleče?
Buggy ::
na embalaži je napisano 280x..
mas kar prav ja...sploh nisem bil pozoren, ocitno prevelika zelja...pa vidim kar zelim videti
drugace pa na zalogi ta trenutek R9 290 BF4, pa Gigabytka naj bi imela celo nekaj malo moznosti odklepa na 290x.
DHL 11€ v SLo in placilo mozno z PayPalom.
Buggy ::
Shybby ::
saj tole ima dino za cca 380.. pa 70 je dodatno hlajenje..
a potem ko bodo nereferenčni hladilniki gor bodo cene višje al niže, kako je ponavadi?
Skyman ::
in kaj teb tle zgleda hudo? Ista je kot vse prejšne windforce 450w pokur,overclockana je za 40mhz 15.9dba tišja od referenčne.Edino kar je hudo je cena 600$ pa da smo skos blizje relisu
Launch and price date were not mentioned but you can expect a price of around $600 US for the non-reference models when they launch around CES 2014 or earlier.
FlyingBee ::
maxwell pa na drevesu in se reži ... ne bi rekel, da je nov nm ali arhit., kot so naredili s 7970, ampak zdaj pa neref. šele 2 meseca po (ne samo papirni) splavitvi
cenovno pa se že nevarno približuje 780ti, tako da samo še za 290 brez x ostane upanje na senzacijo, ki je pa verjetno ne bo, saj ne živijo od P/P
- spremenil: FlyingBee ()
klkkkkkkkkkk ::
R9 290/X bo dobila boost z driverji in mantlom...
Potem se bodo pa tisti ki so kupili R9 290 režali NVIDIA fan boy clubu, ker bo R9 290 na nivoju GTX 780Ti
Xserces ::
Kaj ima AMD za odgovor Maxwellu? Ubistvu ne najdem nobenega pametnega roadmapa od AMDja
klkkkkkkkkkk ::
Odgovor
Pomoje je bolj maxwell odgovor R7/9 serijam...
Po štacunah se lepo vidi razliko, da se AMD kartice prodajajajo bolje...
In na srečo nas kupcev je AMD lepo zbil cene... in naredil best P/P ...
Trenutno ima AMD veliko boljše ponudbe od Nvidia-e ...
Še malo pa boš dobil 7850 1Gb za 100EUR ki z overclockom pride na rang stock 7950 .... Za 100EUR grafično je to odlično...
Buggy ::
7850 1Gb ze sedaj dobis za 110€ dobis pa tudi R9 270 za 146€ ...das dve v CF pa imas performance nad R9 290 ali GTX 780 :D...vmes, ko ne spilas pa se minas z cca 800 kH/s :D
Assass1n ::
A imajo R kartice isti razmak med luknjami kot 7xxx serija? Luknje za pritrditev hlajenja?
klkkkkkkkkkk je izjavil:
7850 2gb dobiš za 122€-130€ odvisno kater cooler hočeš....
a se sploh splača 2 gb na 7850, četudi overclockano?
galu ::
Sam en teaser... Še na zraku. Več pride v prihodnjih dneh (ko se naveličam BF4
). Čez vikend (najverjetneje) pa še primerjava z GTX 680.
BTW, grafa sploh ni tako nenormalno glasna na privzetih nastavitvah. Na 100% pa je seveda popolnoma druga zgodba.
Tako to gre.
| » | Katero R9 290? (strani: 1 2 )Oddelek: Kaj kupiti | 16064 (14034) | FlyingBee |
| » | Katero R9 280x/290 kupiti? (strani: 1 2 3 )Oddelek: Kaj kupiti | 44035 (38817) | chucki |
| » | NV GTX780Ti (strani: 1 2 )Oddelek: Strojna oprema | 19945 (18694) | klkkkkkkkkkk |
| » | Nvidia Geforce GTX 7xx (strani: 1 2 3 4 … 11 12 13 14 )Oddelek: Strojna oprema | 156234 (131246) | Pro_moted |
| » | Radeon R9 290X je hiter, vroč in požrešen (strani: 1 2 )Oddelek: Novice / Grafične kartice | 32709 (27175) | vaščan |
