MiniPC, hw NUC in Brix
trnvpeti ::
Nekje oktobra naj bi zaceli prodajati v3 NUC z hw cpu.
KOncno tudi usb3 in sata port
D54250WYx - i5-4250U (1.3Ghz-2.6Ghz) - HD5000
http://www.intel.com/content/www/us/...d54250wyk.html
http://www.intel.com/content/www/us/...d54250wyb.html
D34010WYx - i3-4010U - HD4400
http://www.intel.com/content/www/us/...d34010wyk.html
http://www.intel.com/content/www/us/...d34010wyb.html
Konkurenca pa Brix, hd4000, Intel Core i3-3227U 1.90GHz
http://www.tigerdirect.com/applications...
Se najava haswell brix
http://liliputing.com/2013/09/gigabyte-...
trnvpeti ::
Še test hw NUC 4250u
Poraba v idle 4.6W
http://www.legitreviews.com/intel-nuc-k...
Hayabusa ::
In cena $360, kar pomeni 360 Eur v EU ;((.
Za tak denar lahko uporabljam i5 4430 + 1x 3.5" hdd (poraba zaokrožena navzgor na 47W) vsaj 7.6 let, da pridem na 360 Eur porabe, kolikor stane intel nuc.
  • spremenilo: Hayabusa ()
trnvpeti ::
Kolk si pa dal za 4430
trnvpeti ::
4430 175eur
ena maticna miniItx, dp in hdmi kaksnih 100eur
ohisje miniItx kaksnih 80
picoPSU 120W kaksnih 50eur
Skupaj: kaksnih 400eur
Hayabusa ::
proc, h87 mobo in 2*4 gb rama 344 Eur s poštnino (hoh).
Ohišje in napajalnik sem uporabil obstoječe (ni za 27/4 "server").
ohišje s psu:
ali
ali
ali
http://www.lovecnacene.si/inter-tech-mi...
ali
Morda ujameš kakega na bolhi, drugače so kar draga roba, 50 je sam psu (vezje), napajalni "cigel/brick" stane še vsaj 30 E.
En fail intel nuca
One of the major additions to the new Haswell NUC boards is the addition of one internal SATA III data and power header! We are glad to see it, but it really sucks that the Intel chassis doesn't support a 2.5? notebook drive! Just to the left of the SATA header you'll see the front panel connections (only needed it you change to a 3rd party chassis) and an internal header for a pair of USB 2.0 ports.
Hayabusa ::
trnvpeti ::
ok minimalno 40eur za psu in ohisje
175 cpu
100 plata
315eur proti 360
sedaj pa ni taksna razlika, kot si hotel pokazati
Sej zadeva je res lustna, ampak ko vse skup vrzes, pa potegnes crto, je zelo draga zadeva.
Ja, pa odsotnost 2.5" mount placa je res fail.
trnvpeti ::
ja, intel pripravlja za jan14 popravek za 2.5" mount
bomo se vidli brix ceno
ja primerljiv pc tudi ne sestavis veliko nizje od te cene
pa i3 4010u, hd4400 je 280(namesto 360)
trnvpeti ::
ok, plata 1150 miniItx, hdmi, vga in dvi je 65eur
ti napajalniki podpirajo haswell C{6,7,8,9} state-e?
trnvpeti ::
novi brixi ne bodo imeli sata
1. The GB-BXi7-4500 has an Intel Core i7-4500U chip (1.8 GHz - 3 GHz)
2. The GB-BXi5-4200 has an i5-4200U chip (1.6 GHz - 2.6 GHz)
3. The GB-BXi3-4010 has the Core i3-4010U chip (1.7 GHz)
4. The GB-BXCE-2955 has the Celeron 2955U processor (1.4 GHz)
trnvpeti ::
nova intel NUC modela(H)
D54250WYKH and D34010WYKH
Razlike:
12.5mm visji
prostor za 2.5" disk visine max 9.5mm
54$ drazji
  • spremenil: trnvpeti ()
trnvpeti ::
novi NUC modeli
 novi NUC-i
novi NUC-i
2f4u ::
Za nuc ti men povej, kje se ga da rabljenega ali novega kupiti - cena je merilo!
Imel sem oglas da kupim pa ni bilo ponudb...
Mini pc?
367469 (112) Morenov
Intel NUC (strani: 1 2 )
7622638 (11213) Invictus
mini ITX računalnik (strani: 1 2 3 )
10428564 (24432) Dr_M
mini računalnik
295782 (4396) GenZNPC
ima kdo praktične izkušnje z mini pcji (v stilu intel nuc)
358873 (8009) Steinkauz
