Forum » Pomoč in nasveti » Nokia E51 se ne prižge
pacnik5 ::
imam problem da se mi Nokia E51 ne prižge naredi samo to:
Če kdo ve kako bi lahko to popravil??
Našel sem tele info ampak nimam pojma kako bi vpisal te ''kode''.( http://discussions.nokia.com/t5/Eseries... )
Pirateforever!
pacnik5 ::
nimam.. najdu sem tole sam nevem kako bi vnesel
1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list.
2. *#7370# - Reformat your phone
3. This you perform as a last resort. Nothing else is working.If the phone is dead proceed with reflash if not, turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
re-flash - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons
Pirateforever!
- spremenilo: pacnik5 ()
...:TOMI:... ::
Ko boš kupil nov telefon pomisli na možnosti za varnostni kopijo.
To so: m:rokovnik, gmail, računalnik, sim kartica, varnostna kopija na sd kartici...
Tomi
| » | Kateri telefon z dobro kamero? (strani: 1 2 )Oddelek: Mobilne tehnologije | 22355 (20752) | denabiker |
| » | Samsung galaxy note BRICKOddelek: Mobilne tehnologije | 4623 (4110) | CaqKa |
| » | nokia n85-accelerometerOddelek: Mobilne tehnologije | 4383 (4260) | WODAK |
| » | HTC Tattoo (strani: 1 2 )Oddelek: Mobilne tehnologije | 28699 (26062) | PeternelG |
| » | reinstall novega OS na nokio 6670Oddelek: Mobilne tehnologije | 1255 (1172) | koyotee |
