Fotke iz PPS-jev.
Fotke iz PPS-jev.
Azz_Kikr ::
Mi lahko kdo pove, če se da kako slike iz PPS predstavitev posamezno izvzeti? Imam nek pps fajl, pa bi rad eno izmed slik shranil posebej... Thanx vnaprej, Azz_Kikr
If sometimes you feel yourself little, useless, offended and depressed, always remember that you were once the fastest and most victorious sperm in your group!
  • premaknil: ToniT ()
ToniT ::
Odpri prezentacijo v power pointu->desni klik na sliko ->shrani kot sliko(save as picture)
StratOS ::
ali pa copy :)
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
boštjan ::
simpl ne8-)
Printscreen V Linuxu
Oddelek: Operacijski sistemi
51931 (1408) Ribič
Shranjevanje fotk v Adobe Photoshop CS3
91438 (1103) Jazzie
problemi z slikami
132077 (1926) cegu
RAW to JPEG
Oddelek: Programska oprema
83183 (3014) kuglvinkl
Computer Forensics - cache, logs, itd..
51414 (1266) madmitch
