Forum » Pomoč in nasveti » XAMPP namestitev napaka
miha670 ::
prosim rabim pomoč pri xxmp ko zaženem inštalacjo mi napiše "important! Because an activated User account Control (UAC) on your system some functions of XAMPP are possibly restriced. With UAC plase avoid to install XAMPP to C:/Program Files (x86) (misssing write permisssions). or deactivate uac with msconfig after setup" to mi napise ko pa pr kolegu instaliram je pa use u nulo program rabim za call of duty 2 (cod2) da jim bo hitreje nalagalo mode oz dol vlekl mam svoj privat server
- spremenil: Mavrik ()
Goran's Blog ::
Poskusi takole:
To disable UAC go to
Start>Control Panel>User Accounts
there you will find an option
Turn User Account Control on or off
just click on it and uncheck
User Account Control to help protect your computer
click OK.
If you also have IIS installed and active then you will not be able to run XAMPP on port 80 and SSL on port 443.
Simply disable IIS as you won't need it if you install XAMPP and Apache.
To disable IIS go to
Start>Control Panel>Programs and Features
on the leftmost side you will find an option
Turn Windows features on or off
Internet Information Services
click OK
and then restart your computer.
click OK.
click OK
miha670 ::
najlepsa hvala zdej mi pa dela samo neki bi te se proso ce mi bi znal povedat kako odpreti porete znam odpirat
za serverje use sm ze odpru tu pa sm probo pa mi ne rata protov odpret za xampp poskuso sm pa ze če bi mi lahko prosim pomagal
Goran's Blog ::
miha670 ::
ne. js sm odpro porte za xampp in sm sm si use naštimo po navodilih za cod 2 da ko se drugi pridružijo da jim vleče mode hitrej ne samo z 14 kb/s kr ma call of duty2 neko blokado zato pa ta program pol nastima da vlece z vec
in sm odpro porte in se kr ni delal pol pomeni da portov vredo nisem odpro ?
zee ::
Napisi se enkrat v slovenscini z uporabo locil. Tvoje sporocilo je ena besedna driska brez repa in glave.
zee
miha670 ::
vredu je NAJLEPŠA VAM HVALA ZA VAŠ TRUD SM ZRIHTO ZDAJ USE LEPO DELUJE NAJELPŠA ŠE 1-KRAT HVALA ZA POMOČ
| » | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 4425 (3691) | dukedl |
| » | administrator problemOddelek: Pomoč in nasveti | 2163 (1472) | Valentin |
| » | Koliko placa za Visto?Oddelek: Operacijski sistemi | 2233 (1883) | Pesimist |
| » | Vista problemOddelek: Pomoč in nasveti | 1450 (1337) | Klemzz |
| » | Izginil standardni zagon? !!Oddelek: Operacijski sistemi | 1565 (1457) | CaqKa |
