Forum » Pomoč in nasveti » Excel -
Excel -
petkofak6527 ::
Živjo,
zanima me, kako bi v Exelu naredil funkcijo, ki bi mi iz ene celice v katero vpišem datum po preteku 11 mesecev drugo celico obarvalo iz zelene na rdečo barvo?
Hvala za pomoč
Luka
Hvala za pomoč
Luka
http://www.contextures.com/xlCondFormat...
tole si si že pogledal?
- spremenil: mtosev ()
petkofak6527 ::
Za označevanje je to točno kar rabim. HVALA
Kako pa bi izgledala funkcija ki bi mi npr. od nekega fiksnega datuma (npr. 14.5.2014) odšteval dejanski/trenutni datum. Ali excel zna prebrat sistemski datum ki je nastavljen v windowsih in potem odšteje vpisan datum v excel tabeli?
Hvala za pomoč.
Hvala za pomoč.
očitno zna, za funkcijo ti ne morem pomagati, ker na kompu trenutno nima excela
Using Date Functions in Excel
Related Tutorials: More Excel Date Functions
There are a number of date functions available in Excel. Depending on your needs, you can use a date function in Excel to return the current date, the current time, or the day of the week. This article covers using the most commonly used date functions used in Excel: =TODAY() and =NOW()
Like all functions in Excel, entering date functions is very straightforward - just type in the function in the cell where you want the date or time to appear.
Computer Serial Date
There are no arguments to enter for the =TODAY() or =NOW() functions. Both of these date functions draw their data from the computer's built-in clock. Computers store the date as a number representing the number of full days since midnight January 1, 1900 plus the number of hours, minutes, and seconds for the current day. This number is called a serial date.
=TODAY()
This function returns the current date. To display the date in a different format than the default:
Click on Format > Cells in the menus to bring up the Format Cells dialog box.
Click on the Number tab.
Select Date in the Category window.
Pick from the available formats in the Type window.
=NOW()
This function returns both the current date and time. To change the display to show just the date, follow the steps for the =TODAY() function above.
To change the display to show just the time:
Select Time in the Category window.
=TODAY()
=NOW()
| » | [Assembler] scanf How-ToOddelek: Programiranje | 2273 (2200) | c0dehunter |
| » | Javascript - izračun razlike v datumihOddelek: Programiranje | 2473 (2328) | kogledom |
| ⊘ | Bill Gates = Satan?Oddelek: Loža | 2277 (2200) | Ziga Dolhar |
| » | Windows Commander 5.1Oddelek: Novice / Operacijski sistemi | 3514 (3514) | darh |
| » | Pomoč pri MySQL in PHP...Oddelek: Programiranje | 2404 (2272) | darh |
