[Opera] Unable to complete secure transaction
Jst ::
Od včeraj se mi na računalniku ni spremenilo nič - razen Windows popravki.
In ko v Operi vpišem https://slo-tech.com mi izpiše zgornjo napako.
Detaji:
You tried to access the address https://slo-tech.com/, which is currently unavailable. Please make sure that the web address (URL) is correctly spelled and punctuated, then try reloading the page.
Secure connection: fatal error (1066)
Unable to verify the website's identity (OCSP error).
The response from the online certificate validation (OCSP) server was too old.
Probal sem izklopiti vse privacy extensione, restart računalnika in vseeno mi slo-tech ne dela, medtem, ko mi ostale strani delajo normalno. To pišem iz IE.
Ideas?
  • spremenil: Jst ()
SasoS ::
Same here...nisem nič nalagal, danes prižgem in ne dela.
Tudi meni. Na dveh različnih pcjih in lokacijah.
IE dela ok. :8)
Jst ::
OSCP - Online Certificate Status Protocol
The Online Certificate Status Protocol (OCSP) is an Internet protocol used for obtaining the revocation status of an X.509 digital certificate. It is described in RFC 2560 and is on the Internet standards track. It was created as an alternative to certificate revocation lists (CRL), specifically addressing certain problems associated with using CRLs in a public key infrastructure (PKI). Messages communicated via OCSP are encoded in ASN.1 and are usually communicated over HTTP. The "request/response" nature of these messages leads to OCSP servers being termed OCSP responders.
vir: wiki: Online Certificate Status Protocol @ Wikipedia
Malo sem googlal in sem videl na Opera community (forumu), da imajo nekateri ljudje probleme s tem. Nekaterim pomaga samo restart Opere. En uporabnik je napisal, da mu je pomagalo "delete all content." Ampak to so zapisi iz leta 2012, pa še to za random strani, ko se jim to začne izpisovati med brskanjem.
Tako, da je nek problem (bil) v Operi. Vendar ker imamo probleme samo z slo-techom, se bolj nagibam, da je problem s tem forumom, kot pa z Opero.
Bil bi vesel, če bi ljudje, ki skrbijo za forum, povedali kaj več. Sicer sem jaz developer, ampak nisem v spletnih vodah...
Moderatorji: a bi združili temi, ki imata skoraj enak naslov in enako vsebino? Najbolje, da iz te teme v drugo, ker je bila tista prej. (ponavadi prej pogledam, če že obstaja tema, a je nisem videl v oddelku "Slo-Tech")
veper je v tisti temi podal rešitev, ki pa odpravi samo posledico, ne pa vzroka:
veper je izjavil:
Dejansko ne dela več v Operi, celo jutro sem se hebal s tem.
Rešitev je pa tale:
opera:config#SecurityPrefs|OCSPValidateCertificates
izključiš, restartaš Opero in spet deluje.
  • spremenil: Jst ()
BaToCarx ::
Jutro.
In pa reload strani, dela. Zanimivo je da se je pojavilo tam ob 2-3 zjutraj, pa sem mislil, da samo kaj spreminjajo, v ostalih je delovalo, samo v Operi ne restart browserja, pa tko ni pomagal. Sm dal za hec http namesto https, ma je redirect na https, potem sem pa delal drugo, šel spat v upanju da se bo "samo" popravilo, pa spet nič. Sem si rekel da je sigurno koga na ST zmotlo, pa pogledam in ste našli, tako da mi ni blo treba brat kaj sploh naj bi bil OCSP pa če je v opera:config.
Me pa vseeno zanima zakaj je zmotilo samo Opero ostale pa ne.
Alexius Heristalski ::
Pofočk za težavo. Opera 12.15 Build 1748
Jst ::
Mene tudi. Bomo Opero vprašali...
BaToCarx ::
Ker prva napaka je bila "Internal communication error"
sash69 ::
Enako pri meni - na 3h različnih lokacijah in na 3h različnih računalnikih. Z Opero na ST od včeraj ne morem.
So, Eclipse and Xdebug walk into a bar, and then my Apache server dies.
Jeeeeeee, zdaj dela.
BaToCarx ::
Jep samo kaj je bil razlog da je 24h bil "blacklistan" ?
Hayabusa ::
Alexius Heristalski je izjavil:
Nope, dotična verzija je izšla 3 aprila http://ftp.opera.com/pub/opera/win/1215/
Na ST strani so nekaj spremenili.
BaToCarx ::
Danes spet "Internal communication error" na strani in pa "Unable to complete secure transaction" na mobilni verziji.
Še sreča da deluje samo kljukca stran in save, pa reload.
Se je še komu to zgodilo,
Version
12.16
Build
1860
Platform
x64
System
Windows 7
Dela nazaj, tudi če je obkljukano. :)
Nop ne dela še, je blo keširano. :x
  • spremenil: BaToCarx ()
isto tu, bilo na katermu pcju/lokaciji
vorantz ::
+1 na problem in rešitev
Jst ::
Spet ta napaka, ja... :/
mr1two ::
+1
Sem spet popenil okrog tega... še dobro da deluje zgoraj opisani postopek. Hvala.
42
SasoS ::
Zadnje nekaj dni počasi odpira ST v Operi. CPU gre na 100% (12.5% na i7). Včasih je rumena ikona na SSL, spet drugič pravi da je stran insecure.
A bo treba zamenjat browser :(
tintorel ::
Tudi meni se dogaja isto, na MintLinux/Opera. Sem inštaliral Chromium zaradi tega.
Hayabusa ::
Katera verzija ?
SasoS ::
Zadnja "taprava" 12.16.
Hayabusa ::
Hmm, meni dela ok.
Imaš nameščene te 3 certifikate ?
"Fraud and malware protection" imam na off.
imena certifikatov:
www.slo-tech.com
StartCom Class 2 Primary Intermediate Server CA
StartCom Certification Authority
// zadnja 2 najdeš tu https://www.startssl.com/certs/
Se zgodi, če si na ST https strani, kjer imaš v temi na forumu linkane slike iz http://shrani.si/ .
Prveri če ta tema kaj pomaga:
Opera: Unable to complete secure transaction
  • spremenilo: Hayabusa ()
Tudi meni odpira počasi, isto Opera 12.16.
SasoS ::
Se opravičujem za necroposting, ampak tudi Opera je oživela od mrtvih in izdala 12.18 za vse stare prdce (vključno z mano :D).
Odpravljena je težava s počasnim odpiranjem SSL in Unable to complete secure transaction na določenih straneh.
Mimogrede, zdaj sem šele opazil da ima ST 2 certifikata. En je ecdsa-with-SHA256, drugi klasičen SHA256 (4096bit key). 12.18 zdaj podpira ecdsa certifikate, zato se tudi odprejo SSL strani, ki se prej niso (ker očitno niso imele fallback sha2 certa). Ni pa čisto jasno od kje je bil zamik, mogoče zaradi razmeroma dolgega ključa. fedoraproject.org naprimer je ravno tako imel zamik pri odpiranju, pa nima EC certifikata (ima pa 4k pkey). Ali pa zaradi cipherjev, 12.18 ima zdaj namreč vse novejše cipherje (EC, GCM...).
Anyway, upam da zdrži vsaj do neke pametne verzije Vivaldi-ja :D
Sporoči nam ko bo 12.18 za linux ...
Opero bi kupili Kitajci
Oddelek: Novice / Brskalniki
4116810 (14421) tabonir
Opera Mini
61362 (1093) harvey
Oddelek: Slo-Tech
111760 (1609) dr.Akula
Izšla Opera 11.50 (strani: 1 2 3 )
12434551 (28426) primar
Opera 9 (strani: 1 2 3 4 5 )
23625888 (17636) R33D3M33R
