Forum » Strojna oprema » Miška na PS/2 ali USB?
falotXP ::
Ali je kakšna razlika, če imaš miško priklopleno prek USB vodila ali PS/2 vodila? (mislim na delovanje miške)
- premaknilo: bastadu ()
andper ::
Če ti angleščina ni problem:
Upam, da ti kej pomaga.
Why is USB better? Simple answer, for a simple question, a USB mouse samples itself somewhere about 125Hz. A really good ps/2 mouse will sample itself at 80Hz, and a crappy ps/2 mouse will sample itself at 40Hz, a Serial mouse will sample itself at about 15Hz. The faster the Hz, the smoother the mouse. Some people might say something like, "But, I have a PS/2 mouse and I run PS/2 rate at 200Hz, isn't that faster than USB?" Well my answer to that would have to be Yes, because it is sampling a lot higher, but then I would have to say No because I have PS/2 mouse on my other system, and I will never sample my PS/2 mouse any higher than 100, simply because 200 makes the mouse too slow, and seem to not be half as smooth as 100 or a USB mouse, simply I think PS/2 rate is basically lieng to everyone, I think as high as a PS/2 mouse can go is 100Hz. Anything past that and the mouse stop functioning correctly.
| » | Katera miška je najboljsa?Oddelek: Strojna oprema | 2402 (1989) | Matek |
| » | Linux / netOddelek: Pomoč in nasveti | 2057 (1730) | roscha |
| » | Bios 8rda+Oddelek: Navijanje | 1351 (1249) | kuglvinkl |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2613 (2209) | Swiwer |
| » | Miš na USB ali PS2?Oddelek: Strojna oprema | 1417 (1216) | Tr0n |
