TEZAVA PRI MINECRAFTU (windows 7)
knipser10 ::
pozdravljeni!!!
vprasal bi zakaj ko prizgem minecraft mi napise bad video driver ceprav sem jih ze (posodobil.
napise mi pa takole:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 24.2.2013 18:44
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows XP (x86) version 5.1
Java Version: 1.7.0_13, Oracle Corporation
Java VM Version: Java HotSpot™ Client VM (mixed mode), Oracle Corporation
Memory: 459684432 bytes (438 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT bf2af1c3 ----------
Hayabusa ::
Napiši HW konfiguracijo.
knipser10 ::
kje pa to dobim???
ati readon 9550
  • spremenilo: knipser10 ()
dottor ::
Na tej grafični pa zelo dvomim da bo delal minecraft...
Ne zazna R.class -android
Oddelek: Programiranje
171749 (1587) Marat
[Android]Vprasanje glede GUI ter pripadajoce XML datoteke
104426 (4312) KernelPanic
java datapool - derby
62935 (2784) jlpktnst
tomcat in datasource
132673 (2430) infiniteLoop
Java- hibernate.properties not found
112280 (1780) xsenon
