Forum » Strojna oprema » Neunicljivi LowLevel Password?
CR ::
Nism vedu tocn, kak bi dal temi naslov.
Pa ne ciljam zdej na BIOS password, ki se ga da seveda zbrisat tak, da das baterijo vn...
Pa naj kr citiram eno bukvo (Neka bukva Linux Security Administration al neki takga):
Another type of hardware password (the Privileged Access Password, or PAP), available on some computers, stores another password in nonvolatile memory. If someone clears the POP (Power On Password [to je ta password, na katerega mi mislimo, ko recemo boot password]) (by removing the CMOS battery or shorting the jumpers), when the system reboots it automatically compensates by promoting for the PAP - so either way, a password has to be provided to boot the computer. (The PAP can also be used to reset the Power On Password if the user forgets the POP.) There is no way I know of to defeat this password, which is good. But, as a result, it means that if you forget your password you must throw out the motherboard and buy another one!
Additionally, some hard drives contain yet another password, which is passed to the nonvolatile memory before the drive will even spin up. If you forget this one, the hard drive will not operate - you will need a new one - but at least you can be sure that the files contained therein are secure.
A vi vete za kej takga? Js to prvic slisim.
CR ::
To pa ni bil odgovor, ki sm ga pricakval...
Sorry, ampak take odgovore je znala ze moja babica izjavljat:"Vse se da ce se hoce..."
Odgovori naj bi bli poucni - zato pa so odgovori, ker odgovarjajo na vprasanja. Kadar pa nekdo zastavi vprasanje, navadno tistega ne ve...
Sandi79 ::
Pač to je iz trte izvito !
Če že govoriš o bios passwordu
Default nastavitva nima passworda!
V biosu ni nikakršnega znaka o "passwordu"!
Oziroma bios je sam "password" !
Zoidberg ::
Ja take passworde sem videl na policijskih prenosnikih. Tos epravi obstaja. Aja to sem videl na 286-ki.
LP Zoidberg
LP Zoidberg
Just keep on trying, keep on flying. I will be the light.
| » | Supervisor BIOS in HDD password reset?Oddelek: Pomoč in nasveti | 2653 (2378) | solatko |
| » | Reset biosa na HpOddelek: Strojna oprema | 2460 (2287) | RiNC |
| » | Diagnostično orodje za WDOddelek: Programska oprema | 5029 (4889) | clovk |
| » | Odkrit nov način pridobitve sistemskih privilegijev v VistiOddelek: Novice / Varnost | 7370 (4659) | iveco18 |
| » | Skrivanje geselOddelek: Izdelava spletišč | 3705 (2945) | Tr0n |
