intel C2D L9400 turbo frekvenca????
krneki0001 ::
Eno vprašanje za tiste, ki se na to bolj spoznajo;
Ali ima procesor v prenosniku X200 tablet tudi turbo frekvenco? Gre za procesor C2D L9400 s 6mb cacheja. Namreč ko ga obremenim se dvigne frekvenca na 2.16GHz, čeprav naj bi deloval samo na 1.87GHz, nikjer pa ne najdem podatka, da bi lahko presegel to frekvenco.
Hvala za odgovore.
amigo_no1 ::
http://www.cpu-world.com/CPUs/Core_2/In...
verjetno je tole:
http://www.cpu-world.com/Glossary/D/Dyn...
Intel Dynamic Acceleration technology (IDA) is a feature that boosts CPU performance when the CPU is running single-threaded applications. This is achieved by temporary increasing frequency of one CPU core when another CPU core is idle, i.e. when the second CPU core is in Deep Sleep or lower power state. How much the frequency is increased depends on front-side bus speed of the CPU:
533 MHz FSB - by 133 MHz
800 MHz FSB - by 200 MHz
1066 MHz FSB - by 133 or 266 MHz
krneki0001 ::
Jap, single-threaded aplikacija je pa bila (ruby v command promptu). Zanimivo.
Hvala.
acer aspire 5315 procesor
323422 (3101) jonyyy
Računalnik
474217 (3406) aleksander4
Težave po menjavi procesorja - laptop
364135 (3914) amigo_no1
Nadgradnja procesorja - prenosnik
252684 (2580) einstein :P
Rad bi zamenjal procesor na laptopu
313212 (2455) zee
