Forum » Operacijski sistemi » Win 7?
Win 7?
klihk ::
Če to nabavim: Microsoft Windows 7 Service Pack 1 32/64-bit (Multilanguage) - DreamSpark ali tega: Microsoft Windows 7 Language Pack 64-bit (English) ali imam notri cel Win 7 ali je to le nek dodatek zanj?
- premaknil iz Programska oprema: bluefish ()
hmm23 ::
klihk ::
Pod datoteko piše pa to:
Microsoft Windows 7 and Windows Server 2008 R2 Service Pack 1
Windows 7 and Windows Server 2008 R2 SP1 helps keep your PCs and servers on the latest support level. It also provides ongoing improvements to the Windows Operating System (OS), by including previous updates delivered over Windows Update as well as continuing incremental updates to the Windows 7 and Windows Server 2008 R2 platforms based on customer and partner feedback. This enables organizations to deploy a single set of updates.
Windows 7 and Windows Server 2008 R2 SP1 will help you:
Keep your PCs supported and up-to-date
Get ongoing updates to the Windows 7 platform
Easily deploy cumulative updates at a single time
Meet your users' demands for greater business mobility
Provide a comprehensive set of virtualization innovations
Provide an easier Service Pack deployment model for better IT efficiency
Sicer sem začetnik in to prvič iščem, ampak mislim, da je cel OS Win 7 notri, prosim samo še za potrditev Hvala
Kaj pomeni DreamSpark?
jest10 ::
klihk ::
sem opazu, to: Microsoft Windows 8 Debug/Checked Build 32-bit, pa je zihr cel Win8?
Description:
Microsoft Windows 8
Windows has been reimagined to focus on your life. The beautiful, fast, and fluid design is perfect for a range of hardware: from compact, touch-enabled tablets and lightweight laptops, to PCs and large, powerful all-in-ones with high-definition screens. It's smooth, intuitive, and gives you instant access to your people, apps, and stuff, so you spend less time searching and more time doing.
You'll love browsing through the Windows Store and downloading apps to help you work more efficiently, or installing the latest games so you can compete with friends. Apps can work together, too, so you can share photos, maps, contacts, links, and whatever else you want.
No matter what you want to do, you can get it done quickly in Windows 8. Whether you're completing a project, playing a game, or reading a book, with Windows 8, you can use touch, mouse, and keyboard together--seamlessly--to do what you want, the way you want. No need to choose one or the other. It starts quickly and it's cloud-connected so you can access your photos, documents, and settings on any Windows 8 PC.
Description:
Microsoft Windows 8
- spremenil: klihk ()
undertacker ::
Imam nenavaden problem pri formatiranju win7. Težava je takšna da ko pridem v menu da bi formatiral win7 mi ne deluje tipkovnica in miška. Sem probal z drugo miško pa je težava enaka. morda kdo ve kaj bi bilo narobe?
- spremenil: undertacker ()
| » | Windows 8 že na MSDNAA (strani: 1 2 )Oddelek: Operacijski sistemi | 18087 (12875) | finpol1 |
| » | Windows licenceOddelek: Operacijski sistemi | 1886 (1678) | techfreak :) |
| » | Windows 7 SP1Oddelek: Operacijski sistemi | 3576 (2449) | gorenjc |
| » | Windows Server 2008 R2 na vmwareOddelek: Operacijski sistemi | 2880 (2634) | _Dejan_ |
| » | Windows 7 je tu (za razvijalce in študente) (strani: 1 2 3 4 )Oddelek: Novice / Operacijski sistemi | 29376 (18027) | ;-) |
