Forum » Zvok in slika » nakup slušalk
nakup slušalk
ohrovt ::
okej vem da je o tem že ogromno napisanega, ampak nekako ne najdem tega kar hočem. Torej, nabavil bi rad nove slušalke. Cenovni rang tam do max 50-60e, raje cenejše. Če dobro argumentirate, da so ene dražje bistveno boljše, se pustim prepričati. Uporabljam iPod. Ne maram slušal, ki gredo neposredno v uho. Kvaliteta zvoka je bolj pomembna od izdelave. Aja zvrst glasbe, vse razen komerciale.
hvala za predloge.
A.
hvala za predloge.
A.
- spremenil: ohrovt ()
ST-777 ::
Pri prenosnih predvajalnikih glasbe je zelo pomembna impedanca slušalk, če ta ni ustrezna, je glasnost slušalk prenizka ali previsoka. Previsoko glasnost seveda lahko znižaš z gumbom za glasnost. Če pa je glasnost prenizka, imaš problem.
Več o tem, so povedali na forumu amazon.co.uk:
"To those who still can't get enough volume: it may be that the impedance on your headphones is too high. For example my 32 Ohm headphones are only just loud enough. There are plenty of headphones, particularly the more expensive, that have higher impedances than that. You also shouldn't go too low: 16 ohms is the minimum.
(Older Ipods have almost the reverse issue: too low an impedance and you get bloated bass and lack of highs (which is incidentally why a clip+ requires a minimum of 16 ohms) . Ipods have more powerful amps so you should stick with a minimum of 55 ohms to see good performance in an older ipod.)"
| » | JBL zvočniki z Yamaha Receiverjev, pomoč!Oddelek: Zvok in slika | 2078 (1629) | Scorpy84 |
| » | Naglavne slušalke (strani: 1 2 )Oddelek: Pomoč in nasveti | 31588 (21383) | jaot |
| » | Logitech G430 - Glasnost porazna..Oddelek: Zvok in slika | 3470 (2954) | iDare |
| » | dobre poceni slušalskeOddelek: Pomoč in nasveti | 1412 (1264) | Ryker |
| » | Velika in majhna impedancaOddelek: Zvok in slika | 5719 (5493) | kucho |
