ExploitShield
ExploitShield
denial ::
Dismantled
Zanimivo branje.
SELECT finger FROM hand WHERE id=3;
RejZoR ::
ExploitShield je drugače stranski projekt (bolj za hobi kot ne) Pedra Bustamante, ki je vodja projekta Panda Cloud AV.
Je pa tud tko, sej za vse varnostne sisteme pravijo da so bedni hacki ampak kot se je izkazalo v primeru npr ThreatFire oz Cyberhawk-a pred tem je da so bili kljub vsemu izjemno učinkoviti.
denial ::
S tem tipom sva bila celo v kontaktu, ko sem pred ~5 leti Pandi reportal EoP bug v njihovem produktu. Doh, always the same dudes circulating in security circus :)
  • spremenil: denial ()
denial ::
Time to grab some pop corn and read ExploitShield response to Trail of Bits analysis: KLIK
And guys, everything you know is wrong. I learned today that "security by obscurity" actually means you keep your product private instead of releasing it publicly.
Anti-virus programi (strani: 1 2 3 4 … 48 49 50 51 )
2536748577 (10266) fikus_
Izbira antivirusnega programa
285460 (4769) opeter
AV za starejši PC
172192 (1943) iloveboobz
Kingsoft Antivirus 2012 izšel! (strani: 1 2 3 )
12831936 (27548) alexz
