Težave z Računalnikom!
mkos2 ::
Živ!
Problem je v tem, da se mi računalnik sesuva. Testiral sem proc, grafično, sumim pa rame med pregledom le teh se tester ni odzval.?
Mainboard : ASUSTeK COMPUTER INC. SABERTOOTH 990FX
Chipset : RD890 PCI to PCI Bridge (external gfx0 port B)
Processor : AMD Processor @ 3612MHz
Physical Memory : 16384MB
Video Card : AMD Radeon HD 7800 Series
Hard Disk : Western Digital WD15 EARX-00ZUDB0 SATA Disk Device (1500GB)
DVD-Rom Drive : ATAPI iHAS122 C
Monitor Type : Samsung S24B370 - 24 inches
Network Card : Realtek Semiconductor RTL8168/8111 PCIe Gigabit Ethernet Adapter
Operating System : Windows 7 Home Premium Home Edition Media Center 6.01.7601 Service Pack 1 (64-bit)
DirectX : Version 11.00
Windows Performance Index : 5.9 on 7.9
Izpiše mi tole napako!
Napaka 1
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2012-09-14T22:20:55.340420700Z
EventRecordID 1204
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Cyberx-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
Vsem hvala za koristne informacije ;)
Mkos2
  • spremenil: mkos2 ()
6151 ::
lahko je tudi napajalnik, povej kakterega imaš.
7900X3D | 32GB | 6800 | 4 TB
mkos2 ::
Imam pa 650 Watni napajalnik.
mkos2 ::
Mašina je nova 1dan. Sestavljena je bila na sestavi.si. Zagotov so neki zajebal, da ni dost gor dan proc al pa so slabi kontakti nastal med prevozom po pošti.
mkos2 ::
Problem rešen, driver za zvok od relateka se je tepu z amd driverjem za zvok. Tukaj mate vse napisan kaj morte narest.
povezava
mkos2 ::
mkos2 je izjavil:
povezava
Pri meni ne deluje, sem testiral in se mi je ponovno sesu.
amigo_no1 ::
mkos2 je izjavil:
Bolj podrobno ne gre ?
cpu-z, naredi screen prvega zavitka.
Daj bios na default.
Tole poženi:
http://www.ocbase.com/
  • spremenilo: amigo_no1 ()
mkos2 ::
 Cpu
Cpu
pviran3 ::
Poglej event loge, če imaš kake errorje, mogoče kaj več piše
mkos2 ::
 Napajalc
Napajalc
amigo_no1 ::
Si zagnal occt ?
in še tole lahko:
https://slo-tech.com/forum/t535279/p372...
mkos2 ::
 Tester z geek
Tester z geek
15min sem testiru grafo.
amigo_no1 ::
Occt tudi (označi "use all logical cores" ?
mkos2 ::
mkos2 je izjavil:
Napajalnik Silentpower LCgp3-W v2,3
KER NATEG http://www.lovecnacene.si/mesano-napaja...
Nategnil so me za 100Watov!!!
amigo_no1 ::
Kdo te je nategnil ?
mkos2 ::
amigo_no1 je izjavil:
Nekje pise da je dejansko 650w nekje pa da ni.
Iz sestavi.si
amigo_no1 ::
Kdo ti je predlagal ta psu za amd fx-8120 sistem in hd 7800 grafično ?
http://www.sestavi.si/index.php/item/di...
Tokovi na posameznih linijah:
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
Haha, tole je 400W psu.
mkos2 ::
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
Nobeden, tam sem ga označil kot da je 650 watni. Dal pa sem 57.95 €.
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
Maš kakšen dokaz da je to dejansko 400 watni.
mkos2 ::
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
Uporabil sem program PSUcalc pa mi je narocunal 500w vse skupi da porablja komp. Tko da je 650 watni v kišti.
mkos2 je izjavil:
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
+3,3V 35A
+5V 40A
+12V1 19A
+12V2 19A
Za grafiko pa isto, sem ze studiral, ce bi vzel samo 1GB pa sem raj tole vzel.
dzinks63 ::
Priznane firme prodajajo podobno zmogljive, oziroma zmogljivejše napajalnike pod dost nižnjimi nazivi,
npr.: EMD425AWT II
+3.3V +5V +12V1 +12V2 +12V3 -12V 5Vsb Total Power
20A ... 20A... 22A ... 22A... 22A... 0.6A... 3A ... 425 W
120W ............... 396W (33A) ...... 7.2W .....15W
mkos2 ::
pviran3 je izjavil:
Primer napake:
Event 41, Kernel-Power
amigo_no1 ::
HD 7800 modela grafične ni.
Obstajata modela 7850, 7870.
Katero imaš ?
Poraba grafičnih 2Gb:
96 in 115 W
http://www.techpowerup.com/reviews/AMD/...
podoben podatek:
http://www.guru3d.com/articles-pages/ms...
Imaš priklopljeno 6 pinsko napajanje za grafično ?
Poraba cpu fx-8120:
zgornji desni graf, kjer se obremeni samo cpu
244W , ti imaš še malo navito na 3.6, lahko dodaš še kakšen Watt
http://www.overclockers.com/amd-fx-8150...
Worst case scenario:
115+244 = 359W (brez hdd in ramov) , kišta se sesuje.
Torej ?
mkos2 ::
hd 7850 oc
Proc je navit na 4,2 Ghz v strcun so ga tok navil.
mkos2 ::
mkos2 je izjavil:
hd 7850 oc
sej predvidevam da so to nardil.
mkos2 ::
Katero imaš ?
96 in 115 W
podoben podatek:
Poraba cpu fx-8120:
Torej ?
Mam pa 6-pinski preklop pri grafki.
mkos2 ::
500 w za grafo, 250 watu za proc mam pa samo 650 watni napajalnik pol pa vemo kok je ura.
dogo ::
mkos2 je izjavil:
To je poraba celotnega sistema in ne posameznih komponent.
Ali bo napajalnik zdržal (550W)? RX 480, CPU AMD 8350... (strani: 1 2 )
5613778 (12727) tikitoki
Kateri napajalnik za Gigabyte Radeon HD 7950 WindForce 3X 3GB GDDR5 (strani: 1 2 )
8111214 (10463) Pesimist
Kateri napajalnik kupiti (strani: 1 2 )
7512616 (10484) Tomson
Moja konfiguracija računalnika kaj bi spremenili cena do 800€
325231 (4975) D3m
Sestavi.si (računalnik) komponente (strani: 1 2 )
8720884 (19716) gljis
