Forum » Programska oprema » plavi zaslov
plavi zaslov
Border ::
Lep pozdrav!
Imam tezavo z racunalnikom. Racunalnik je nov (P4 2.4, MB asus p4pe, XELO radeon 9000pro 64ddr, RAM 512ddr333, 60WD 8Mb) in kupljen pri AGT. Reklamiral sem ze graficno (sapphire). Dali so mi sedaj XELO. Na racunalik imam priklopljeno se RAID PCI(2x80WD 8Mb), SIEMENS Gigaset3070 ter Epson20UX. Vsi driverji so bili dobljeni zraven hardwarea.
Ko delam z racunalnikom (igre, DV obdelava, word...) mi vcasih izpise plavi zaslon. Zakaj to? Kako popraviti? So rami (naredi sem ze test z mem86 bilo je brez napak)? Je maticna plosca? Procesor?
-----------PRVIC-----------------------------------------------
A problem has been detected and Windows has been shut davn to prevent damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you have seen this stop errors screen, restart your comuter. If this screen appears again folow this steps:
Chech to make sure any new hardware or software is properly installed. If this is a new installation ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or sofware . Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer. Press F8 to select advanced startup optuions and select safe mode.
Teehnical inforation:
*** STOP: 0x000 000 D1 (0xFF8FE000, 0x00000002, 0x00000000, 0xF81A9B41)
*** hrampa.sys � Address F81A9B41 base at F819F000, Datestamp 3C501F6E
Beginning dump of physical memory
Physical memory dump complete
Contact your system asministrator or tehnical support group for forther assistence
-----------DRUGIC-----------------------------------------------
*** STOP: 0x000 000 D1 (0xFE82A000, 0x00000002, 0x00000000, 0xF81A9B41)
Hvala za vase cenjene odgovore in pomoc!
Podvojena tema - tista v pomoč in nasveti bo dovolj - zaklepam
ToniT
ToniT
- zaklenil: ToniT ()
| » | Kako ugotoviti kaj mi serje? Bluescreeni...Oddelek: Pomoč in nasveti | 3311 (2702) | Cold1 |
| » | win 7 bsod - okvara matične ?Oddelek: Pomoč in nasveti | 2373 (2202) | vander |
| » | PC se mi resetiraOddelek: Pomoč in nasveti | 1905 (1712) | Parsifalius |
| » | težave z MSI motherboartOddelek: Strojna oprema | 3419 (2732) | EZ2BHard |
| » | Plavi zaslonOddelek: Pomoč in nasveti | 2535 (2336) | Border |
