Forum » Operacijski sistemi » TinyCore Linux GUI se ne zažene
Testman42 ::
Yo
Jaz nimam sreče s tem da bi se moj zaslon na prenosniku razumel s katerimkoli Linux sistemom.
Poskušam zagnat TinyCore Linux pa mi v virtualki lepo dela, medtem ko z diska ali z USB-ja se zažene vendar samo v ukazno vrstico, grafike ne zažene, startx pa sploh ne pozna.
Enako z Damn Small Linux.
Imam HP Pavillion G6-1225ev pa se mi že pri zagonu Fedore izklopi zaslon tako da moram prenosnik zapret in odpret da se prižge nazaj.
Kakšna ideja kako naredit da vsaj v TinyCore pridem v GUI?
Ima tudi kdo drug takšen problem?
errhec ::
Ob zagonu napiši VGA :
Recimo vga=769
Skratka poizkusi.
Tiny Core accepts the following additional boot time options:
Color 640x480 800x600 1024x768 1280x1024
256 8 bit 769 771 773 775
32000 15 bit 784 787 790 793
65000 16 bit 785 788 791 794
16.7M 24 bit 786 789 792 795
tinycore vga=7xx 7xx from table above
Recimo vga=769
Skratka poizkusi.
dd
Testman42 ::
SplitCookie ::
Pogruntaj kero grafiko imaš
Nato dalje
Nato dalje
SplitCookie> Prevoziš RDEČO ! jype> Ja? A to je kaj posebnega?
Ramon dekers> Ječa je lahko naravno okolje potem ko se adaptiraš.
jype> CPP ne spoštujem _NIKOLI_
errhec ::
Imaš podporo na uradni strani.
Help X does not start. Why does my system boot up to a login prompt?
Tiny Core defaults to vga=791 or 1024x768 but your machine may not be able to support that resolution.
At the first boot prompt type:
tinycore xsetup
This boot code creates a selectable table from the Xvesa -listmodes so it is easier to use.
If you get a blinking cursor after the "Xauthority" lines, try hitting ctrl-C to get back to text prompt, then type xsetup.sh and try another screen resolution option.
From text prompt, type: startx
Note: Xvesa -listmodes displays what your video card is capable of, but not necessarily what your monitor is. If your system does not support Xvesa then perhaps the framebuffer extension (see F2 boot screen and below for instructons).
The last resort is to use the Xorg extension.
tinycore xsetup
dd
Testman42 ::
Sem že poskusil, vendar tudi brez uspeha.
tale xsetup se zažene, samo mi ne ponudi nobenih možnosti
Kaj moram res Xorg inštalirat, je ta Xvesa tok nedodelana stvar?
Icematxyz ::
To je verjetno razlog tvoje težave torej in pa TinyCore, katerega sem preizkusil že dolgo nazaj je imel takrat svoje težave na tem področju da. Imaš vgrajeno le Intel grafično kartico ali je zraven še kakšna od AMD?
Mihal01 ::
Poskusi se lahko z Mageio
[originally forked from Mandriva]
Code
http://tinyurl.com/6mwfy7p
Oz. z Mandrivo
Code
http://tinyurl.com/thsax
Na Prestigio LCD PC Officer PO795 PC-ju:
procesor: Intel Core 2 Duo ...,
integriran GPU: Intel GMA3100
NI uspelo spraviti nobene druge Linux
distribucije kakor samo Mandrivo,
Mageie takrat se nisem zasledil,
v kolker bi jo bi prvo poskusil z njo.
Mandriva je delala b.p.,
je pa za neko placilo ponujala
fuendo .mp3 kodeke, ...
Se je pa stuff dal dobit drugod,
da se je med source dalo repozitorij
Zaradi tega, in podobnega, je tudi
nastala Mageia, projekt Mandriva
skupnosti ...
Probaj prvo z Mageio ...
In ko se je Mandriva zbootala v namizje,
sem bil prav presenecen, edina distribucija,
ki je laufala b.p. od cca. 25 sprobanih. -)
Korak do konca in Naprej :).
- spremenilo: Mihal01 ()
Testman42 ::
Moj prenosnik ima dve grafični, Intelovo HD 3000 in pa AMD Radeon HD 6470
Zdej se že nekaj časa igram s tem mojim problemom in sem ugotovil da se mi najbolj splača naložit Xorg, ker Xvesa sploh ne podpira dovolj velike resolucije, kaj šele da bi tekla na 64 bitnem sistemu (Ja, sem zamenjal tako da zdej poganjam 64 bitno jedro). vendar tudi sedaj ko sem ga naložil mi za sekundo prikaže samo wallpaper, potem pa cel ekran izklopi. Še backlight ne sveti, ekran je čisto črn.
V glavnem mislim da moram samo še obdržat prižgan ekran, usposobit kurzor in pa window manager pa sem zmagal :)
Upam da mi kaj uspe dosežt.
Icematxyz ::
Dobra izbira strojne opreme za začetnika, ki ga zanima Linux na namizju in "Hacker Way". Tukaj se verjetno (deloma) skriva razlog težave in torej, če želiš uporabljati Linux na namizju in te zanima "Hacker Way" na tej strojni opremi ti priporočam, da namestiš kakšno popularno Linux distribucijo in poskusiš usposobiti hibridno grafiko, kjer boš imel možnost preklopa med Intel in AMD grafično kartico, oziroma najprej preveri v BIOS, če se tam slučajno nahaja kaj podobnega (stikalo), ker drugače bodo najverjetneje težave z kakšno avtonomijo naprave in tako naprej.
| » | Thin client T1010Oddelek: Strojna oprema | 4050 (3557) | d4vid |
| » | Mandriva Linux (spet) tik pred stečajemOddelek: Novice / Ostale najave | 8245 (6043) | filipk |
| » | Mageia Linux 1.0 (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 42160 (39343) | MrStein |
| » | Mandriva linux 2010 - se ne boota po namestitvi popravkovOddelek: Operacijski sistemi | 2160 (1875) | Icematxyz |
| » | Kateri linux? 2 želji...Oddelek: Operacijski sistemi | 2250 (1597) | Gost |
